08-18-2017, 05:34 PM
2007 25' Safari FB SE
Bozeman
, Montana
Something is going on: Airstream rollover three
You will recall the old saying "Once is chance, twice is coincidence, but three is enemy action". Well, here goes the action:
Many of you will recall my previous post about two Airstream rollovers in a week on I90 MP319, in roughly the same spot, in early August two years ago. I am a fireman and responded to both. In both cases, weather was perfect, grade was straight and 4% downhill. Both times trailer swung around the TV. One was a small SUV with a long trailer, one a rental unit. Here is the thread.
http://www.airforums.com/forums/f463...ml#post1645004
Today, I received a page MVA I90 MP319. I was off duty, but heard later from the responders that it WAS AN AIRSTREAM IN THE SAME PLACE, where the trailer apparently tried swing the TV, based on skid marks. The TV and trailer were in the ditch on their sides. And it was apparently a rental unit. Young family of four, one transported.
So what do we make of that? I don't believe any of the TV's were larger than 1/2 ton trucks. Were the TV's overloaded? Were the driver's inexperienced? Were the hitches on right? I don't know, but something is going on, and I don't want to be a part of it.
I do know most TV's (in particular 1/2 tons) are overloaded. Here is the thread.
http://www.airforums.com/forums/f463...tml#post456088.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
08-18-2017, 05:42 PM
2012 27' Flying Cloud
W
, New England
Irresponsible of me to guess - but inexperience, no training, and excessive speed. Renting these units suggests (doesn't demand, but suggests) people have no former RV experience, if so, odds are lottery-low they took a 2-day RV Safe Driver course, and without any experience or training may assume you just drive like you always do despite having the trailer behind you. Again - irresponsible to guess here but that's my $0.02...
08-18-2017, 05:47 PM
Biloxi
, Mississippi
I have no opinion until some actual facts as to cause are known.
MICHAEL
08-18-2017, 05:54 PM
2022 23' International
Folsom
Thanks Hank,
Doing all that math right now and have eliminated a number of trailers even though they have a GVWR below my TV tow rating - its the combined weight that didn't work, and that we before altitude adjustment.
Thanks for your service,
Pat
International 23 FBT
Solitude 372 WBR
08-18-2017, 05:56 PM
W
, New England
Dagnabbit - why do you have to be all responsible after I venture out irresponsibly? [emoji23]
08-18-2017, 06:00 PM
2013 28' International
Bozeman
, Montana
I'm sorry to hear. I drive the pass often going from Bozeman to Livingston, both with Airstream in tow and also on my motorcycle. The wind gusts do get very strong and going downhill I can see someone getting taken by surprise.
http://www.kbzk.com/story/36168224/c...n-bozeman-pass
08-18-2017, 06:06 PM
Biloxi
, Mississippi
Because this thread will go the way of all its predecessors.
MICHAEL
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
As an experienced accident investigator, I investigated accidents based on the empirical assumption that there is never just one cause of any accident. There are always two or more. One is an unsafe act, the other an unsafe condition or another unsafe act.
An unsafe condition by itself never causes an accident. If the people involved are aware of the condition, they can make allowances for it, and everything is copacetic.
One unsafe act by itself never causes an accident. That's why people can say, "But I've done it that way for years and never had a problem." Until the one time they DO have a problem, because conditions were different that time.
In these three cases, there is at least one known unsafe condition, namely the 4% downhill grade. One thing that's unsafe about a downhill grade is the gravity-assisted acceleration. Most of us know to downshift and use engine compression to help control speed, and we know not to ride the brakes if we do have to brake, because hot brakes fade. But some people don't even realize that you can downshift an automatic; they just put it in "D" and go on about their way. And if they don't know to downshift, they may ride the brakes for lack of knowing what else to do. And given the way trailer brakes are typically set up, the trailer brakes will fade before the tow vehicle brakes do, leading to the tail trying to wag the dog when the tow vehicle slows and the trailer doesn't. Especially when the trailer outweighs the tow vehicle by a significant margin.
So there's a possible unsafe condition, the downhill grade, and a possible unsafe act, improper method of downhill speed control. One plus one equals two, an accident.
It's all speculation, of course. I wasn't there. I didn't see it. I didn't talk to any of the people involved. But it's entirely plausible, and it makes sense of the same type of accident happening in the same place three different times.
08-18-2017, 06:15 PM
2015 28' Flying Cloud
Durango
Well, you are part of it, and encouraging speculation in absence of knowledge is not very productive. One would need the accident reports and root cause analysis. Probably not public information.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
08-18-2017, 06:23 PM
From All Over
Don't be too hard on him. We may not be able to learn from the accidents in the absence of documented fact. But we can speculate about possible causes, and learn from each other how to deal with the hypothetical situations we come up with. That's hardly what I would call unproductive.
08-18-2017, 06:43 PM
Sag Harbor
, New York
Thanks for the link. The headline refers to Bozeman Pass, but at the bottom of the short article it says:
"Another crash is slowing traffic just east of Livingston (see photos).This is a developing story and will be updated as more information becomes available."
The photos are not much help IMO:
In previous accidents, the photos showed some details which permitted further inquiry.
The news article says it will be updated.
Winds at the airport were light and unremarkable IMO: http://w1.weather.gov/obhistory/KBZN.html
The Livingston paper has nothing that I see: http://www.livingstonenterprise.com/...-local-stories
Nothing at all to go on about what caused the accident IMO.
Peter
08-18-2017, 07:10 PM
Sag Harbor
, New York
Here are some traffic cams east of Livingston on (?) I-90:
http://rwis.mdt.mt.gov/scanweb/swfra...va&SenType=All
. . . but not sure how to get the historical data.
Although the winds at the Bozeman airport were light per the previous post, the Livingston airport experienced strong winds this afternoon from 12:53 to 3:53 PM local time, with gusts up to 29 MPH from the west. Not insignificant IMO:
http://w1.weather.gov/obhistory/KLVM.html
The mountain range between Bozeman and Livingston could easily augment the westerly winds coming down the mountain into Livingston IMO.
https://www.google.com/maps/place/Li...4d-110.5599556
Here is another view of the wind data, with the westerly gusts highlighted in pink:
http://www.wrh.noaa.gov/mesowest/get...M&num=72&raw=0
The 2:03 PM MDT weather warnings here: [scroll down page to find it by time stamp]
http://www.weather.gov/wwamap/wwatxt...wa=byz&wwa=all
. . . included this text:
"* Impacts/Timing: A dry cold front will create dry and breezy conditions beginning this afternoon. Wind and dry conditions will likely occur on the midslopes and ridges well into the overnight hours tonight.
* Winds: West winds 15 to 20 mph with gusts to 30 mph through exposed areas. Peak winds are expected between 6 to 9 pm."
Again, no speculation about causes for the roll-over -- just some raw data to consider. If the news article is updated, or the driver posts here [which happened last year -- was that Montana also? Hmmmmm . . . ], then the wind date may come into play.
Have a good weekend!
Cheers,
Peter
FWIW
08-18-2017, 07:52 PM
2006 25' Safari
St. Augustine
I betcha its those darn Chevys with the bad steering and brakes!
Seriously, it would be good to know if possible. The idea of unfamiliar drivers is a good possibility.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
08-18-2017, 07:58 PM
Lakes Region
, New Hampshire
Speculation...
Looking at the map and following the highway looking for where it might have happened, before I saw the photos, my guess was pretty much correct on the location. So I'll go with my reasoning that led me to select the spot.
On the North side of the highway there are two sections of small cliff blinds, north of those two sections are the valleys which lead north, one housing Jackson Creek Road the other Quinn Creek Road up into the mountains, I live in NH, home of the highest wind speeds ever recorded (okay, not anymore) those speeds are achieved by the mountains funneling affects, the same would be the case here. So even if the airport doesn't see high winds, small winds can be focused and channeled to be stronger somewhere else. This combined with the blinds, creating a calm area, which you are abruptly dumped out of, then add in that you are coming out of the hills and can pretty much see flatter road ahead (causing you to think coast slightly and cool the brakes) then add in 2 of these accidents involved rental units (experience/equipment condition) no muscle memory to reach/squeeze brake controller. Add in a slightly sudden increased tailwind, channel affect and the whole thing could get squirrelly extremely quickly.
It's kinda like the Santa Annas coming in and blowing over parked CH-53s
Dropped Pin
near I-90, Bozeman, MT 59715
https://goo.gl/maps/LdaW2EQ5wEN2
08-18-2017, 08:03 PM
Dazed and Confused
Hillsburgh
, Ontario
We all know sections of roads or curves that have collect their fair share of victims over the years; from sharp drop offs that unload suspensions in the winter, to decreasing radius curves that cause 18 wheelers to roll with alarming regularity.
This could be such a case of undulating pavement that starts a swaying resonance or something of that ilk that catches the inexperienced and unwary.
Truly hope that all were okay.
08-18-2017, 08:19 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
On the Airstream Adicts Facebook page there was a post from sombody not long after they rolled. The reason was they freaked out after looking down and seeing a yellow jacket on their hand.
08-18-2017, 10:55 PM
1969 25' Tradewind
Shasta Lake
Another thing to consider is the TV in a bunch of these rentals is a short wheelbase Tahoe coupled to a 28' Airstream.
IMHO I think the 28' should have a longer wheelbase TV like the Suburban at least.
The Tahoe is better matched to the 23' .
08-18-2017, 11:40 PM
1978 31' Excella 500
Genoa
, Nevada
Bravo on the sleuthing, using what long distance evidence can be gleaned. Someone somewhere will save themselves by reading this thread and think about it while driving down similar conditions. Sudden wind gusts may be something some folks have never seen or are prepared for. The wrong shape bumps in the road for certain size set ups could make bad bumps for someone.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
08-19-2017, 02:55 AM
2005 19' Safari
GLENDALE
, AZ
Re: Airstream Accident on Bozeman Pass
I normally don't participate in speculations regarding accident causes; however, I think RandyNY is on the right track.
I located the accident site by comparing the backgrounds in the photos with Google Earth street views (GPS: 45° 40.032'N 110° 49.293'W), and the TV and Airstream probably lost control just after going over the summit of Bozeman Pass. The speed limit is 75 mph (trucks, 65 mph), and 1,200 to 1,500 feet before where the TV and trailer are seen laying on their sides is a low point between two deep cuts in the hillside. (See photos below.)
If the driver had just passed the summit and started down the moderate grade (calculated at about 6% from the decrease in elevation between the hill cuts and where the rig landed), the Airstream was probably pushing slightly, or slack on the trailer hitch. This condition, plus excess speed (75 mph?) and a side-wind blowing through low point between the cuts could easily have caused unexpected sway and loss of control. And, this assumes there were no contributing mechanical or tire problems. (It is also interesting that there is a roadside memorial cross/marker on the larger hill cut.)
We have often encountered severe cross-winds in areas like this, and caution and lower towing speeds (55-60 mph) are warranted to maintain control.
Just my opinion...
Note: Street view photo is approaching first (larger) cut in hillside.
08-19-2017, 03:20 AM
Mantua
, Ohio
Irregardless of all the talk about grade, wind etc, it all comes down to driver error.
