My inverter is located under one of the dinette seats. It is kind of handy to know where it is, since it has an inline fuse that might blow out sometime. It doesn't have the 115 v cord on it that Bigventure references; I suppose different inverters were installed in different Airstreams at different times. It is also handy to know that it is one of the very few things that is wired directly from the battery and isn't turned off when you push the main store/use switch that is supposed to turn everything else off in the trailer. So at least in my trailer, the different outlets make sense, since it doesn't seem easy to run shore power to the inverter outlets.
