Old 01-30-2016, 11:18 AM   #113
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Originally Posted by SeeMore View Post
The slide mechanism was built by Power Gear, 1217 E. 7th Street Mishawaka, Indiana 46544. (1-800-334-4712)
You may get greater clarity, or actual diagrams, from the manufacturer for your particular year model.
Meanwhile, you can see a diagram of the 2003 model on page I-4 at this URL:http://www.airstream.com/wp-content/...lassic2003.pdf
Thanks Dave,
I have the 2002 Parts Manual and it has the same, or similar picture. IT doesn't show the rollers that are mounted on the side of the frame, or anything on the bottom of the slide or on the floor on the inside. I think what is shown is the drive mechanism, but it is not weight bearing. I'll try to contact Power Gear and/or dig through the parts book some more.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 01-30-2016, 12:03 PM   #114
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
My investigation into the question discovered these type rollers as the two methods used back then. The specs also mentioned each rail was capable of supporting 400 pounds in the OUT position at 30" making 800 lbs the limit for slide out contents (discounting slide weight) when deployed at 24".
I wish I could confirm the actual mounting method and placement but concluded one was affixed to the slide shell floor and the other mounted to the floor below the shell contacting either the rail from above or below. The first method would change the leverage point based on where the slide out was in or out. The second method would affix the leverage point and may have reduced the stress/twist on the mechanisms.
I could be wrong as I haven't been inside the mechanism or under my slide's flooring to actually see the installation. That was as far as I dug because I learned I had the second edition design.
Name:	Screen Shot 2016-01-30 at 1.53.27 PM.png
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 01-30-2016, 12:53 PM   #115
Found this in Airslide's slide adjustment thread. I don't know what vintage it is, but it appears to support the floor outside, but closely adjacent to, the frame rail.
I guess those rails look like they could support 400# each. I'll just have to try to see what I've got when I get there.
Al
S/OS #004
Old 01-30-2016, 10:44 PM   #116
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by Al and Missy View Post
Thanks Dave,
Al
Just a heads-up that Power Gear was bought out by Lippert Components. They still have all the Power Gear information and parts available though and their website has lots of information on various slides. My Power Gear slide controller recently fried and Lippert was very good about ensuring i had the correct replacement.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 02-03-2016, 06:25 PM   #117
What is this? 2002 Classic 30 Slide
Here's a picture of what I'm seeing on the floor at the front of the slide dinette. The dealer says that these are "drains" and all slides have them. Seemore and the dealer that replaced the slide gasket and repaired some floor damage from the leaks says no.
Does anyone have anything like this on their trailer? The resolution on the pictures does not permit zooming enough to get a clear look.
Al
Name:	Floor artifacts.jpg
S/OS #004
Old 02-03-2016, 09:03 PM   #118
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sliders Unite!!
When was that trailer built? I know that Airstream did a retrofit on the gaskets on the early slide outs. I was up at Jackson Center in July or August of 2001 having my A/C checked out. There was a slide there having its gaskets replaced. The owner told me that they brought guys from the plant over to do it since the regular repair guys were not yet familiar with the process and the gaskets. I don't think my 2003 shows evidence of drains in that area. The floor is fully carpeted. I wonder if this trailer has the old style gaskets? Here is my trailer and you may be able to zoom this picture dependent on what you are using to view this post. I need to get out where I store it to take a closer look and maybe shoot a close up. I'll see if I have time next week to possibly do that.
JackClick image for larger version
Jack Canavera
STL Mo.
AIR #56
Old 02-03-2016, 10:21 PM   #119
JackAttachment 256781
Thanks Jack,
I'll check the build date tomorrow. The original owner told me that the slide wiper seal was replaced in 2014 by their local dealer. I presume that it would have been fitted with the updated gasket at that time. Your picture will be helpful. I zoomed it and can see that the carpet goes all the way to the wall.
Al
S/OS #004
Old 02-03-2016, 11:14 PM   #120
Tracking the ancestry of the slide
Looking at the Airstream manuals and data archive I found that only the 2002 Classic 30' slideout, and no other model or year lists the following parts:
203226-01 and 203226-02, Drain, plastic, RH and LH.
Curiouser and curioser........
Al
S/OS #004
Old 02-04-2016, 05:22 AM   #121
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
Al
I have a 2004 34' slide-out lounge model; it has the roller mounted on the floor centered and about 12 inches back when the slide is in the out position. There are drains in the floor on both sides next to the slide-out (not on the slide-out). The drain is a 2x1x.5 inch plastic piece, with a plastic pipe that goes out the bottom of the trailer.
Of course both were full of factory building trash (aluminum shavings, rivets, and yellow glue), and did not drain very well until I found them while removing the carpet, and cleaned them out.
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 02-04-2016, 10:37 PM   #122
I should have said, "...of the models I checked...." Which were 2001,2,3. I didnt check 2004 and later.
More importantly, we are now slideout owners - we bought the 2002 Classic 30. pictures to follow .
Al
S/OS #004
Old 02-05-2016, 10:24 PM   #123
pappy19's Avatar
Garden Valley , Idaho
Glad you made the plunge. These units are getting harder to find. We love ours and always get a crowd wanting to see the inside, so be prepared. Welcome to the Slider Club!!
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-07-2016, 10:55 AM   #124
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
How does one find the length of a 28 ft safari slideout from bumper to hitch?
mcomeaux is offline   Reply With Quote
Old 02-07-2016, 11:37 AM   #125
TinShack's Avatar
2005 28' Safari S/O
My 2005 28' slideout is 28'-11". Nearly all Airstream specs and information can be found on the Airstream website at this location... http://www.airstream.com/service/document-archive/
Steve
Old 02-07-2016, 10:16 PM   #126
mcomeaux's Avatar
Sunriver , Oregon
Thanks Tin for the info
Curtain Sliders For '63 Overlander squrlgurl Upholstery, Blinds, Walls & Interior Finishes 4 08-29-2014 08:29 AM
Gaucho Sliders Lumatic General Interior Topics 5 10-10-2012 06:54 PM
1962 Overlander Curtain Sliders gnored Upholstery, Blinds, Walls & Interior Finishes 0 06-12-2009 10:35 AM
Looking for curtain sliders for globetrotter mariestephan Upholstery, Blinds, Walls & Interior Finishes 6 04-21-2009 12:39 PM
1964 curtain sliders Safari64 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2008 06:49 AM
