Old 05-08-2014, 01:54 PM   #57
Just purchased our 30 ft so classic. We have 2 big dogs so the floor space is appreciated. Just taking our first trip to Utah.
rasjad is offline   Reply With Quote
Old 05-08-2014, 02:14 PM   #58
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Originally Posted by pappy19 View Post
I am getting an estimate for my carpet removal and hardwood replacement; around $1,800.00, is this a fair price?
Pappy,
That's about what we paid for our synthetic installed on the diagonal about eight years ago. Sounds good. Enjoy.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 05-08-2014, 06:58 PM   #59
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
rasjad,
Welcome to Airforums. More experience here that we'll ever know. I think the S/O is a special model you'll get more questions about it than you imagined. Folks will want pictures and we'll ask for model specifics so be prepared.
Now, how about the year info?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-08-2014, 06:59 PM   #60
GCinSC2's Avatar
Pappy,
No idea on price but I'll be watching and hoping you post the pic's.
Gary
S/OS #001
Old 05-09-2014, 06:30 AM   #61
SteveH's Avatar
Common Sense , Texas
Would be really nice for us that don't know would be some in progress pictures of what is under the slide, and how the carpet is removed from under there.
Regards,
Steve
Old 05-09-2014, 05:03 PM   #62
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
325 lbs of pet space
You'll discover a slide is the best way to accommodate large dogs and 'streaming. My two Danes are both over 150lbs each and they sleep together on the living room floor - a feat not possible in a standard.
Enjoy Utah!
SeeMore is offline   Reply With Quote
Old 05-11-2014, 06:42 AM   #63
RKL1954's Avatar
2015 25' FB Flying Cloud
1966 28' Ambassador
Vancouver , Washington
In answer to GCinSC2's question - we have a 2007 30' with S/O. We purchased it in Jan right before I retired. I've done a bunch of "upgrades" already - they include:
- Switched to all LED lights
- Installed 4 Lifeline batteries and a Magnum Inverter (I plan to install solar this summer)
- Installed a GPS "anti-theft" system/alarm (I posted something on that about a month ago).
- Installed a back view camera (I like to know what's behind me when I'm driving/parking)
- Installed a separate GPS tracker so I could create "maps" of our trips using Google Maps (see attachment).
This summer I plan to:
- Install solar (as above)
- Build a cover for the AS
- remove the carpet and install a different flooring material (why did AS think putting a pale yellow carpet right by the entrance was a good idea?!?)
Who ever said retirement was boring?
Rasjad
RKL1954 is offline   Reply With Quote
Old 05-11-2014, 01:43 PM   #64
GCinSC2's Avatar
Rasjad,
Haven't found out if retirement is boring, hope to someday.
If this has not been covered by your getting to know your trailer, several things worth checking. If you've been there done that, just post the pic of the T shirt.
Brake actuator, AS did a recall but if you still have the grey plastic housing Actibrake, it needs a close eye or just scrap it.
Brake hoses, again an AS recall to R&R with longer ones that don't kink.
Found this about my 2007. But here's one that might scratch your head, what is the axle rating of YOUR trailers axles? Not any nameplate data stuff, crawl under get the AS P/N and check that # in your parts manual for its ratings. I bet your nameplate says 5,000 Lb/Axle. What is the axle rating? If you need further advice on this let me know.
15's vs. 16's too many threads but all show concern on heavier tandems and 15" ST's.
Almost all of my efforts have been running gear issues but those 4 piston disc brakes are strong and smooth.
Slides are cool.
Gary
S/OS #001
Old 05-14-2014, 12:59 PM   #65
RKL1954's Avatar
1966 28' Ambassador
Originally Posted by GCinSC2 View Post
Rasjad,
Slides are cool.
Gary
I will definitely check out those things. We purchased it from a dealer and they gave us a 1 year warranty so if there are any repairs I'm sure they will cover it.
I just purchased four 15" ST tires a month ago. I think I'll run them for now.
Rasjad
Old 05-18-2014, 09:26 AM   #66
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Originally Posted by SteveH View Post
We bought our trailer used, and it had set out in the sun on top of a hill in California since new, with the slide out. The slide awning material was bad. So, I called Zipp Dee and ordered a new fabric. It was not what I'd call cheap, and it was not a snap to change, but we got it done. It was one of those things that looked easy, but you do need to read, understand, and follow the instructions. I could do another one very quickly having done one already.
We have an '02 and I'm wondering how long it will be before I will need the ZipDee replaced on my slide. Anyone have a similar replacement?
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 05-18-2014, 09:42 AM   #67
jcanavera's Avatar
Fenton , Missouri
Images: 143
I guess how long the awning lasts is based on how it gets treated. The slide awning does contact the top edge of the slide unit so you do have a friction point there. I haven't looked carefully at that point of contact on my '04.
I have had the loop on the slide awning pull strap tear so I can't use the hook to pull it out. For all intents that long strap loop would be important if you want to open the awning prior to the slide extending. In my case I always open the slide first prior to pulling the awning out. Extending the slide partially unrolls the awning which allows the strap to be reached by hand.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-18-2014, 01:19 PM   #68
SteveH's Avatar
We had to replace the slide awning on our '08, but only because it sat out in the sun, and under a tree for five years before we bought it. That should give you some idea how long it will last. It would have been OK if not for the tree stuff that wouldn't come off.
Regards,
Steve
Old 06-12-2014, 10:02 AM   #69
benwilbanks's Avatar
2004 34' Classic S/O
2006 25' International CCD
Marietta , Georgia
We have had 2-a 2001 and a 2004 Lounge slide out and they are great. They are used more for destination camping. 3 months in Fl every winter is perfect for a 34-slide. It seems like twice the room of a regular 34.
benwilbanks is offline   Reply With Quote
Old 06-12-2014, 04:54 PM   #70
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I like the ones with the lounge slide and the fireplace in the front.
I wish they would make them again.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Curtain Sliders For '63 Overlander squrlgurl Upholstery, Blinds, Walls & Interior Finishes 4 08-29-2014 08:29 AM
Gaucho Sliders Lumatic General Interior Topics 5 10-10-2012 06:54 PM
1962 Overlander Curtain Sliders gnored Upholstery, Blinds, Walls & Interior Finishes 0 06-12-2009 10:35 AM
Looking for curtain sliders for globetrotter mariestephan Upholstery, Blinds, Walls & Interior Finishes 6 04-21-2009 12:39 PM
1964 curtain sliders Safari64 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2008 06:49 AM
