Old 04-15-2014, 06:20 PM   #43
SteveH's Avatar
Common Sense , Texas
Originally Posted by jcanavera View Post
I remember asking the dealer if they could build one without the carpet and at the time he said that the carpet was necessary for the rollers supported the slide when it moved inside. Supposedly the roller would damage a hard floor and the factory refused to build one without even though I requested. Later models did come without the carpet but I was told that the roller system had been modified to not cause floor damage.
We have friends in our unit that have a 34' couch slide that came from the factory with carpet, and they have had the carpet changed out to wood flooring. The wood flooring is damaged where the slide goes over it.
I'm wondering what the procedure is for changing out the carpet under the slide.
Regards,
Steve
Old 04-15-2014, 06:42 PM   #44
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Steve I'm not sure. I wonder what year your friends trailer was built? I know that when I extend the slider, I can see the track marks in the carpet. The pile is not damaged though and the tracks vacuum right out. I now can see that a hard floor might be damaged by the rollers. I'm not sure what year Airstream started allowing hard floors on the slide outs.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-15-2014, 07:19 PM   #45
SteveH's Avatar
My friend's trailer is either a 2000, or 2001. And yes, we see the tracks in the carpet pile also. Do you think the slide must be removed to replace the carpet? That seems a little extreme to me, but might be possible.
Just wondering because I can see where in the future we will want to replace it.
Regards,
Steve
Old 04-15-2014, 07:47 PM   #46
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Airstream slides are the best.
When you want to set-up camp, you've got all that extra room at your fingertips.
Without compromising the purity of an Airstream
and when you're underway, and stop for a lunch/legstretch/diaperchange, you've still got all the space and functionality of a standard 31' Dinette, without having to drop the stabs and extend the slide (you won't find that versatility in most SOB slide models).
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 04-15-2014, 07:52 PM   #47
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by ZoominC6 View Post
We purchased our 30' Classic S/O new in 2004 and have had fun changing things and making it our own. Can't think of ever trading it as Airstream makes such a great platform.
Did you change out the flooring from carpet in your slideout? If so, you can make a lot of slideout people happy if you would explain what you did!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 04-15-2014, 08:17 PM   #48
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Our 2002 S/O has carpet and I am sure looking to change it out to wood, at least in the kitchen. Makes no sense to have carpet in the kitchen. That's my only complaint with our S/O. We may stop at the mother ship on our upcoming 7,000 mile trip, and see if changing to a wood floor will be possible.
Name:	Spring Trip 2011 024 (Small).jpg
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 04-15-2014, 08:38 PM   #49
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Our SOB trailer had carpet only in the slide. The rest of the trailer was vinyl flooring. You could tell where the carpet was matted down from the slide going in and out.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-15-2014, 09:13 PM   #50
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
There are a number of posts about carpet removal in the Airforums if you can formulate your search query correctly. It took me quite a while to find what others did. Here are a couple:
http://www.airforums.com/forums/f36/...ml#post1399401
http://www.airforums.com/forums/f461...ml#post1143976
I am just starting the design phase for a flooring overhaul in my 28 S/O and assessing various materials, patterns, colors, etc. I only parked the trailer at my shop today to conjure up my plan and execution methods plus start the measurement, inspections, etc. My research has only just begun and my interest is either cork or maybe the new 100% waterproof, loose lay solid vinyl planks that are dimensionally stable. I guess I need to photograph the event and add to the database of knowledge on the forum.
What I have learned, but not verified on my unit, is that two methods were used for easing friction when the slide moved. Some models had wheels mounted to the slide bottom that move across the floor surface and others had wheels mounted to the floor on which the slide sat. The first method is an issue with hard flooring surfaces due to marks and buckling on floating floors. The change happened around the '03-04 timeframe in the various comments/information I've read online.
SeeMore is offline   Reply With Quote
Old 04-15-2014, 09:26 PM   #51
jcanavera's Avatar
Fenton , Missouri
Images: 143
Sliders Unite!!
I just don't think you can remove the carpet in those older slide outs without risking damage to the new floor. The question is whether the old slides could be retrofitted with whatever changes were made in the newer slides.
I have an '04 and the rollers move across the carpet pressing on the carpet.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-15-2014, 09:31 PM   #52
1974 25' Tradewind
2000 34' Limited S/O
cottontown , Tennessee
You have 4 rollers mounted in plywood floor at outside wall on a lounge s/o these rollers do not move in or out. If you open up compartment under slide you will see the roller plate on back side of plywood at the out side wall These roller plates will be slightly above or even with plywood bottom . My slide bottom rides on this rollers. These rollers are fastened on top side. If you adjust slide adjustment bolt vertical down you can put a lot of pressure on these rollers when it closes up.These rollers are a pivoting point between slide bottom and slide mechanism and adjustment bolt. If you open slide half way you can rock slide up and down on what i call the pivoting point rollers. As slide moves into trailer the inside front bottom of slide will tilt forward causing more drag on carpet or wood floor because of pivoting point changing . I have 3/8 wood floor in mine i use a piece of felt under one corner of slide going out or in.
shamrock is offline   Reply With Quote
Old 04-15-2014, 09:50 PM   #53
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
@shamrock - Thanks for the clues. I have never had any marks on my carpet and the front edge barely touches the top of the carpet nap. My slide must be perfectly level with the floor, an Airstream first? I may try the half way trick to see under the edge. I suspect my rollers may match yours with a mounting to the floor.
If so, the flooring issue will be a bit easier to cope with. I will just have to figure how to make a big enough floor section to slide under the leading edge when the slide is out and ensure I have a secure boundary.
Old 04-20-2014, 04:46 AM   #54
ZoominC6's Avatar
Colleyville , Texas
CASteamer,
We didn't remove the carpet ourselves. Some years back, 6 or 7, we had our dealer remove the carpet for us after seeing work he'd done on another Airstream. He removed the sofa and anywhere carpet was installed underneath then installed a faux wood flooring that has a wood grain imbossed into the planking and installed it on a diagonal as shown. It's so much easier to keep clean. We did leave the carpet in the bedroom. A couple of years ago we had the fabric removed from the dinette and sofa, had premium backing installed under real leather then had the slide out flanges wraped in a vinyl that matches the color of the mouse fur on the walls.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 04-21-2014, 04:49 AM   #55
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
I really like your colors. It all goes together very nicely.
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 05-08-2014, 10:51 AM   #56
pappy19's Avatar
I am getting an estimate for my carpet removal and hardwood replacement; around $1,800.00, is this a fair price?
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Curtain Sliders For '63 Overlander squrlgurl Upholstery, Blinds, Walls & Interior Finishes 4 08-29-2014 08:29 AM
Gaucho Sliders Lumatic General Interior Topics 5 10-10-2012 06:54 PM
1962 Overlander Curtain Sliders gnored Upholstery, Blinds, Walls & Interior Finishes 0 06-12-2009 10:35 AM
Looking for curtain sliders for globetrotter mariestephan Upholstery, Blinds, Walls & Interior Finishes 6 04-21-2009 12:39 PM
1964 curtain sliders Safari64 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2008 06:49 AM
