Old 12-24-2014, 03:49 PM   #1
2014 19' Flying Cloud
Eugene , Oregon
Sleeping in Corner Bed
You may think this is a silly question, but we were wondering which end of the corner bed do you lay your head(s). We tend toward the aft end, but started at the forward end. No matter which way, one of us becomes intimate with knees and elbows in the middle of the night. Any ideas? No, we don't want bunks. Dave
Dave-Nancy is offline   Reply With Quote
Old 12-24-2014, 04:06 PM   #2
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
That pretty much sums it up. Whats interesting to us is our 20 ft FC has the same size bed as the 19 but it is accross the front and it appears to be bigger and more comfortable to us. We owned both BTW.
subfan1 is offline   Reply With Quote
Old 12-24-2014, 04:54 PM   #3
ottawa (greely) , Ontario
We had a 19 foot airstream and we had no problem sleeping on the corner bed ,first of all my wife and I are slim so no problem with width of the bed ,I'm average height 5foot 10 inches and my wife is 5 foot 4 inches so normaly the taller person would get the full square end of the bed and the shorter the curved end but I'm a sound sleeper and a morning person so I chose the shorter curved side and she would crawl over me at night and not wake me and in the morning I could get out of bed and not have to crawl over her and wake her . As for the length of the bed it was fine for me on the curved side and since we are sleeping bag people for camping never have a problem with length of bed as in a sleeping bag your feet can overhang a few inches with no problem, and we always slept with our heads at the square end of bed .
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 12-24-2014, 05:22 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I'm 6'-2+ and my wife is 5'-0-. In our 25' corner bed I get the long side. DW gets the curved wall short side. I have to sleep with my head toward the rear because my feet hang over the edge. She sleeps with her head toward the back also. I've found that If I sleep on the slight diagonal I don't hang over so bad. DW likes to snuggle up, so it works for us most of the time. If one of us starts feeling a little crowded, it's me that usually end up on the sofa.
The only real solution that I have found to give us all the room needed is the queen bed in a larger trailer. I have had the twin setup in prior trailers. I find them to narrow.
Alan
Old 12-24-2014, 05:42 PM   #5
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
Smile
We have a FC 23D and are new to Airstreams. The first couple of trips we slept with our heads to the rear of the trailer which worked fine 50/50 sharing. Then we took our two cats on our next trip so now it is 33/33/33 and is a little tight, I might end up with a sleeping bag on th pull out sofa
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Old 12-24-2014, 07:17 PM   #6
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I usually sleep with head to rear, but recently flipped around as I lved being able to look out the window. We were in Maine on the Ocean and it was so wonderful watching the tide and lapping water.i
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 12-24-2014, 07:28 PM   #7
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
We sleep with our heads towards the front. That puts your head into the warmer part of the trailer, and out of the draft off of the back window - much better in colder weather. Also it puts your feet into the narrower part, allowing you to move your arms around. I sleep against the wall so that Becky doesn't have to climb over me to get out to use the bathroom. For a while, when we tried used the corner bed with our heads facing the back, we ended up making up the dinette and sleeping separately. Switching ends put us back together again-yeah! I'm also a bit claustrophobic, so sleeping with my head under the cabinet above also made me uneasy.
robert claus is offline   Reply With Quote
Old 12-24-2014, 11:35 PM   #8
Eugene , Oregon
Thank you so much for the input. I should have mentioned that Nancy is thin and I am not really heavy, but larger than my cute, petite Norske. We have no problems with the size of the bed, for us. I feel that it is definitely harder to exit at night if one's head is at the aft end of the AS. We will use the AS pillows and overhead lights in the after-part as a lounge and the forward part as where we enter and exit the bed, at night. It is really great to get help from all of you on an issue that might seem trite, but isn't to us. Thanks!
Old 12-25-2014, 01:25 PM   #9
Goal15's Avatar
Dallas , Texas
We started out sleeping head to back but DW said it made her feel claustrophobic. So we addedd a Sharper Image Memory Foam topper and switched to feet to the back and have slept better. Still hoping to move up to a 25 FB at some point to get bigger bed and more knee space in the john
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Sleeping Accommodations beyond the queen bed in a 25FB or 27FB MaryD 2008 Safari SE 10 04-13-2010 10:54 AM
Sleeping position: Corner bed owners ericwarren Our Community 13 11-05-2008 07:15 PM
Comfortable Sleeping - bed, mattress, pad??? kudzu Community Polls 19 07-23-2006 07:31 AM
25' With rear corner bed j54mark 1984 - 1989 Sovereign 16 02-16-2005 10:13 PM
Making the bed in the corner...Help! wildwoodrver Our Community 12 11-16-2004 12:57 PM
