Old 05-17-2019, 04:48 PM   #1
2019 25' International
Washington , Washington, D.C.
Shower door sweep
Jackson Center Airstream has replaced this once as part of warranty. Three days
into my road trip Click image for larger version
ID:	340989, it’s doing this: (hoping photo attached). I’ve tried sliding it out and then sliding it back in, no joy. Any permanent fix suggestions from the community?
PatLee is offline   Reply With Quote
Old 05-17-2019, 08:47 PM   #2
2013 28' Flying Cloud
Penn Yan , New York
Sweep
Make sure the bottom seal/sweep is the correct length. I replaced mine and it was a little long and it would come out. I trimmed it to the exact size of the door track and that fixed it, no more issues.
delrossa is offline   Reply With Quote
Old 05-17-2019, 08:52 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Yeah it’s a plastic bit - once it gets messed up it deforms and doesn’t go back as new. $5-$10 part thereabouts. Plan to replace every 1-2 years. Wear and tear.
In your case it may have been mis-fed into the track when originally assembled, causing to to get mangled after a few open / closes. Most dealers are not hyper detail oriented / focused so likely not caught on PDI.
wulfraat is offline   Reply With Quote
Old 05-17-2019, 09:16 PM   #4
2007 27' Safari FB SE
Forest Grove , Oregon
To help all of us simple folks...the reference to it being a stock part and easily replaced....can you give us more details as to part number, what part to specifically ask for, what aisle and bin number to find it in the big box companies....., etc.
Or do we need to order it from one of the trusted suppliers who are small companies that we see on this site and can't advertise for them either??
bweybright is offline   Reply With Quote
Old 05-17-2019, 09:24 PM   #5
wulfraat's Avatar
Shower door sweep
Seven dollars and night five cents. Google is your friend:
“Airstream shower door sweep”
http://odmrv.com/catalog/index.php?m...oducts_id=1517
Out of doors mart is a very reputable supplier.
You can also call airstream customer service and say “I need a new door sweep for the shower”. They’ll know exactly what you are after - they’ve been using the same door for a number of years.
When I called they sent me a new one no charge as I was still under warrantee.
Otherwise out of doors mart can send you one for seven bucks and change plus shipping.
Old 05-18-2019, 06:27 AM   #6
Thanks, guys, you’re the best!
Old 05-18-2019, 07:58 AM   #7
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
We had the same ‘sweep’ problem with the shower door on our 2014 FC.
the sweep kept shearing off.
Permanent fix- remove the sweep.
We installed a shower curtain and have had no leaks.
az-streamer is offline   Reply With Quote
Old 05-18-2019, 08:36 AM   #8
wulfraat's Avatar
Shower door sweep
If your door is too low, causing unnecessary friction against the sweep, call airstream customer service and they’ll send you a little kit to raise the door and stop the sweep from dragging.... no charge
Old 05-18-2019, 03:14 PM   #9
2017 28' International
Flint , Texas
We also installed a “hospital type” nylon shower curtain just inside our shower door. Used a spring rod so we could lay it on the shower floor during towing. No more leaks. This has been a problem on all 5 of our Airstream trailers.
cowcreek7 is offline   Reply With Quote
Old 05-18-2019, 06:46 PM   #10
2014 27' FB Eddie Bauer
Coldwater , Ontario
Ours tore. I removed it. Less water outside the shower. I’m happy.
The sweep pulled water from the lower door track when the door was opened. With the sweep gone, water doesn’t escape during showers and the door doesn’t sweep water out.
So, for the life of me, I can’t see why you’d bother with it. YMMV
bbandeddie is offline   Reply With Quote
Old 05-18-2019, 07:25 PM   #11
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Try to keep it in the channel so that it does not work out ... silicone sealer is your friend.
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 05-21-2019, 06:55 AM   #12
I removed the shower sweep and didn’t replace it. I took a shower last night (sans sweep) and the floor outside the shower remained dry. So to bandeddie’s point, why bother replacing it? Also, the shower door no longer sticks at the bottom when I open it. Thanks everyone for your responses.
2013 Classic 30 shower door sweep m.hony Sinks, Showers & Toilets 11 11-20-2017 04:18 PM
Shower door sweep failing frequently Robere 2009-2015 Flying Cloud 17 11-09-2017 07:47 PM
Shower sweep failure Gamehawkers 2016 - Current Classic (all lengths) 11 09-26-2017 03:42 PM
Has anyone had a custom lucite or clear plastic folding shower door made fro shower? Driftin Di Sinks, Showers & Toilets 2 08-09-2017 07:34 AM
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
