Old 11-08-2006, 08:21 AM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Set-up & Break-down Tips
I recently began using garden hose quick-connects on my city water and black tank flush hose connections. I am also using them on my "Y" hose connector to the city water supply. I now use these on every hose connection and have found that it is a significant improvement over screwing on the hose attachments, especially in the dark.
I am passing this on and asking that others please pass on time and effort saving tips for making and breaking camp.
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 11-08-2006, 08:49 AM   #2
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Maybe sounds silly, but put colored plastic clothes pins (red or blue) on "littles" that you need to remember so that you see these easily as you do your ready to go survey of the interior. For example, it's easy to forget your antenna is up, so place one on the ceiling handle. It works; you'll notice it! Another place for clips is on the leather holding tabs for the sliding doors separating the bath from other areas. If not secured back, these will slide and bang enroute. A red clothespin helps you remember to snap them shut. You might also clip some to curtains at windows that you've opened to remember to latch them shut. I'm sure there are other useful places to clip a reminder, but these are some sure ones. (Granted, most of you don't need as much reminding as I do!) ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 11-08-2006, 11:47 AM   #3
Avion am I
1968 17' Caravel
San Luis Obispo , California
Pre-Travel List
It is easy to miss an important to-do item prior to travel to or from a trip.
I have compiled a comprehensive list for all our needs, and a check list for all must dos. It is updated as needed from time to time, especially when needs change.
While the list is highly personalized (in Microsoft Word form), it could easily be modified for other's needs.
I would be glad to send it to anyone interested.
J. Codispoti
joecodi@clearsightusa.com
joecodi is offline   Reply With Quote
Quicky Hints and Tips FrankR General Repair Forum 7 10-05-2012 11:09 PM
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 09:27 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-06-2006 12:00 AM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 10:08 PM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 07:50 PM
