Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 02-17-2015, 05:16 PM   #1
Tao
Tao's Avatar
2022 16' Basecamp
Chapel Hill , North Carolina
Segway X2-SE and Airstream Intl. 19?
Hi Folks,
We have just puchased a 2012 Intl. 19 in new condition and are getting it set up for our spring trip. (We have previously owned a 16 Anniversary and a 22 Safari.) We are towing it with a 2015 Toyota Tundra 1794 Edition. Bed has a RollBak cover on it.
Now, I have a degenerative neurological disease. This disease comes with a Handicap Placard. Problem is there are days where I just have a difficult time walking, thus I bought a new Segway X2-SE. Plan is to use it to continue my life long passion of Landscape photography. I prefer to be "entertained" by this disease rather than resticted.
Now, it would be very helpful to take the Segway with us BUT the truck hitch receiver is taken by the Airstream (we previously put our Segway lift/carrier (SegVator) in the hitch and would wander in the truck with the Segway on the tail.
From all I've read, putting a hitch on the back of the Airstream 19 is not a good idea - put's too much weight behind the trailer axel. Segway X2-SE weight is about 120 lbs.
Has anyone found a good way to take something like the Segway with us?
I'm sure some cleaver rascal has already addressed this issue and I'm anxious to learn!
Jack
Tao is offline   Reply With Quote
Old 02-17-2015, 05:27 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I think this might be your answer, from Harbor Freight…
If you've got someplace to attach a sling swivel, you can use the hoist to lift the Segway into and out of the pickup bed, then fold away the hoist and pull the Rollbak cover over it.
Old 02-17-2015, 07:13 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Saw this in Trailer Life...it's a hitch rack with a support wheel(s) to support the weight.
The ultimate single wheel trailer system.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-18-2015, 04:59 AM   #4
Tao
Tao's Avatar
2022 16' Basecamp
Took a while but I found the item:
1/2 Ton Capacity Pickup Truck Crane
Seems like an excellent solution IF it will fit in my truck bed. Will call Harbor Freight to get dimensions; height under truck bed side wall top lip, then measure to be sure it will fit.
Also need to make sure the Segway, laid flat, will let the RollBak to clear it and close. If so, the tailgate has a lock so it will also be a great way to secure the Segway from thief when traveling as compared to being in the open.
I've never seen anything like it in a truck bed.
Thanks!
Old 02-18-2015, 10:08 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Reckon where they got the '73-'86 GM pickup in the picture? Or is it a 30 year old pic?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-18-2015, 04:00 PM   #6
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Yeah, I noticed that too. Owned a '73 3/4T 2WD with a compound low stump-puller 4-speed manual. Plain-jane truck, strong as a thousand camels in the courtyard.
Modern trucks are built of sheet metal that's a lot thinner, and I'd worry about stressing the bed without a stout backing plate. Wonder if it comes with one...
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 02-18-2015, 08:42 PM   #7
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
Maybe a front mounted receiver on your TV could solve the problem. I have hauled bicycles this way.
jfowler218 is offline   Reply With Quote
Old 02-20-2015, 08:35 AM   #8
beerrun'r's Avatar
2013 25' Flying Cloud
ARTHUR , Illinois
I've hauled my X2 with me for several years in the bed of my F150 super crew. I use 2 2"x6" boards for ramps. By starting up the Segway and running it by hand (I do not ride it up into the bed, IOW) it loads and unloads itself with its own power. All I do is guide it. I stow the two boards in the slots in the sidewall of the bed where they also serve as a barrier to keep my tool box and generator from sliding forward. (Side note: my X2 is for sale if you need another one)
beerrun'r is offline   Reply With Quote
Old 02-21-2015, 07:12 AM   #9
Tao
Tao's Avatar
2022 16' Basecamp
That's certainly the simplest. Assume you walked up the boards behind the Seg?
I went to Harbor Freight yesterday and noted they had a nice selection of ramps that seem to be secure to ground and truck tailgate - afraid a board might slip?
Old 02-22-2015, 06:29 PM   #10
beerrun'r's Avatar
ARTHUR , Illinois
No! I'm no thrill rider! I stand on the ground holding the Segway's handlebar in my hand and "walk" it up the boards, using the Segway's power, til it's on the tailgate where I switch it off with my Bluetooth controller, lay it down and roll it forward into its transport position. The ramp is pretty steep from level ground. The boards are only as long as the width of the bed. Too short and steep to walk on. To unload, I stand on the ground, pull the Segway out on the tailgate, stand it up, turn it on then tap the footrest with my hand to start it up, then merely guide it up onto the boards (they are 2" boards so there's a little threshold to overcome) and just hold the handlebar back enough to break its forward motion and let it "walk" itself down.
About board slippage.......I drilled a small hole in the boards at the tailgate end and into the tailgate lip for a nail (8p). I just slip the hail in and the boards stay put nicely.
Old 04-14-2023, 12:00 PM   #11
Cave creek , Arizona
Segvator
Hi Folks,
Jack
Am curious as to what you ended up doing with your Segvator?
Jdenaro is offline   Reply With Quote
Airstream Intl' Ocean Breeze 27' FB :: 2009 Airstream International Ocean Breeze geogeczy3 Airstream Registry Discussions 0 07-04-2014 11:14 AM
New to Forum and own a '68? Sovereign Intl Land Yacht ? Bart_I308J 1965-1969 Sovereign 28 12-24-2011 05:54 PM
Segway? Motorcycle? Foiled Again Off Topic Forum 170 10-17-2008 12:43 AM
2008 Intl Signature with Classic Shades and Drapes Bambi_Bandit 2006 - 2010 International 4 08-15-2007 07:15 PM
Airstream Caravel with Intl Scout Image sunnyhillfarm 1956 - 1965 Caravel 9 11-05-2006 06:33 PM
