Old 05-05-2016, 09:51 AM   #1
2016 30' Classic
Pascagoula , Mississippi
Securing
Just bought a 2016 Airstream Classic. Does anyone know how I can lock the propane tank container and the battery box on the front hitch?
Brannch is offline   Reply With Quote
Old 05-05-2016, 10:18 AM   #2
2016 23' International
Salem , Oregon
The hold down for the propane is a large wing nut. You can drill a hole through this and use a regular pad lock.
On the battery box you might be able to replace the turn type closure with a keyed one from a hardware store or drill a hole on either side of the battery box for small padlocks.
If the thief wants it they will figure a way.
Dave
NoResults is online now   Reply With Quote
Old 05-06-2016, 07:12 AM   #3
2016 30' Classic
Thanks so much for the info. I'll give it a try.
Old 05-11-2016, 12:56 PM   #4
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Our 2008 Classic came with the dual locking battery boxes.
Never thought about securing the tanks, tho.
Now that you mention it, might be a good idea... just to keep folks honest.
I think a cable lock thru the LP tank handles then down around the A-frame should work.
boondockdad is offline   Reply With Quote
Old 05-11-2016, 01:41 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
It would be unwise to lock the lid of the propane box since that would prevent rapid access to the valves in the event of a fire or leak.
There isn't much clearance between the wing nut and the cover.
I would suggest a lightweight cable lock through the handle openings in the top part of the tank, and around the frame. And good insurance...
Old 05-11-2016, 02:41 PM   #6
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I drilled a hole in the handle on the propane tank, thru the bracket and put in a padlock. The battery box is simply a piece of hardware. I bought a replacement locking one at Home Depot along with one for the refrige door as I have a self actuating fire extinguisher in there.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-11-2016, 03:00 PM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
All good suggestions for securing the propane tanks.
I have never run across anyone who has ever reported a stolen propane tank, nor have I ever heard of anyone on the Forum having their tank stolen.
Have any of you ever had your tank(s) stolen?
Bob Martel
WBCCI# 5766
Securing CCD Sliding Doors bhunt 2002 - 2005 International 18 01-13-2008 04:09 PM
Securing Coleman A/C Shroud Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-08-2005 07:59 AM
Securing Aluminum Tanks flyfshr LP Gas, Piping, Tanks & Regulators 15 07-18-2004 01:47 PM
Securing the floor whistler Repairing/Replacing Floor &/or Frame 21 05-02-2004 06:55 AM
Securing your tow vehicle ipso_facto Tow Vehicles 6 10-02-2003 03:40 PM
