Old 01-25-2015, 12:21 PM   #99
chriscraw's Avatar
1991 35' Airstream 350
What a terrific idea Peter..I think while I'm at it, I'll add a wireless circuit to our house door bell so that visitors can also enjoy the air horns!
Appreciated your kind summary of the 350LE's condition, quiet an endorsement of just how lucky an ill-informed buyer can be!
I'll follow-up on dannydimitt's suggestion Monday and let you know the result.
Chris
chriscraw is offline   Reply With Quote
Old 01-26-2015, 08:16 AM   #100
chriscraw's Avatar
Rear air bags and bushes
Originally Posted by dannydimitt View Post
Only one place in Austin that I would take it .
Atlas spring and alignment service
3535 East 7th Street, Austin, TX 78702
(512) 385-3661has been there for many many years. Good folks there.
Spoke with these folks this morning and got a sort of "maybe" depending on parts availably. do you have a scource for both the airbags and bushes, pins that will be needed ?
Old 01-26-2015, 08:43 AM   #101
chriscraw's Avatar
American Carrier
[QUOTE=Smartstream;1572274]I'm not sure exactly how the tandem axle air suspension is set up but I had a similar problem on my 280 and it was a pretty simple fix. Mine is an American Carrier system and they had the bushings for about $65 and the cross pins and "dog bone" link if needed. It took an hour or two to change if I remember correctly. The air bags may take a "set" from being run like that for some time. Turning one bag 180 degrees will help balance them or you can replace them if they are aged and cracked.[/QUOTE
Did you locate a source for American Carrier parts..also any idea where to obtain rear airbag replacements ?
chris
Old 01-26-2015, 12:26 PM   #102
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
[QUOTE=chriscraw;1572962]
chris
ACE is in Calif. American Carrier Equipment Trailer Sales, LLC - Contact American Carrier Equipment Trailer Sales, LLC
Air bags at Leaf Springs, Helper Springs and Suspension Parts | SD Truck Springs
SD Truck Spring has a great guide on identifying you air bags. http://www.sdtrucksprings.com/identi...ir-ride-spring
Cheers, Dan
~ Margaret Thatcher ~
Old 01-27-2015, 11:33 AM   #103
chriscraw's Avatar
Had an interesting morning with the Austin Travis County Tax Office (these folks register and title RV's inthis County)
After convincing them that the vehicle was not a "travel trailer" they admitted limited knowledge on registering motorhomes (guess Dealers do the heavy lifting for customers?)
Finally they worked-out that the 350LE, although an Airstream, was indeed, not a travel trailer (the supervisor gave a detailed description of the difference which was certainly enjoyable!)
But no cigar! As none of the documentation listed a vehicle weight, they now insist that I obtain a "weight slip" before they will issue a Texas title!
I protested that I had the manufacturers spec, wasn't that sufficient.? But no. Anyone know a way around this conumdrum or am I going to have to cruise I35 loking for a truck weigh scale ?
Old 01-27-2015, 11:36 AM   #104
chriscraw's Avatar
Dan..did you get my thanks for the links..if not, thanks again for the airbag and bush info..also got a link to master cylinder replacement..time to talk to Mrs. Banker for funding!
chris
Old 01-27-2015, 05:59 PM   #105
wxbuoy's Avatar
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Google CAT scales. Most truck stops (love's, Pilot, Flying J etc) have them. It cost $10 for the first weight and a few dollars for each subsequent weight with in a few days. So you can get a empty and loaded weight.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 01-27-2015, 06:03 PM   #106
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
When posting about what to expect from the tax office while you were on the road , I was thinking that a Cat Scale weight ticket would have been easy to obtain at a truck stop along the way . Most scrap iron recyclers have truck scales as do the two big garbage dumps in Austin . Ya might call and see if they will let you get a weight ticket from them .
When the wife and I drove up to northern Illinois and bought our 2005 AS we stopped at a cat scale in north Texas and got a weight slip on the way home .
dannydimitt is offline   Reply With Quote
Old 01-28-2015, 11:20 AM   #107
chriscraw's Avatar
Dave and Danny..thanks for the CAT/Truck Stop/etc info. Next step is to get the rear-end redone and then worry about getting the RV "Texas Titled"
chris
Old 01-28-2015, 02:45 PM   #108
2004 28' Classic
austin , Texas
We recently tried to get a license plate for our Airstream( a 28 foot trailer, purchased with a Missouri tag). We were told by Travis County that we had to go get it inspected! Like a car! Nothing was said about weighing it though. Wonder if that will come next.
Ntex is offline   Reply With Quote
Old 01-28-2015, 02:47 PM   #109
2004 28' Classic
austin , Texas
And by the way, when you find scales near Austin please post. We went all the way down to Seguin where there are a couple of truck stops along I-10 with scales when we wanted to weigh our Yukon. Surely there is something closer and we would like to know about it.
Old 01-28-2015, 02:48 PM   #110
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
chris
Remember you'll pay a penalty if they know you took longer than 30 days to get it titled.
— David
Old 01-28-2015, 06:31 PM   #111
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
If there is no sales date on the title , it will not be a problem .
Old 01-28-2015, 07:19 PM   #112
DKB_SATX's Avatar
1976 Argosy 28
Hence my choice of words. "If they know"
— David
new member owner 1991 350Le wheeler134 Classic Motorhomes 6 01-31-2015 05:18 PM
91 350le waterpump not working jerry220ver Water Heaters, Filters & Pumps 4 11-22-2006 04:41 PM
Looking at a 1991 350LE dssauburn Trailer Values 24 11-19-2006 07:32 PM
Help!! Austin-to-LA-to-Austin Astro On The Road... 13 04-05-2006 10:29 PM
