Old 01-16-2015, 07:56 PM   #71
chriscraw's Avatar
1991 35' Airstream 350
At 4335 feet here at Deming, NM. Tonight, the temp is to go down to 25F so's just as well I've got plenty of LP in reserve so will be snug in the 'ol 350LE bedchamber!
Today covered some 400 miles from Kingman AZ.....quiet a drive!
Tomorrow will drive to Fort Stockton and on Sunday home to Austin..Yea!
The 350 wanders all over the road due to slack in the steering components, brakes require the leg strength of a Russian weight lifter and I don't have a filling left in my teeth from all the banging around...this thing is sprung like a stagecoach!
Having said all of that, she is a worthy beast and with nostrils flared, is heading for home.
Chris
chriscraw is offline   Reply With Quote
Old 01-16-2015, 08:16 PM   #72
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Chris
Funny...
She knows you and you know her, that's established by now
<<Making notes to tell Chris about "steer safe system" and checking front airbags>>
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 01-16-2015, 08:16 PM   #73
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Glad you are making progress!! The description of your mechanical woes tells me that 1) your front airbags are not inflated and 2) quite possibly your hydro-vac or brake booster is on the fritz.
Keep coming, you are almost home!
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 01-16-2015, 10:16 PM   #74
1989 34.5' Airstream 345
Ebro , Fla Panhandle
"Flared nostrils ". Love it Chris!
Might be able to tune some of the steering play out with an adjustment at the steering box. I dialed out about three inches of play at the steering wheel this way, much better.
You are on a roll now, be light with the whip hand.
Cheers Richard
tevake is offline   Reply With Quote
Old 01-16-2015, 10:58 PM   #75
It takes very little to adjust the steering box. One box end wrench, and one Allen wrench. I can't recall the sizes but easy to check for size. In front of and inside of the drivers side wheel. You will find the steering box. On the side of it there is a lock nut holding the adjustment bolt. You insert the correct size Allen wrench and with the box wrench you ease off on the lock nut while holding the bolt in place with the Allen wrench. Once the bolt can turn you turn it one half turn clockwise. Then snug the lock nut while you go check the play at the wheel.
This should take a lot of the play out. If it still has play, repete with one quarter turns till the play is mostly gone. Then tighten the lock nut while holding the bolt in position with the Allen wrench. Don't want to over adjust.
If there is a grinding feeling in the wheel, you went too far, got to back off a little. 1/4 turn at a time.
This may sound complicated but once you get the tools in hand it takes about 15 min. Max.
I did this in the sellers driveway when I got mine and he was blown away. And kicking himself for driving thousands of miles sawing away on the wheel..
It will probably take you less time to do the adjustment that it took me to type this.
Hope this helps.
Happy travels
Richard
Old 01-17-2015, 05:07 AM   #76
wxbuoy's Avatar
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Originally Posted by PeterH-Airstreamer View Post
Funny...
Good to hear, I was about to do the same thing. Proper inflation of the front bags will make a world of difference on the remainder of the ride home. I will scan my paper work from super steer so he knows what to ask for. I did most of the components available.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 01-17-2015, 06:36 AM   #77
The fill valves for he front bags are on the front bumper, near the center. They take 55 lbs, if I remember correctly.
A couple of small fixes should transform the rest of your trip in a good way.
You will be heading down into lower elevation and slightly warmer temps today. Yea!
Happy trails
Old 01-17-2015, 06:19 PM   #78
chriscraw's Avatar
OK...tonight in lovely downtown Ozona Texas in the middle of oil biz it seems judging by the rigs all parked besides me in a really awful RV park called "Economy RV"...get this, $35 to hook-up, no shower or toilet so had to use duck tape to join my no- fit dump hose to the Tethford Airstream fitting.....sort of works for grey water dump only which is all I need tonight.
Other notes:
bwoodstx, thanks for the comments re steering and brake booster...see also posting from teakettle re steering adjustment. PeterH is making copious notes for our get-together in Austin.Won't hassle with the air bag pressure but seems to be the problem along with steering box adjustment, thanks also to WXbouy for his input. Right now, my main focus is getting the old 350LE home to Austin in one piece.
Leaving Ozona early tomorrow, I10 then on to 290 and home by early afternoon. Hope we will all meet at some time, just to reminise and have a laugh. I plan to have the 350 at both the Spring and December get togethers!
I will make a final posting on this thread once safely in the driveway! Thanks again to each and every one of you fine Airstreamers!!
Old 01-17-2015, 07:02 PM   #79
wxbuoy's Avatar
....... I plan to have the 350 at both the Spring and December get together!.......
Which would those be??
Dave and Felicia
Old 01-17-2015, 08:52 PM   #80
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
There is a spring rally in Johnson City, Tx April 10-12 and aBlanco Christmas Rally in Blanco, Tx December 11-13, 2015.
Bruce
Old 01-19-2015, 09:38 AM   #81
chriscraw's Avatar
Made it!!!!
Arrived in Austin at 1pm local time. will post a reckoning of miles travelled, gas guzzled and food consumed in the next few weeks. Immediately, I'm getting together with PeterH next weekend to go over a list of "must doos" (steering box adjustment, air bags, dump connector etc. etc.) and "nice to doos" ( solve engine over heating problem before spring, replace globes, get registered, roadworthy etc.)but in any event, the 350LE is a grand old lady in any measure.
Finally, my very real thanks to each of you for being there over the 2500 miles. At some future date, I'll publish a sort of summary of the trip for the benefit of any other idiot who might plan such an adventure! Vene, Vidi, Vici!
Old 01-19-2015, 09:48 AM   #82
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Just remember, in Texas you have 30 days to change over a title, if you have one, or you will pay a hefty penalty.
Bruce
Old 01-19-2015, 04:51 PM   #83
chriscraw's Avatar
Bruce..not sure if my Thanks worked but just in case..don't I need a roadworthy certificate before I can change title ?
Thanks for making me one of you very select friends!
chris
Old 01-19-2015, 05:06 PM   #84
chriscraw's Avatar
Dave and Felicia..is this the adaptor I need to get from the Thetford fitting to the standard dump hose ? Thanks
chris
http://www.amazon.com/Valterra-T05-2.../dp/B0006N5S6C
new member owner 1991 350Le wheeler134 Classic Motorhomes 6 01-31-2015 05:18 PM
91 350le waterpump not working jerry220ver Water Heaters, Filters & Pumps 4 11-22-2006 04:41 PM
Looking at a 1991 350LE dssauburn Trailer Values 24 11-19-2006 07:32 PM
Help!! Austin-to-LA-to-Austin Astro On The Road... 13 04-05-2006 10:29 PM
