Old 04-03-2014, 11:58 PM   #1
Reno , Nevada
Smile Schwai
Can my 03 ford 150 tow a 1978 31' airstream.
Keith Schwai is offline   Reply With Quote
Old 04-04-2014, 05:01 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Most likely it can.
5.4?
Which gear ratio?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-05-2014, 08:20 AM   #3
Reno , Nevada
K schwai
I have 378's gear ratio. I also have the 5.4 motor.
Thanks.
Old 04-05-2014, 08:41 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
The info I've got indicates that your rig weighs in dry at around 4,800. That's not that much more than our 67, which weighs in dry at 4,650, and which we tow in the mountains at elevation with an F150 with the smaller V8. You'll probably be ok, depending in part on how much stuff you decide to carry along. Be sure to use adequate weight distribution and sway control.
Check this thread, to which I posted a PDF with weights, etc.
http://www.airforums.com/forums/f238...nd-111359.html
Lynn
WBCCI 21043
