Old 08-20-2014, 11:08 AM   #85
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by mojo View Post
The bathroom scale method gives you an estimate of hitch weight but is not the most stable set up and weights can be off by 200 lbs by weighing at the jack stand as opposed to the coupler at the ball. A sherline hitch scale can provide better accuracy. Plus a 200lb difference may negate some of the confusion about true hitch weight and all the referrals to published GCVW and hitch weights discussed on the forums.
Can I borrow your scale?
MICHAEL
Old 08-20-2014, 11:15 AM   #86
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by Birdmaestro View Post
Mojo...
Inaccurate by 200 pounds would make weighing by bathroom scale worthless. How could AS recommend it? Where did you get your information?
Poppy
Oddly enough, some quick math shows if you had 200lbs to Airstreams published numbers for their hitch weights, you end up with numbers closer to what people have shared as their empty trailer hitch weight.
Maybe that's why the promote it. So they can claim their hitches are lite?
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-20-2014, 12:39 PM   #87
Wise Elder
Jammer's Avatar
2010 30' Classic
Well let's summarize.
http://www.airforums.com/forums/f48/...ay-124057.html - car following the Airstream collided with it, causing loss of control.
http://www.airforums.com/forums/f161...ml#post1313059 - Loss of control with no known cause, possibly due to tire failure. Reese dual cam
http://www.airforums.com/forums/f351...nce-28912.html - Loss of control on downhill grade, possibly due to partial or complete failure of the trailer brakes.
https://groups.google.com/forum/?hl=...o/oxLV0n3tvggJ - sudden lane change to avoid another vehicle leads to loss of control. Reese dual cam
Nelson: Airstream vs. School Bus – No Injuries | Blue Ridge Life Magazine : - not enough data to draw any conclusions
Saw A Trailer Sway Then Roll Over Today. (Not A Casita&#33 - The Casita Club Forum - The Casita Club Forums - loss of control accident, not enough data to conclude anything more
http://3.bp.blogspot.com/-K3WIFeLo5x...0/IMG_2391.JPG - loss of control under winter conditions, road surface may have had slippery spots. Conventional WD hitch, unclear whether sway control was used
http://www.airforums.com/forums/f464...tch-82925.html - loss of control accident, cause unclear - Hensley hitch
http://www.airforums.com/forums/f42/...ime-46232.html - collision from police SUV with lights on that was, apparently, not being driven in a safe manner.
http://www.airforums.com/forums/f42/...one-27195.html - loss of control due to icy road
I can't draw any conclusions from that. Maybe someone else can.
I will observe that, to the extent we can determine, WD hitches were present in all the crashes, and none appear to involve overmatched tow vehicles.
Old 08-20-2014, 01:28 PM   #88
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Mojo...
Poppy
By weighing at the hitch coupler and the jack stand with the Sherline scale. 200 lbs difference.
This is why crunching numbers relying on published weights and limits are worthless unless you go to a truck scale and weigh YOUR trailer and TV under all configurations. Only then will you know what's safe.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 08-20-2014, 01:29 PM   #89
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Someone sent me the following PM:
The number one problem I see with the "discussion" of this whole subject is that it cannot in any meaningful way address the "most important" aspect of accident avoidance, and that is....driver skill.
I'm not sure it's the most important. According to Inland Andy improper setup is responsible for 2/3 to 3/4 of all accidents (no doubt often compounded by lack of driver skill). So that seems pretty important also. And there has been discussion here about driver skills - the proper way to respond to a sway and to practice the proper way to practice the proper response to a sway for example.
It can get depressing reading about all these mishaps. I hadn't realized there were so many. I might not become a better driver as a result of what I learn here, but it's motivated me to try.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 08-20-2014, 01:33 PM   #90
AWCHIEF's Avatar
Images: 33
Not discounting research done in the past, but it would be nice to see some info based on current suspension and WD systems technology. The new automatic Air Suspensions and WD systems are a far cry from those used 20 or 30 years ago.
MICHAEL
Old 08-20-2014, 03:34 PM   #91
Nomadic , USA
Poppy
Wow, well that settles it with that bold claim. Who can argue with the solid facts and research.
Old 08-20-2014, 03:56 PM   #92
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Safety: Learning from Incidents, Accidents & Crashes
Pretty much, when we are talking about "single vehicle" towing accidents, apart from sudden equipment failure, all accidents are a result of driver error.
This is true whether the tow vehicle is over size or under size, whether a state of the art hitch is used or the trailer is towed on the ball.
Whatever the limitations of the vehicle, it is the job of the driver to know these limitations and to drive accordingly.
Even so, there will be accidents, and even good drivers are subject to error.
Old 08-20-2014, 04:52 PM   #93
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Now I know that Millennials have a penchant for irony. As a old guy I'm not quite sure how to take your comment.
Poppy
John & Vicki
WBCCI #4291
Old 08-20-2014, 10:57 PM   #94
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, as much as a certain person claims that air bags are a big no no, my 2000 Lincoln Navigator came from the factory with rear air suspension. It also came with the factory tow package and the owner's manual tells you how to set up a WD hitch with this vehicle. I think I'll trust the Ford engineers. [well I have for about nine years now] Maybe that one year only 1958 Ford air suspension wasn't too hot.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-21-2014, 06:18 AM   #95
Gainesville , Florida
If you get a Hensley so you can tow faster, aren't you partially negating the advantages as far as safety is concerned? Ideally, I believe, would be a Hensley and a speed of less than 65 mph. Jim
Old 08-21-2014, 07:57 AM   #96
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
It has been said already in this thread that there are usually several contributing factors to most incidents. If you remove any one of the factors proactively, the probability of a mishap decreases.
With today's tow vehicles, it's easy to tow at 65+ mph (105+ kmh) but the forces at work when things go wrong have remained unchanged over the years. Physics is physics...
The simplest factor that is under the driver's control is speed. Check this out:
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 08-21-2014, 08:24 AM   #97
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Just for context,,,,, traveling at 45 mph the car will stop faster still....
And at 20mph even safer.
In a model T 20 MPH is fast enough, and 45 MPH is scary fast....
A reasonable speed is different whether in traffic or on a rural interstate. Assuming a stable rig, there are times when 50 is too fast, and imho there are times when 60 is too slow.
By the way,,, Regarding the video, I contend that I had been in the place of either car in a car with good non antilock brakes, my car would not have hit the trailer.....
Old 08-21-2014, 08:46 AM   #98
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
That V squared thing is a bitch. Fortunately I think most here use common sense in determining how fast they drive.
For me one of the biggest challenges when it comes to speed is traffic flow. I agree that it's safest to stay in the flow (which for me when I'm towing is the lane flowing the slowest) as opposed to being an impediment. Slow drivers on the track are often referred to as a "moving chicane" and it can create a real hazard.
But it can be scary being in the flow...
A couple of years ago I was driving a very capable Porsche, one that I had driven on the track a couple of weeks before, on one of the freeways around San Francisco. The road had perhaps 5-6 lanes and I was in the second to the inside lane and going along with the flow. The road was in disrepair, as many of the highways are in California, and very bumpy, but that didn't seem to discourage anyone. I glanced at my speedometer and the flow was 85mph.
It seemed frantic to me and I was paying attention - I had felt safer on the track. We came to a large sweeper and no one slowed down. The inside lane was going significantly faster, must have been 90mph+. As the thundering herd swept around to the right the car passing me on the left came into view. It was being driven by a young girl who was bending over to look into her rearview mirror while she applied eye makeup.
What'd ya gonna to do?
Poppy
John & Vicki
WBCCI #4291
2006 Safari Dometic RM2551... Crashes Ray Eklund Refrigerators 3 08-08-2008 02:01 PM
Lighning crashes tin can luv Our Community 2 04-30-2004 06:28 PM
Airstream pulled by Expedition crashes... qqq Our Community 13 07-01-2003 01:32 PM
