Old 02-18-2019, 05:47 PM   #1
2017 19' International
Tallahassee , Florida
Safety flares, or ...
What do people carry or recommend for when things go wrong and you have to pull over (such as a flat).
What do you use to warn other drivers — safety flares or something else?
I don't carry anything, but I'm thinking I need to fix that.
WhereStream is offline   Reply With Quote
Old 02-18-2019, 06:15 PM   #2
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Got a set of battery powered flares. The pyrotecnic type age out and require disposal. The battery type just need a power refresh. It's not quite that simple, but represents the logic with which I proceeded.
Reflector triangles are a good night time alternative. Use your emergency flashers.
Following to see if others have a better idea. Thanks for asking. Pat
PKI is online now   Reply With Quote
Old 02-18-2019, 06:17 PM   #3
2017 23' International
hendersonville , North Carolina
Safety triangles
Go to any truck stop and pick up a set of reflective Triangles. They will be in a red plastic box about 18" long. It will contain 3 triangles. If you break down place the first triangle 10' behind vehicle, walk back another 30/40' and place #2, another 30/40 feet for #3. I have 20 years driving Class 8 trucks. Safety flares are required equipment.
uraljohn is offline   Reply With Quote
Old 02-18-2019, 07:02 PM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I have and use flares
Dept of “OverKill”
Old 02-19-2019, 10:05 AM   #5
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
Bought mine at Pep Boys. Always have them and many states require them.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 02-19-2019, 10:18 AM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I carry railroad fuses, as well as turbo flares.
AtomicNo13 is online now   Reply With Quote
Old 02-19-2019, 10:27 AM   #7
Railroad fuses .... ????
Old 02-19-2019, 10:30 AM   #8
harryk's Avatar
2005 31' Classic
Venice , Florida
When I had a flat on my truck along the Interstate in Texas, I used the triangle reflectors and the trucks seemed to take pleasure in running them over. Now I carry flares with a metal rod in the bottom (Nail ? )to stand them up. Guess what ? They seem to want to avoid them at all cost.
harryk is offline   Reply With Quote
Old 02-19-2019, 10:33 AM   #9
PKI
PKI's Avatar
Wow - Always learn something when the investigation hat gets used. Have considered flares appropriate, but never thought they were a requirement for private vehicles and RVs. So I pulled up DIYRV and they had a list. We have only seen towing speed limits in CA, but their list has a bunch of states with towing speed limits. Texas and Illinois are even included. Now I need to do some more research on what is required for flares and reflectors as well as if the DIYRV is accurate about speed limits. Wow - Pat
http://www.doityourselfrv.com/state-towing-speeds/
Old 02-19-2019, 10:57 AM   #10
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Yeh, there are a lot of safety laws no one knows about, especially when traveling out of state. We have some triangles and red cones, but never have used them. Do anything you can to get as far from the road as possible—that’s more important.
I recall when we were in Minnesota some years ago a cop was being prosecuted for not putting out safety warning stuff. Something bad happened and she was in lots of trouble. Of course, cops are supposed to know those laws and set a good example. I have noticed that every year one or two cops are injured in Colorado when walking to and from their car to something along the edge of the highway. One of my great fears is having to change a tire at the edge of the road. I’d rather ruin a tire limping along to a wide spot.
Gene
Old 02-19-2019, 11:05 AM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Railroad fuses are bigger brighter and burn longer.
Nothing special other than super sized.
Bought a box of them 30 years ago, and still have more than a hundred!
Old 02-19-2019, 11:32 AM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We rarely travel at night with the trailer so we don't carry flares... We do have 2 boxes (3 each box) of the collapsable triangles...we have used them and they work well. They are weighted to stay in place while those small plastic orange cones are useless. They just get blown around by passing traffic. The larger cones are probably better, but then there is a storage issue.
TB & Greg and Abbey Schnauzer
#3954
Old 02-19-2019, 12:17 PM   #13
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
FWIW harbor freight has a cheap set of reflective triangles for like $5....
Old 02-19-2019, 02:11 PM   #14
1976 31' Sovereign
Oswego , Illinois
Railroad flares have a spike in bottom, if they are in traffic lane or left after use they are dangerous as they can and will rip side wall of tire and can cause blow outs. When lighting have to be careful as can cause severe burns also can cause fires. I was rr conductor for 36 yrs & have seen all these things plus a crew member was blinded and face scarred when held toward face when lighting. A county mountie placed in road when at accident then caused another accident when run over plus I have seen Il. state police place in road and leave them when burned out. I recommend battery warning lights and triangles, be cause average person does not no of these things that can happen, so be careful if using flares and pur. ones that don't have spikes.
featherbedder is online now   Reply With Quote
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
RV safety education foundation 83Excella Link Archive 5 10-15-2004 05:44 PM
Flares Pahaska On The Road... 0 01-02-2004 12:48 PM
Trailer tire safety article 83Excella Tires 0 08-14-2002 08:44 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
