Old 01-11-2014, 07:19 PM   #1
1999 19' Bambi
Friday Harbor , Washington
Running with the Fridge on
What do most people here do when you are physically traveling on the road. Is it Ok to run the propane fridge or can you switch to battery power while you are moving. I'm sure this topic is somewhere on this forum. I am new to the site and am not quite sure were it would be if it is here. Thanks for any help on this. This will only be my second trip.
SERENDIPITY1 is offline   Reply With Quote
Old 01-11-2014, 07:33 PM   #2
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
http://www.airforums.com/forums/f287...-on-94070.html
Welcome serendipity. Here's a link to a "fridge on while traveling" thread. There's plenty of opinions but we run with ours on and we fuel at commercial petroleum fuel stops in the diesel lanes so we don't worry too much about gasoline fumes igniting. If we are close to gasoline pumps or are heading through tunnels we shut down the propane. - Brad
SuperTrouper is offline   Reply With Quote
Old 01-11-2014, 07:57 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
We have always left our refrigerator running on LP gas while we are underway.
Brian
SuEllyn & Brian McCabe
Old 01-11-2014, 08:00 PM   #4
1986 31' Sovereign
Miami , Florida
Unless you have a three-way fridge (rare), your choices are to run it on propane or have it off. Your basic RV fridge has a very slow recovery once it warms up so most of us run with it on.
Most road tunnels require the propane be shut off and many folks will not fuel with the refrigerator on but both these interruptions are brief.
Enjoy the journey,
Mike
Old 01-11-2014, 10:21 PM   #5
aftermath's Avatar
Spokane , Washington
Read through the link provided by Super Trooper, it will provide you with a nice summary of the never ending debate.
I run with mine on. It is not against the law in Washington, Oregon, Idaho, Montana, South Dakota......... There are some places where they want you to turn the propane off like on the Washington Ferries and some tunnels back east but that is it as far as I know.
Some will turn them off when filling up at the gas station while others don't. As in most things, it is up to you.
aftermath is offline   Reply With Quote
Old 01-12-2014, 12:25 AM   #6
And New Jersey, as Dylan and the Traveling Wilburys sing in Tweeter and the Monkey Man ........."In Jersey anything's legal, as long as you don't get caught"
Old 01-12-2014, 12:48 AM   #7
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
We turned ours on the day we got it, and it has only rarely been off ever since. It switches back and forth b/t gas and 110. I am blessed with a nice covered carport to dock it at home with full hook ups so it goes to 110 and stays there. The fridge is usually well stocked, and we are on the road at least half of every month. so far, no problems.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 01-12-2014, 09:00 AM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have a wireless thermometer in mine. In our hot Texas summers, there is no way to keep food at a safe temperature without running with the propane on. In the last ten years, my propane has not been turned off except when going through the tunnel under Mobile Bay.
John W. Irwin
WBCCI #9632
Old 01-12-2014, 10:16 AM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We have a 2 way: propane and elec. We run with the propane on unless directed to shut it off as in long tunnels.
Kay
Old 01-12-2014, 11:22 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We keep the propane on except when fueling or if we are stopped for a long period of time in a location which isn't level.
As far as battery goes, while I don't know if the fridge in your Airstream has setting to use battery, I have experience with this when I used to tow a Hi-Lo. I had a true 3 way fridge and I used to run on battery when I towed. That power connection from your tow vehicle to the plug must have ample gauge wire to carry the necessary voltage to keep your battery charged. In addition any corrosion between the contacts on your receptacle on the tow vehicle and your trailers contact on the plug must be clean. I used to carry some contact cleaner and sprayed both prior to going on an outing. I must have experienced about 4 cases in 14 years of ownership of a dead trailer battery upon arriving at a campground. If you ever have had a Hi-Lo, you know that it is lifted by cables attached to a hydraulic ram that is powered by a 12 volt pump. Needless to say I remember sitting in a campground, plugged into the campground outlet waiting as the battery built up enough charge to raise the upper end of the trailer. After that incident I started carrying jumper cables. Interesting giving your trailer a jump.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-12-2014, 01:03 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We run with it on, and rarely turn it off ... pretty much only when we take it in for service and need to unload the frig completely.
TB & Greg and Abbey Schnauzer
#3954
Old 01-12-2014, 01:56 PM   #12
Santa Fe , New Mexico
Don't worry
You almost never need to turn off the propane. When re-fueling, just remember to stop at the first pump, even if the pump in front of that one is open. This means your trailer is always many feet from any possible gas fumes. After you fuel up, you drive past the pumps at a fast enough rate that nothing can happen.
I would never drive for hours down the highway with the refrigerator off. That's crazy.
mistermcfrug is offline   Reply With Quote
Old 01-12-2014, 02:29 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We also run with the propane on most of the time. If you just do not want to you can dedicate the freezer shelf to some blue ice to help keep it cool when driving.
Old 01-12-2014, 03:49 PM   #14
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
We run with the fridge off. I'm happy to concede that the risk of propane mishaps is minimal but, to steal a line from Airstream Inc., it's how we roll.
When we're on the driveway at home the fridge is always on using shore power. We load before a trip, switch off just as we leave and the fridge (and freezer) stay cold enough during a day's travel. We have hit the LPG switch when stopped for a long lunch and we have supplemented the cooling with a bag of ice occasionally, especially when heading south. Of course, if we stay up here north of Lake Erie then our cooling requirements are not in the same league as you guys who live closer to the Equator than we do.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
