Old 10-31-2008, 08:38 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Rotated your tires lately?
Today I stopped by AS of Spokane for a pre-trip inspection. A Funny thing happened. We found the left rear inside sidewall was separating. The tire was getting ready to come apart. It would have caused a lot of damage.
It was replaced with my Canadian made spare. Brake rotors, pads and never lube bearings were fine.
By the time I reach Florida my I will need my third set of tires for my trailer.
Michelle TAC MT-0
Sarah, Snowball
Old 10-31-2008, 09:04 PM   #2
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
It's a good thing you had an inspection, we always go over our unit thoroughly before hitting the road. We rotate our tires every 5000 miles. What kind of tires are you running? We used to run the Goodyear Marathons, had lots of troubles, switched to the Maxxis tires and have had much better luck.
1999 Airstream 34' Limited (The Cottage)
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
99Limited34 is offline   Reply With Quote
Old 10-31-2008, 09:07 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Are you saying that you will have replaced your tires 3 times by the time you reach Florida? Wow. How is it that on the old SOB's you find these old tires that have been on there for years and they seem to motor down the road and the Airstreams just eat up the tires? I guess its the weight or frequency of use or ?? Seems crazy though really.
Have a safe trip. Glad you spotted the bad one. Who needs a breakdown.. not a good feeling when you feel a flat tire and looking for a place to pull over knowing that tire tread is beating up your baby..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-01-2008, 05:39 PM   #4
Keymar , Maryland
Vinnie
I will have a fresh set (third) of tires when or before I arrive in Florida. I have 50,000 miles on my trailer in under three years. She is heavy, right around 9,000lbs. I usually do not wait for my tires to wear to the minimum. I want a little more tread left than that.
My truck is on its third set as well. 55,000 miles 10,000 GVW.
Michelle TAC MT-0
Sarah, Snowball
Old 11-01-2008, 05:40 PM   #5
Keymar , Maryland
I am running Marathons and probably will continue to do so. Maxxis tires are hard to find a dealer out here.
Michelle TAC MT-0
Sarah, Snowball
Old 11-01-2008, 06:20 PM   #6
moderator
Airslide's Avatar
Wilton , California
Images: 50
I guess i just have to get used to this. Im in the automotive field and i have customers yelling at me when they only get 30k out of a set of tires. I just changed all mine with Carlise's load range E. I will keep an eye on them but there is no way i will be towing 50k miles any time soon. Im lucky to get away on weekends. Sounds like you keeping a good eye on it and that will save grief down the road..
Old 11-01-2008, 10:15 PM   #7
Keymar , Maryland
Another thing the that was noticed was the tires were not inflated enough.
I had been running them at 65 PSI. THe maximum specified by Airstream. This turned out to be too low. We bumped them up to 70 PSI.
Michelle TAC MT-0
Sarah, Snowball
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
tires 78 Overlande Tires 13 01-10-2006 03:34 PM
How old are my tires? Chuck Tires 21 06-08-2004 10:07 PM
How old are my tires? Chuck Tires 6 12-27-2003 07:22 PM
Tires joel Tires 0 09-24-2003 09:46 PM
