01-31-2016, 04:49 PM
2016 23' Flying Cloud
Dallas
Refrigerator while moving
In the past, I have had 3way refrigerators that ran off of battery power while moving. What have any of you found is the best way to keep items cold with the two way? I do not want to run on propane while traveling. Thanks in advance.
Kittyfeet-
I hope this day to have the opportunity to help someone in need.
01-31-2016, 04:50 PM
Biloxi
, Mississippi
Propane while traveling, works great.
MICHAEL
01-31-2016, 04:52 PM
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent
, Oklahoma
I run my propane, and don't worry about it.
Have a blessed day !
TAC OK-5
01-31-2016, 05:05 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Assuming that you didn't want to be told "run the fridge on propane," there are a few other ways to deal with the situation.
1 - Don't even carry refrigerated/frozen foods in transit. Buy them at your destination. You can pick up regional specialties this way.
2 - Carry an ice chest and use either bagged ice or Blue Ice packs, or even dry ice for stuff that absolutely must stay frozen.
3 - Use a portable 12v fridge that plugs into a power outlet in the tow vehicle. Dometic makes several in different sizes (I have the smallest, to carry soft drinks within easy reach of the driver) but none as big as your trailer's fridge, of course.
One thing you probably won't be able to do is load up your fridge and then keep food cold in it without running the fridge. It's not insulated well enough for that.
01-31-2016, 06:03 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Your fridge will keep stuff cold enough for a few hours if left entirely off. A lot depends on how full it is (the more full the better, assuming the contents are at proper temperature to begin with) and the ambient air temperature (the lower the better, up to a point.) In 50 to 70 degree ambient air, you can easily go three to four hours with the fridge off. Test it and see. On the other hand, don't expect a lot of time if the outside air is in the 90's or higher.
Having said all of this, when we had an adsorption fridge, we ran it on propane while on the road (and turned it off at gas pumps.) We currently have a marine fridge with a Danfoss compressor (12 V only) and it runs all the time.
Bob Martel
WBCCI# 5766
01-31-2016, 06:28 PM
1998 30' Excella 1000
Livingston
In moderate air temperatures (fall, winter, spring) I regularly leave it off for a 5 hr drive and the temps stay in the safe zone in the fridge and my ice cream does not melt in the freezer. Gets a little soft though.
01-31-2016, 06:35 PM
From All Over
The best way to tell if the food in your freezer is still safe is this…
Freeze a small container of ice. A Jell-O pudding cup filled halfway with water and frozen is normally fine for this, but for a moving trailer you probably want a container wider than it is tall so it's less likely to tip over in transit. Place a coin on top of the ice. As long as the coin stays on top of the ice, then the ice hasn't thawed, and neither has the food. But if you ever see the coin inside the ice, you know that the ice has thawed and refrozen, and it's time to throw out the food.
This is a trick I learned from living in an area where people have to evacuate for hurricanes, and we need to know when we return whether anything we had to leave behind is still safe for consumption.
01-31-2016, 09:38 PM
Wise Elder
2010 30' Classic
South of the river
The best thing to do is run the fridge on propane. The risk of food poisoning from a warm fridge is real and is much greater than the theoretical risk of a fire from leaving the propane on, especially in hot weather.
Otherwise, use a thermometer, load and fully cool the fridge before travel, and you'll be mostly ok for a while if it's not too hot out.
01-31-2016, 11:20 PM
2015 28' International
Ofallon
, Missouri
We run our fridge on propane while driving.
Some good advice I got once though was to turn it off before fueling. You don't want an open flame around gas fumes.
02-01-2016, 12:02 AM
Salem
, Oregon
Hi, last year [2015] we went across this country. Over 13,000 miles and for 3 1/2 months. We turned our refrigerator off twice for a quick defrost only. Shore power at camp grounds, propane while traveling and at Walmart parking lots.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-01-2016, 06:36 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
02-01-2016, 06:53 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have always traveled with the Airstream's refrigerator powered by propane. We have been doing this for ten years now. We have 1,700 nights out in the Airstream and 140,000 miles of towing.
We rarely stay at a place more than two or three days. Restocking at each new location would very bothersome. Early on in our Airstreaming, we tried turning off the refrigerator while underway. It just didn't work for us.
We keep a very close eye on our LP system.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-01-2016, 07:00 AM
Dallas
Thanks everyone. Propane it is!!!
Kittyfeet-
02-01-2016, 07:31 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I've driven 500 mile days in 95+ degree midwest humidity with the fridge off. Never had any problems with freezer defrosting or warmth in the fridge. I do turn it on for about an hour mid-day when we take a lunch break.
Wondering why the need to keep the fridge running?
@living.somewhere.yonder | Instagram
02-01-2016, 07:42 AM
Mantua
, Ohio
Food poisoning and spoiled food.
02-01-2016, 08:07 AM
From All Over
Which is exactly why I described the "coin in the ice" trick for determining if thawing has occurred.
02-01-2016, 09:06 AM
2014 23' Flying Cloud
Fair Oaks
I've heard the risks of traveling with the fridge on, but never any examples of actual disasters. Even the dealer recommended traveling with it on during my orientation, except for specific times you are required to turn off the propane, such as on ferries, etc. So I always travel with it on.
02-01-2016, 09:15 AM
Wise Elder
2010 30' Classic
South of the river
I've tried to find evidence of actual problems and came up empty.
The closest I came was a hydrogen fire from a defective fridge while someone was under way in a motorhome. While turning off the propane would have prevented a fire in that particular place and time, it likely would have just postponed it until parked somewhere -- not any safer. No one was hurt.
Even accidents while refuelling don't seem to occur. The all-causes fires at gasoline pumps are in the single digits to low teens nationwide each year, with static electricity being blamed for most of them and cigarette smoking for most of the rest.
02-01-2016, 09:35 AM
From All Over
Most of the cautionary tales of imminent disaster from using propane while in transit ignore simple physics and chemistry, namely that the concentration of flammable vapors in the air (from propane, fuel pumps, whatever) must be in between the upper and lower explosive limits for a fire to occur. Obtaining a concentration of vapors in that range is difficult even at a fuel pump, because they're outdoors and any breeze at all will dissipate the vapors. Tunnels are a problem because they're mostly enclosed, and tunnels under a waterway are especially problematic because they have low spots where vapors can collect. Which is why many tunnels require you to turn off your propane.
The rest of the time, the only real issue is whether the slipstream of your rolling down the road will blow out the flame. This problem is more of a problem if you have a pilot light, because once the pilot light blows out, the fridge will not relight by itself. With a spark ignition, if the flame does blow out, it can restart itself.
02-01-2016, 10:04 AM
Normal
Ditto on running the frig on propane when traveling.
I used to be afraid of the propane, too, but got over it and common sense has prevented there ever being an issue.
You don't need food spoiling, nor the aggravation of dealing with a cooler. It is perfectly safe.
Have a great time!
Maggie
