Old 11-21-2006, 08:03 PM   #1
2000 34' Limited S/O
Jamestown , North Carolina
Recommendations for GPS!
I would appreciate experiences and recommendations for portable vechicle GPS systems!
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 11-21-2006, 08:20 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Use the Search...
There are several series of prior posts on the subject. Garmin versions seem to be gaining ground, but folks use everything from laptops in car to handhelds... FWIW we use Garmin C320 (uses memory card v C330 with hard disk) and only complaint is a little hard to read in bright sunlight when wearing sunglasses.. Also takes a while to search if you've installed large SD memory card.
Use search tab above for "gps" and "portable"..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 11-21-2006, 10:13 PM   #3
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
maybe check out this thread that is already going....
http://www.airforums.com/forum...gps-27916.html
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Ridgeland Miss camping recommendations? 10acKen On The Road... 2 05-10-2007 06:50 PM
Campground recommendations -Memphis, Nashville luckydc On The Road... 4 07-10-2006 01:44 PM
Drain Fitting conversion? Recommendations? Jabba Waste Systems, Tanks & Totes 3 07-11-2003 05:30 PM
shop recommendations in K.C. kc airstreamer Commercial Listings 0 05-18-2003 12:34 AM
de-humidifier recommendations dpope 2003 Safari 3 04-07-2003 03:08 PM
