Old 10-10-2018, 01:23 PM   #1
StreamingEagle's Avatar
2017 25' International
Chicago , Illinois
Lightbulb Quality and What's in your toolkit
I have seen conversations about Quality all over here for a long time, and someone pointed out of about ways to fix things. I agree that we shouldn't have to fix a lot of things, but for all those buying new rigs (and even those who have been on the road), what are the key items you bring with?
What items do you use on the inside of your trailer to keep doors attached, drawers back in place, etc..
2017 25' International Serenity
TV - 2018 Porsche Cayenne S
WBCCI #11337
StreamingEagle is offline   Reply With Quote
Old 10-10-2018, 02:08 PM   #2
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Great question!
Do you own/have you read Rich Luhr's book "The (Nearly) Complete Guide to Airstream Maintenance"? Along with his "The Newbies Guide..." you will find a lot of ideas for what to have with you. But it sure would be interesting to hear from the long timers/DIY'ers here on the forum!
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 10-10-2018, 07:59 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I love it when someone asks the Tool question...😂
.......a tool thread starts I have to post this.🤣
Tools explained.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans.. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-BITCH TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a BITCH!' at the top of your lungs. It is also, most often, the next tool that you will need.
“Side effects from the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 10-10-2018, 08:32 PM   #4
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
Key tools/items we use every trip are:
Viair 88P air compressor to air up the tires
small level for setup
gloves for keeping hands clean during hitching
something to open those window gaskets--we use a lodge pan scraper. others use a credit card
cushy kneeler mat for low point drains and fresh water tank drain
socket set to tighten tow mirrors and to drain water heater plug
Tools we have used during trips:
torque wrench for lug nuts and extension socket-check periodically
zip ties--used for failed water heater clip
duct tape -used for lose trim (bonus-color blends in well)
sticky velcro-used for vent hood flaps, hanging pictures inside
spray silicone, spray graphite-used for locks and window gaskets
Tools we carry just in case:
Bottle jack
breaker bar
spare pins for sway bars
spare clips for sway bars
silicone tape for leaks
tarp
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 10-10-2018, 08:45 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Start with stuff to fix a flat tire (jack and lug wrench) and basic tools anyone (should) already own (pliers, screwdrivers, etc).
The most important tool is cash/credit card, to get the thing you need when you need it.
Alan
Old 10-11-2018, 10:37 AM   #6
Ypsilanti , Michigan
Childproof
Take a look at Childproofing options for some of this. There are devices to keep cabinet doors from opening and keep drawers shut that can defeat a 2-year-old, and they will probably keep things shut for you.
Ahuka is offline   Reply With Quote
Old 10-11-2018, 10:49 AM   #7
2015 23' FB Flying Cloud
Redmond , Washington
You likely will receive many excellent recommendations on this forum as well as the Newbie Guide mentioned. My tool bag has been replaced with larger sizes three times in addition to tools that must be stowed separately (battery powered drill). The increased weight allows me to present to my wife the need for a new tow vehicle capable of the payload necessary to insure our safety and comfort while maintaining our Airstream investment.
I’ll add only one small, light weight, inexpensive item that I’ve used a few times on the road - a soldering iron (and solder).
A smart phone, and related charging tools, is perhaps the single best tool you can bring. You can search for repair instruction videos, parts stores, repair shops, and towing services. Or even put your rig up for sale on the very spot it is broken down. I also use my phone every stop to determine leveling. And the built-in flashlight is heloful. Finally, I have learned to ALWAYS take a “before” photo prior to disassembling or disconnecting anything.
It’s all part of the adventure. Repairs happen. Have fun!
WestieHouse is offline   Reply With Quote
Old 10-11-2018, 12:37 PM   #8
Mollysdad's Avatar
Speaking of doors attached, one of my best purchases was 40 of those little plastic gizmos for covering the hinge release on all the Euro hinges. I always seem to discover another hinge that's hidden away waiting to detach the door with the slightest bump.
My microwave is on a pull out drawer, and I heard folks have trouble with the drawer staying closed underway, so I made a 3/4" dowel about 26" long, put white crutch tips on it and wedge it between the drawer and the opposite wall.
BTW, my microwave has never opened accidentally under way. It does scoot around since it just sits on the shelf, so I found that plain old rubber door stops fit snugly between the back of the microwave and the lip of the shelf.
(Plan B is to use very firm black case foam to put in front and back so the drawer latch doesn't rub the side of the microwave.)
Old 10-11-2018, 01:10 PM   #9
2014 25' FB Eddie Bauer
Okemos , Michigan
this is a very good question. After purchasing a 25 new in 2014, it is now clear to me that being able to fix things is part of using the coach. It makes sense that things break on the road which is also when time is limited and repair shops are far. Beyond the annoying repairs, we have had:
A failed furnace - bad overheat thermostat
A failed fridge - also a bad overheat thermostat
A failed hood vent - connector behind wall not properly seated
A failed hood vent again - bad fuse body
A failed tail light - it just failed.
All of these needed to be fixed right away which I was able to do after some research and reading - thank goodness for this forum and the internet in general.
I think a good set of 12 Volt electrical connectors and tools along with an electrical mulit-meter are absolutely essential.
I am sure folks figure it out, but I do feel bad for owners who must rely exclusively on repair shops to keep things working. The risk of incompetence, delays, and expense tip the balance of fun on the wrong side of the scale for me.
Wanna EB is offline   Reply With Quote
Old 10-11-2018, 02:27 PM   #10
eagletoo's Avatar
2018 23' International
Long Island , NY
Tool List
Bob, your list had me roaring. Thank you.
Safe travels, wherever you're bound!
Bruce
2018 23CB International Serenity-“Rambler”
2018 Jeep Grand Cherokee 5.7 L Hemi with factory trailer towing package
Equal-i-zer Hitch
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 10-11-2018, 04:10 PM   #11
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by ROBERT CROSS View Post
.......a tool thread starts I have to post this.��
Tools explained.
Replacement glass pane for each of my 3 windows in the garage that the above tool breaks.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-11-2018, 05:42 PM   #12
2017 28' International
Baileys Harbor , Wisconsin
I just carry some basic tools (pliers, wire cutters, wire stripper, cresent wrenches, etc) with a few special tools for my Propride hitch. Then I have some extra hinges, extra latches, PVC pipe, PVC connectors, fuses, electric connectors. One thing I really use a lot is my 20V Delta Drill. Use it to raise the WD bars on Propride and putting up and down the stabilizers on the AS. Also definitely a 250lb torque wrench to torque hitch bolts and lugs. Also Gorilla tape and liquid wood is good. If a screw comes out and it doesn’t go back in tight a broken off match with some liquid wood works wonders.
Daquenzer is offline   Reply With Quote
Old 10-11-2018, 05:47 PM   #13
Where did you get the “little plastic gizmos.” Looks like a good idea.
Old 10-11-2018, 07:52 PM   #14
Mollysdad's Avatar
There's two sources I found. both sell the same thing and they're about $0.45 each, so I ordered 40, shipping was $13 which was a lot considering the package comes in an envelope.
But they're worth it.
https://www.woodworkerexpress.com/gr...tor-steel.html
or
https://www.baersupply.com/baer/wg-index.jsp
(Part # GFF072135807540)
See this thread on the Airstream forum for more details.
I can't take credit for the research, but I saved it.
How to use:
http://www.airforums.com/forums/f164...-175341-2.html
Scroll down to post #24, #25. (for images)
AS Quality? Your thoughts, is it worth it? Disillusioned Potential Buyer gonz Our Community 110 10-11-2018 11:14 AM
How to test your axles...and ruin your ramps. outofcontrol Axles 25 04-27-2015 12:27 PM
Is it okay to leave your refrigerator on when your are at home and not camping? Jeffg24 Refrigerators 22 10-14-2010 06:21 PM
quality of airstream and especially chassis in 70's and 80's turfclubroad Our Community 1 05-21-2009 07:37 AM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 09:04 PM
