Old 04-05-2015, 01:02 PM   #15
r carl's Avatar
Lin , Ne
I have read many posts here that you shouldn't even put a bicycle rack on an airstream bumper.
Old 04-05-2015, 06:47 PM   #16
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I've considered it to pull my DR650. It would be a job getting it right though. I'm sure it would handle my DR, but not the Goldwing.
My neighbor pulls doubles to constructions sites all over the ArkLaTex area without difficulty.
NavyCorpsman is offline   Reply With Quote
Old 04-05-2015, 10:17 PM   #17
2000 36' Land Yacht XC Diesel
Fresno , California
Now for my setup it would be a class A AS diesel pusher with my Hummer in tow 4 down. I already have an auxiliary braking system because my dinghy is 8000lbs or so. The question I can't find an exact answer to is could I then hook up a tag trailer to the Hummer? The way the hummer hooks up to the motorhome isn't actually a tag style. So when you back up you don't have to flip the wheel in reverse. I use a Roadmaster Falcoln 2 to hook up the Hummer.
I don't think even if it was legal that is actually attempt it as it seems sketchy and probably unsafe. On top of which now that I think of it my GWVR would be at double capacity. My 330hp Banks Power boosted, inter cooler added diesel pusher engine is just enough to tow the H2 anyways.
So its definitely just out of curiosity. Curiosity killed the cat. Satisfaction brought it back.
LucasS is offline   Reply With Quote
Old 04-05-2015, 11:01 PM   #18
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Originally Posted by Kiera View Post
Ok, I've done a little research but couldn't find anything solid.... I was just wondering if anyone has set their trailer up to tow an additional trailer behind it? I know the laws and what states it is allowed in, that is not my question. I just would like to be able to pull a very small aluminum motorcycle trailer with my bike, naturally. The trailer will be between 300-400 lbs n the bike is about 650 lbs.
Has anyone set their trailer up to do anything like this? What did you do to "beef" it up?
Thanks!
1975 Sovereign - NO NO NO - very bad years for rear end separation (not that any are bulletproof).
I may have my 2012 Eddie Bauer up for sale in the not too distant future. Just put the Motorcycle INSIDE via the rear hatch. Of course this would be best for a light weight - dirt bike or Vespa or something else equivalent. Wouldn't advise a big Hog or Gold Wing.
Paula
Old 06-11-2015, 10:24 AM   #19
1975 Argosy 26
Cantley , Quebec
Rear Hitch installed Argosy 26 ft
I have an Airstream Argosy 26 ft that I am rebuilding from ground up. I sandblasted the frame and rebuild it. In the rebuiding process I removed the rear bumper that was welded to the frame. I inserted in each longitudinal frame, C chanel, a square tubing (1'' x 3'' 3/16 think) from the bumper to the rear axle that I welded. Between these two 1'' x 3'' I welded as under bumber frame a 2'' x 4'' 3/16 square tubing where my class 1 hitch in welded. Over this 2'' x 4'' I rewelded the original bumper to hided the job. Everything look original except the small class 1 hitch.
I also plan to extend the axle plate, the one suporting the axle, to the rear to beefup the frame stifeness.
I will upload some picture as soon as I figure out how.
Manrique is offline   Reply With Quote
Old 06-11-2015, 02:15 PM   #20
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by lewster View Post
Not sure about the legality of double towing 2 trailers. I'm sure some states will allow it but I have never seen it done in my cross-country travels each year.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-11-2015, 02:26 PM   #21
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Double tow in Texas is only behind a 5er/GN trailer. And not a good idea. At all.
Old 06-11-2015, 03:02 PM   #22
halftimer's Avatar
irving , Texas
Could you not fish plate the rear frame of the air stream like they do concrete mixer truck and other heady duty and that take care of separation. In my dp the dw said we look like acircus coming to town. 40 foot dp extended cab pickup and twenty foot boat right at 75 feet yes I know 65 the limit but have bee stop by highwY patrol strap dragging nothing said about length.was at the lake once guy came in crew can dually pulling big 5th wheel towing pontoon boat back it tight into over flow parking spot. Just have to back slow
halftimer is offline   Reply With Quote
Old 06-11-2015, 03:34 PM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
For purposes of this discussion, an Airstream doesn't have a frame.
Old 06-12-2015, 08:08 AM   #24
halftimer's Avatar
irving , Texas
Did not know that.
Old 06-12-2015, 07:16 PM   #25
1975 Argosy 26
Cantley , Quebec
framed or not framed
Airstream trailer are build on a thin frame and yes it's a frame under the floor. The frame itself due to its thin gage can't sustain a lot of stress. The design of an airstream can be classified as a semi monocoque or semi unibody design category. The integrity of the shell and the frame form a rigid assembly that can sustain much more stress then the sum of each of them separatelly. The problem in towing behind (double tow) is with the rear separation due to the aft frame flexion. This 'problem' can be mitigated with reinforcing the frame behind the aft axle as well as the rear attachment between the rear of the shell to the frame.
This explanation are from myself as a Mechanical/Aerospace Engineer
Excuse my bad english, this is my second language.
Old 06-16-2015, 08:55 AM   #26
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
With respect, rebuilding the trailer is not any kind of "solution". Which is why I wrote that for purposes of this discussion that A/S does not have a frame
In other words, the desire to double tow is not possible in a realistic sense.
Old 06-16-2015, 10:14 AM   #27
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
What about something like this? You could put the Airstream in the back and not have to worry about it's small frame.
Cheers,
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 06-16-2015, 10:32 AM   #28
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Disaster wanting to happen, don't even think about it, my opinion
Pulling a trailer through Yellowstone Castaway On The Road... 16 05-21-2015 08:58 PM
pulling trailer behind 1986 325 ChrisHunt Classic Motorhomes 6 04-17-2015 04:59 PM
1965 Avion Travel Trailer Air Stream Vintage Pull Behind Camper eBay Watch Airstreams on eBay 0 12-29-2013 07:00 PM
Preferred method for pulling shell from trailer Debnw Repairing/Replacing Floor &/or Frame 19 07-25-2013 08:43 AM
Towing a Small Motorcycle Trailer Behind 25' Safari?? heyskipper Our Community 4 05-07-2003 11:23 AM
