Old 06-02-2004, 01:38 PM   #15
2003 30' Classic
Dallas Center/Des Moines , Iowa
Cool
Great information. Now, does anyone have the formula of knowing how far off level you are initially, so when building the ramp height you only have to do it once? Eight foot string with a string level and a tape measure???? Who of you veterans might have the magic??
Newbie, Joe
iowaroots is offline   Reply With Quote
Old 06-02-2004, 01:49 PM   #16
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I use the WAG method myself.
dscluchfc is offline   Reply With Quote
Old 06-02-2004, 02:27 PM   #17
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
When I towed a trailer I had a Tamarack Level on the front of the unit in the center. It was normally one lynx leveler to the mark on the tamarack. It also had a front to rear level so you could use it to adjust the front to rear level with the tongue.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-02-2004, 02:52 PM   #18
The issue is side to side level. Front to back is acomplished with the tongue jack, and must wait until you unhitch. I back into place, and read the level - One board (2X8) for each mark on the level. I then pull forward enough to lay down the boards and back into place. If an adjustment is necessary, I need only pull straight forward, add or subtract a board, and back straight up again. It takes about as much time to do it as to tell about it.
Mark
Old 06-02-2004, 02:59 PM   #19
upallnight's Avatar
Question
dscluchfc
Maybe you could let some of us newbies in on the WAG method. Start with what does WAG stand for.
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 06-02-2004, 03:31 PM   #20
Edie's Avatar
Dallas , Texas
You just set the 4x4 on the ground a foot or two in front of the tires. Then place the board on the 4x4 to create the ramp. Only drive as far up the ramp as far as you need to go to get level.
Edie
Edie is offline   Reply With Quote
Old 06-02-2004, 04:18 PM   #21
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep it's still that way. Apparently Tamarack now calls the levels "Level Master". When you are one mark off, one Lynx Leveler block under the low side wheels brings you right to level. For those using that level and not wanting to use the Lynx blocks, figure out the height of the Lynx block (go to Wal-Mart with your tape measure) and buy the equivalent in wood.
Its pretty much of a no brainer, one of the reasons why I like my Lynx blocks.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-02-2004, 04:53 PM   #22
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
WAG = Wild A$$ed Guess.....in other words....I look at the levels on the side, and front, and back of the trailer, and eyeball and take my best guess as to how many boards of what thickness it will take.....it ain't rocket science.
Old 06-02-2004, 09:56 PM   #23
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Correct, if it were, it would be a SWAG . . . a Scientific Wild A$$ Guess.
Joe
66Overlander is offline   Reply With Quote
Old 06-03-2004, 12:23 AM   #24
JanP's Avatar
Unhappy how to level
At a KOA in Utah several years ago, I used every block I had under one wheel side and had to dig a trench 6" deep for the tongue to get level. (I had a 28' AS trailer then). I want to look over the sites before parking there again, but what the "hey" when it is getting late and crowded you take anything in a sparse state like Utah.
Ernie and Jan
JanP is offline   Reply With Quote
Old 06-03-2004, 05:47 AM   #25
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
A couple other things that haven't been mentioned - coming from the voice of experience!
Don't raise or lower the jack on the front of the trailer if you have the corner jacks down. I tried this once, and it don't work!
Also, Lynx levelers are sold with 10 blocks to a package, and you'll sometimes need more than 10 blcoks, especially if you have a 2 or 3 axle trailer. I bought mine (new) on Ebay at less cost (including postage) than Camper's World or Walmart.
John
Flyfisher
flyfisher is offline   Reply With Quote
proper bulb for large door light? IPM General Motorhome Topics 3 03-19-2006 06:27 AM
Argosy rear air bag leveling valves. Mark K Airstream Motorhome Forums 5 09-15-2003 04:34 AM
"Lego" leveling blocks--bad experience! Kistler Jacks, Stabilizers, Lifting and Leveling 9 08-28-2003 05:42 AM
hydraulic leveling system kooblekidz Airstream Motorhome Forums 4 02-27-2003 01:52 PM
