Old 12-29-2010, 02:56 PM   #15
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Originally Posted by vswingfield View Post
I think we need to clarify the units. For example, to fill my 40 lb tanks takes about 9 gallons. Big difference.
I filled a 40 lb bottle (9 gallons) on the 20th. The cost including sales tax was $29.37. That works out to about $3.26 per gallon or $0.73 per pound.
That would explain the difference in prices between others' and Shane's. I'm also willing to believe that he recently bought 60 pounds, two 30 lb tanks full, but not 60 gallons. As his second post said, "Confusing."
Not so bad once you get used to it, though.
Thank-you, I WAS confused...using the wrong measurement.
DOH!!!
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 12-29-2010, 02:58 PM   #16
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
After my recalculations come out to......
3.26 a gallon.
Shane
TAC ID TX-1432
Old 12-29-2010, 03:38 PM   #17
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I filled a ten gallon tank yesterday and it cost 15.00 even
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 12-29-2010, 07:28 PM   #18
Denis4x4's Avatar
Durango , Colorado
We're at $2.08 a gallon. I had a wet feed on my 500 gallon tank to fill RV and BBQ tanks. Thanks to the EPA, most companies won't install a wet feed any more due to liability issues and environmental concerns.
Denis4x4 is offline   Reply With Quote
Old 12-29-2010, 10:16 PM   #19
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Here In Tucson lately I've been getting filled at $2.50 + 9.1% sales tax, a little less then $20 for a 30# tank.
snake is offline   Reply With Quote
Old 12-29-2010, 10:53 PM   #20
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I did a little better today on the Northside of Jacksonville. I had two 30# (7 gallon) aluminum tanks filled for $22.50 each works out to $3.21 per gallon. I got these aluminum tanks at a garage sale and they had the old type valves. The shop refitted these tanks with new valves for $18.50 each, which I thought was pretty good.
Brian
SuEllyn & Brian McCabe
Old 01-02-2011, 06:11 AM   #21
2005 28' Safari
saline , Michigan
We pre purchased in August last year at $1.70 per gal. I didn't know you could buy propane anywhere in the US for .87 .
Kosm1o is offline   Reply With Quote
Old 01-02-2011, 06:41 AM   #22
rideair's Avatar
Last I checked, "head price" (the price of propane per-gallon coming off the rail car) was $1.52 a gallon. I get mine at $2.07 per-gallon and use about 3,000 gallons a year in the hot air balloon biz and have a 500 gallon pump station. Prices have gone up over the past couple months.
Paul Waddell
rideair is offline   Reply With Quote
Old 01-02-2011, 06:44 AM   #23
HCR
HCR's Avatar
Livingston , Full time traveler
$24 (including tax) for 30lbs. in Webberville, TX-just outside of austin.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 01-02-2011, 08:39 AM   #24
fmrcaptevil's Avatar
Weldon Spring , Missouri
$2.75 per gal. at Lakeview RV park in Houston, (about $20 for a 30# tank), which is not bad, but electricity is $.155 per kwh. Like the theme from one of Jerry Seinfeld's episodes, "everything evens out"......
fmrcaptevil is offline   Reply With Quote
Old 01-02-2011, 09:42 AM   #25
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Currently, we're charging $2.75/gallon for folks staying with us at the park, and $3.25/gallon for everybody else. Since the park is effectively closed now, it's basically $3.25 for everybody.
Lynn
WBCCI 21043
Old 01-02-2011, 10:22 AM   #26
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
We paid $2.99/gal at a fuel station near Petaluma, CA 2 weeks ago. Saw it as low as $2.75/gal somewhere in Oregon I think.
U-Hauls in San Jose wanted over $4/gal.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 01-02-2011, 10:25 AM   #27
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
You can't. See posts 13, 15, & 16.
Vaughan
Old 01-03-2011, 06:02 PM   #28
AirEPotter's Avatar
2011 27 FB International
Lubbock , Texas
Just filled two 30's in Texas and the total cost with tax was $44. I know they were empty because brilliant me didn't refill them before our last trip (just got back yesterday). Woke up at 2am freezing cold---LP tanks had run out. Nighttime low was 26 degrees. Long cold night. Lesson learned.
AirEPotter is offline   Reply With Quote
