Old 01-15-2016, 07:29 AM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our dynamic changes when the fresh water moves aft into the black and gray water tanks on the Classic. I find I have to drop the height of the jacks to 5" from 5.5". Initially we had a 6" setting, but after taking 175 pounds of battery and stainless steel enclosure weight off of the tongue weight and getting rid of the original water heater and the six gallon hot water storage (which was 80 pounds less weight just behind the street side wheel well), the dynamic changed.
We are still playing with the height of the jacks. If I get them too short, we get both slight oscillations and bounce.
We had more than the provided number of washers in the adjustable hitch head, but I may need to add some more, perhaps with a longer bolt for them to ride on.
Old 01-15-2016, 04:05 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by dznf0g View Post
On some pavements, it is what it is and you can't get rid of all of it.
Rich is correct.
Up-and-down (vertical) movement of the rear of the tow vehicle is not sway and cannot be controlled by changing the hitch around. This is not a problem unique to ProPride; all hitches do it.
The root cause is an undulating pavement surface. Usually the amplitude of the pavement changes is small enough that it isn't noticeable without a trailer. The physics of it has to do with the "normal mode" or resonant frequency of the combination of the tow vehicle rear springs and the weight on them.
If the rear shock absorbers in the tow vehicle have failed, that will make the movement much worse. If they are still good, it will help somewhat to replace them with heavy duty shocks, at the expense of an overall stiffer ride.
Front shocks can also help a little.
Reduced speed can help somewhat.
Old 01-16-2016, 06:39 AM   #17
1996 25' Excella
Tillsonburg , Ontario
Originally Posted by cwf View Post
Oh how fast do you pull? I pull about 60.. Too fast you can develop an oscillation if roads undulate. I have had that in our 34'
Also our truck original shocks were incapable of decelerating. Had to slow under 45 to get it to stop.
Just ideas since we do not know your situation, operating speeds.. Etc.
I have had several situations where it was impossible to stop the porpoising and others where a change in speed settled things down somewhat.
The issue is partly spring rates in the truck and the ability of shocks, but I also believe the spacing in the road joints is a more important factor. The porpoising is due to a natural frequency in the total rig. Some roads simply match the distance between the TV wheels and the Trailer in a way that sets the whole rig into a natural bounce usually referred to as sympathetic frequency. Longer rigs like tractor trailers don't (usually) have the problem.
In my worst case it didn't matter how much I slowed down; sometimes speeding up actually improves it but it will always be there if the road conditions are right!
JCW
JCWDCW is offline   Reply With Quote
Old 01-16-2016, 07:59 AM   #18
dznf0g's Avatar
Oswego , Illinois
JCW
Yup
-Rich-
Old 01-16-2016, 08:56 AM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Could this be one of the reasons the Airstream Owners Manual cautions to never exceed 1,000 lbs hitch weight (similarly, amplifying any sway tendencies)?
Using their guidance of at least 10% of trailer weight, not to exceed 1,000 lbs, our hitch weight must be between 720 lbs and 1,000 lbs, for example.
Doug and Cheryl
Old 01-17-2016, 03:52 AM   #20
switz's Avatar
2014 31' Classic
Images: 8
We had a diesel Suburban in the mid 90s (it lived at the dealership due to exceptionally poor engine design) and were driving in Wyoming at the posted 80 mph with just two of us and some luggage in the car. The road was undulating and we were getting pounded by the suspension. Slowing to 72 mph, the frequency of the road and the long wheel base came into synch and the ride was smooth again.
That road and vehicle harmonic also comes into play when towing.
Old 01-17-2016, 08:11 PM   #21
2014 31' Classic
Hot Springs , Arkansas
Thanks for the many replies. To answer one of the questions asked, we tow at 58-60 mph. The AS has the original D rated tires with 65 mph limits so we don't push it.
We hook up next Monday for a 130 mile drive to our next destination. We'll experiment with some of the suggestions, including taking measurements on the front wheel well and from the back of the WD bars to the ground. Thanks again.
Gigi1957 is offline   Reply With Quote
Old 01-17-2016, 10:00 PM   #22
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also... Check from ground to the "belt line", bow and stern...
Peace and Blessings..
Channing
WBCCI# 30676
Pro Pride Hitch cpfdret Airstream Classifieds 0 11-05-2014 05:04 AM
Pro pride hitch questions gomotomoto Our Community 4 10-11-2014 11:09 AM
Pro-pride (Hensley) Hitch for sale Schilling Airstream Classifieds 0 06-06-2014 08:56 AM
Pro pride hitch/weight distribution question dkottum Hitches, Couplers & Balls 19 03-03-2010 09:42 PM
