Old 05-06-2014, 04:24 PM   #1
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
Preferred fuel stop.
I own a 30 ft flying cloud. I usually travel the interstate. At times it is difficult to find a fuel stop that will allow easy ingress/egress. When towing what is your preferred type fuel stop for re-fueling? Does anyone carry a five gallon plastic container filled with extra fuel for emergency just in case you can't find a suitable fuel stop?
Sjcjr is offline   Reply With Quote
Old 05-06-2014, 04:45 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you are on that last leg going north to Cartwright Labrador, 430 km, there is no reason to carry extra fuel.
I think you be hard to find any exit from the interstate system that was no easy off easy on and almost every one has some form of fuel stop. Now that said you will pay extra at any exit stop off the Interstate system. I have found fuel $.30 a gallon cheaper just 1/2 mile past the station just off the Interstate. At 40 gallons per stop I will drive that 1/2 mile.
Get Gas Buddy app for your phone. It gives prices and map direction.
2004 Excursion 4x4
Old 05-06-2014, 05:07 PM   #3
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
We carry a copy of "NEXT EXIT". It is arranged by State; then by interstate no. It lists RV friendly gas stations in "Red" and other RV friendly places like Cracker Barrels, etc also in "Red" and tells which side of interstate they are on. Probably the most used purchase for our airstream travels. It is a "MUST HAVE" as far as the "navigator's seat" is concerned.
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 05-06-2014, 05:13 PM   #4
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
There is an iPhone App called iexit. Perhaps it is developed by same company as the book, but it is free and does that very thing. Of course you have to have cell phone service, so the book might be a good backup.
Landrum is offline   Reply With Quote
Old 05-06-2014, 07:02 PM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
We usually fuel up at the truck stops. Not my favorite place, they are usually very busy and I don't want to hold up the working driver, but at 57' total length, pretty much a must. plus we need diesel, which even further complicates fueling. A necessary evil.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 05-06-2014, 07:26 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I do carry a back up can just in case, however I use a steel safety can. The plastic aren't.
I look for large name brand stations, quite often they incorporate a truck stop. Depending on the rig I may need diesel or gas. In my part of NC; Loves, Hess/Wilco, TA and Davis get my vote. Lots of resources out there, GasBuddy is a good one.
Aaron
WBCCI #XXXX AIR #2495
Old 05-06-2014, 07:29 PM   #7
2016 30' Classic
Aaron
Where did you but the steel safety can? How much?
Old 05-06-2014, 08:14 PM   #8
Missouri Valley , Iowa
Sjcjr,
To keep gas for my mower, etc, I use a 5-gal steel safety can from Gemplers.com Its Eagle brand and has a plastic funnel that fits on the spout. It is available in red, blue, or yellow for $44 plus shipping.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-06-2014, 08:43 PM   #9
Landrum's Avatar
I just bought one of those as well. I had it with the stupid safety spout on the newer plastic fuel "cans". You can also buy them at Lowes and Tractor Supply.
Old 05-07-2014, 03:47 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
I do not carry extra fuel for my tow vehicle because of the possibility of contaminating the fuel with dust or dirt and the considerable trouble and expense involved in replacing fuel filters on modern tow vehicles.
Then again I have room for 38 gallons in the factory tanks.
Easy is in the eye of the beholder. Too, fuel station layouts do vary regionally. I can get my 30' trailer in and out of all but the smallest gas stations as long as the islands aren't saturated with cars. Sometimes, rarely, I need to get out and look, or use a spotter.
Old 05-07-2014, 04:04 PM   #11
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
Truck Master Fuel Finder's web site usually has a "street view" of the fuel stop...the fuel stops listed are usually truck stops...the site has a section where you can enter your beginning and ending locations and it will list the fuel stops along the way whether or not interstate routes. also you can use the street view function in google maps and get a good idea of the entrance/exits of fuel stops.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 05-07-2014, 04:18 PM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I buy mine from Airgas Safety, but any good industrial supply house should have them... $45 range for a 5 gallon. I buy the JustRite brand, they are all steel, the Eagle have a plastic handle that doesn't last as well.
Aaron
Old 05-07-2014, 04:43 PM   #13
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
I put a 90 gallon tank in the front of the bed of my TV - 15-1700 miles between fuel stops. Got tired of getting stuck in small gas stations made for cars and dealing with cars in the stations. Now I have plenty of time, and no pressure, to find a good pull through gas stop. Best thing I ever did!
Silver Hawk is offline   Reply With Quote
Old 05-07-2014, 04:57 PM   #14
1981 31' Excella II
New Market , Alabama
I have been lucky enough that most of my trips don't require me to stay on the interstate 100% of the time. I am sure those exit apps can help. Looking at the gas stations from Google earth can help as well. The stations with the pumps parallel to the road are the ones you want. Those are much easier to get in and out of. The ones with the pumps facing the store don't want anything pulling a big trailer. I don't do truck stops. Also if you have a choice between one with a long line that is ten cents cheaper than the one across the street pick the one with higher prices and less traffic. It is worth $5 not to have to deal with penny pinchers that don't mind waiting 30 mins to get gas.
Sovereign weight and Preferred tow vehicle JLD 1974 - 1979 Sovereign 24 06-26-2017 10:17 PM
Preferred method for pulling shell from trailer Debnw Repairing/Replacing Floor &/or Frame 19 07-25-2013 08:43 AM
Preferred driveline brake for '83? dljosephson Mechanics Corner - Engines, Transmission & More... 2 10-05-2009 11:46 AM
