Old 11-12-2004, 10:38 AM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Power w/o batt. just shore...
Hello.
This weekend will be another sad reminder that cold weather is upon us in Chicago. I will be taking out the two batteries from my '04 CCD and store them in my basement with a BatteryMinder watching over them.
1) Will I still be able to hook up the AS to shore power without having the two batteries in the coach? (In case I want to visit during winter).
2) With the batteries out, the cables will just be sitting in the battery storage box, which is made out of metal (of coarse). Let's say I can hook up to shore power, do I need to isolate (insulate) the connectors for the batteries so that they don't short out against that box, or doesn't it matter?
Thanks.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 11-12-2004, 11:18 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by crazylev
Hello.
T
Thanks.
Jonathan
Jonathan,
I don't think you should hook up to shore power without batteries. I remember reading in my manual that you can cause some damage but I forget exactly as to what components. I'm sure there is someone who can verify my statement. Obviously if you are going to hook up to shore power on an occasional basis, the batteries should be fine left in place.
I pull my batteries out since my trailer is at a storage facility and will not have shore power available till next spring.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-12-2004, 11:20 AM   #3
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Hello.
Thanks.
Jonathan
I do not believe that it would hurt the unit unless you shorted the battery cables, but why not just tune off the charger circuit breaker. This would be the best solution.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 11-12-2004, 11:25 AM   #4
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
No batteries
I would wrap the ends of the battery connectors in plastic sandwich bags. A 60 amp spark bouncing around inside the compartment is a little dramatic.
The batteries act like big filter capacitors for the power supply. Since yours is a very recent vintage, the power supply may be a switcher with enough internal filtering to produce smooth DC. For those of us with ancient Univolts, the output without batteries is extremely noisy. The light bulbs and water pump do not care, but I wouldn't want to submit a computer chip to it. (Of course, this does not apply to items like TVs that use the AC shore power.)
sander17 is offline   Reply With Quote
Old 11-12-2004, 12:53 PM   #5
till's Avatar
Lisle , Illinois
Images: 108
I believe that the batteries act as a voltage regulator for the 12 volt DC curcuit. With out them the 12 VDC may not be 12VDC, but something higer.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 11-12-2004, 02:03 PM   #6
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Hello.
I was curious enough about this to actually call AS, and spoke with Jim in customer service.
The bottom line: Apparently you can run shore power to the unit, however, the converter will put out full power going to the batteies, thinking that they are not charged. I was told this would not harm the converter, and in fact that there are some people that only run on AC, without their batteries.
The one thing to make certain of, like Gary, Sander, and Jim(AS) point out, is that the terminal ends MUST be insulated so they don't short out against anything metal.
So who wants to try this first? No.....you go first!
Joanthan
Old 11-12-2004, 02:08 PM   #7
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I've always heard that you should have a load on the converter or else it will ruin the converter.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-12-2004, 04:40 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
my manual sez you can do it, but kiss your radio fuse goodbye!
no you go first!
i don't run mine without batteries. i do think the best solution is to unplug/turn off the breaker to the converter, then just light the trailer with 120 volt lamps from the outlets.
john
you call them ferrets, i call them weasels.
Old 11-12-2004, 05:14 PM   #9
Craftsman
Guest
Posts: n/a
I was hooked to shore power the other day with the lights and furnace running while winterizing the Soverign. I had removed the battery the week before. I hope I didn't damage anything.
TV connected & on shore power? Kistler Audio, Video & TV 4 04-03-2004 06:12 AM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 06:11 PM
power boosters John Our Community 18 11-19-2002 04:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 03:51 PM
