Old 07-29-2010, 10:14 AM   #1
1977 29' Ambassador
Union , Mississippi
Red face Power panel burned up
Hello,
For about the last two months I have lived in my AS helping my son at Starkville MS. About two weeks into the venture with the outside temp in the 90's I went to the camper and approaching it did not hear the AC running. Went inside and could smell something that had burned or was still burning.
After inspection found that the neutral wire had burned into inside the power panel. With the help of my son we got the cable that feeds the power into the camper and cut it off about 6 inches. Hooked everything back up except the AC and turned on the power and everything seemed to be ok. Checked across the AC feed with multimeter and found no short on wire.
Went to the power panel to remove the main breaker and when I did everything in the power panel fell apart. The only answer was to replace the power panel and breakers. Could not find a replacement at a local electric supply house. Went by Lowe's and "BEHOLD" they had almost the exact panel on the shelf. Purchased the panel and correct size breakers and replaced early the next morning before it got to hot. Everything worked fine except unable to use GFCI breaker where the book called for it. The old panel did not have one either in this spot. Sure was good to enjoy the AC again.
Felix B
Katman104 is offline   Reply With Quote
Old 07-29-2010, 10:16 AM   #2
funkill's Avatar
reno , NV
Images: 27
Nice going. I would have melted, along with the panel after finding this situation. Stay cool!
Laura
funkill is offline   Reply With Quote
Old 07-29-2010, 10:31 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Could you have had a lighting strike? We have has some real fireworks up here in Oxford the past few weeks?
Old 07-31-2010, 06:55 AM   #4
1977 29' Ambassador
Union , Mississippi
That was my first thought but the AS was within 100 feet of where I was working and not a cloud in the sky that day.
burned Airstream!!! mickeymoose Airstream "In the News" 10 10-11-2009 07:50 PM
HELP: shorted out control panel and now no power purman Electrical - Systems, Generators, Batteries & Solar 5 06-26-2009 03:33 PM
Brake Lights LED Burned Out? campadk Lights - Interior & Exterior 10 06-29-2007 09:45 PM
AC Power Light on Control Panel? 66Overlander Electrical - Systems, Generators, Batteries & Solar 8 10-20-2005 09:13 PM
Burned 4 way light switch Ferroequine Electrical - Systems, Generators, Batteries & Solar 1 08-06-2004 10:56 AM
