Old 04-23-2016, 07:15 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I also use roof top canoe pads to cushion my ladder. They are pre slotted and fit right on the ladder rails without slipping. Already had them so nothing else to buy. I forgot to pack them for a recent trip and needed to use the ladder. I have a couple of large pool noodles cut for the ZD arms. Used those and they worked just as well. Saw a guy using towels taped around his ladder and that also did the job. Big thing is to cushion the ladder from damaging our precious soft aluminum Airstreams. Use whatever works for you.
MICHAEL
Old 04-24-2016, 06:40 AM   #16
Sioux Falls , South Dakota
I carry a two-step step stool and a folding ladder because of the work I do. When we get the Airstream both will travel in the truck. I got pool noodles for the big awning on the Foretravel after I used my head to find one of the arms. Those noodles will go with the coach and I'll get new ones for the Airstream.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 04-24-2016, 07:27 AM   #17
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Depending on the size and shape of your space, you might want to consider alternative designs:
http://www.amazon.com/GP-Logistics-S.../dp/B002PNMMOC
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-24-2016, 07:36 AM   #18
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That's exactly the kind that Camping World used to sell. As I stated in a previous post, my 5' model was so rickety I don't dare set it up anywhere but on a level floor.
Mind you, the posted load capacity of the 5' GP Logistics is only 225 pounds (I just now looked on mine, it's posted in very small numbers about 1/8" high on one leg of the ladder), and I'm about a dozen pounds over that limit. So of course it's rickety for me. People who weigh less will have fewer problems with it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-24-2016, 08:23 AM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We carry this compact and stable 3-step ladder which allows us to reach the roof and helps getting stuff into the bed of the truck. Travels nicely.
Doug and Cheryl
Old 04-24-2016, 08:43 AM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Telesteps for me!
I use 2 of their 16 foot heavy duty models (the ones with the actual step platforms on them) for my solar installation work. I lean then against the sidewall of an RV using a dual durometer foam cap that I have fabricated for me in Hood River at a foam products manufacturer.
Almost every client with an Airstream also has one (but the shorter, regular duty models) that allow them roof access to clean or tilt their solar panels. They are solidly built, work extremely well and store with a single latching mechanism. Great product!
Old 04-24-2016, 11:09 AM   #21
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by Protagonist View Post
TeleSteps is one of the best. Very sturdy and very compact. Available as a regular ladder or a stepladder. I have the stepladder type.
http://www.telesteps.se/en/pro/home/
This is interesting. Looking at their website they make a the step ladder in both a 1.7M and 2.3M lengths. The folded lengths are almost the same 67cm compared to 71cm and the weights are about 4kg apart. Does anyone know how deep they are when folded. The spec says they are width is about 60cm but does not talk about depth (folded)
I use a ladder all the time while on the road as I like to keep the trailer clean as possible - so it gets washed regularly. Right now I'm using a 3-step folding step stool but find its not high enough to get the end caps clean.
I know I'm short.....
Anyway, just wondering if the 1.7 or 2.3 would be best and also does anyone know were one can purchase these in Canada or the USA as I see this is a European site
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-24-2016, 11:20 AM   #22
I got mine at Amazon after reading on another thread where Lewster mentioned his.
http://www.amazon.com/s/ref=nb_sb_no...ords=telesteps
WBCCI #1105
TAC LA-4
Old 04-24-2016, 11:24 AM   #23
Arcticfox's Avatar
Central , Canada
Thanks Protagonist. What length did you get?
Old 04-24-2016, 11:32 AM   #24
This one, Telesteps 10ES:
http://www.amazon.com/Telesteps-10ES...rch_detailpage
Unfortunately, that one is temporarily out of stock at Amazon. It's not long enough to use to climb up on the roof, but long enough reach the roof.
WBCCI #1105
TAC LA-4
Old 04-24-2016, 11:41 AM   #25
Arcticfox's Avatar
Central , Canada
Perfect - Thanks you!
Old 04-28-2016, 09:30 PM   #26
2016 26' Flying Cloud
Southlake , Texas
I bought this ladder from Amazom and it is a good multi-purpose ladder that doesn't take up much space when stored. I have used it to get on the roof several times by having 3 sections straight and the 4th at a 90deg angle. I put a 2x2 across the end and padded it. It is long enough to spread load across two roof supports.
NeikoŽ 01995 Folding Aluminum Ladder, 12.5-Ft Extended | 300 Lbs. Capacity
Sorry, didn't know how to paste a link.
Bgibbs is offline   Reply With Quote
Old 05-02-2016, 09:29 AM   #27
2015 30' International
FREDERICK , Maryland
That is also what I keep in my rear storage compartment. Pricy but sturdy.
Doc Foster is offline   Reply With Quote
Old 05-02-2016, 09:53 AM   #28
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
With the overall height of the typical Airstream trailer under 10ft would the Telestep 3.3m model (10.8') overall length be too short or is the 3.8m model advised (12.5').
Kelvin
Lower ladder section for 2000 Airstream Motor Home Usmconei Airstream Classifieds 0 07-23-2014 12:47 PM
1950 Cruiser # 6032 pipe or ladder frame? Jim Jarzabek 1950 - 1958 Cruiser 11 01-12-2006 06:31 AM
Found a good ladder DaveJ Commercial Listings 11 11-12-2003 05:12 AM
Ladder Advice ViewRVs General Repair Forum 11 10-10-2002 10:51 PM
