Old 09-16-2018, 05:03 PM   #1
2019 25' International
Washington , Washington, D.C.
Portable Heater recommendations
A recently-issued Blue Beret magazine recommended getting a 'quality portable heater' in the 'milk house style'. Recommendations? Thanks!
PatLee is offline   Reply With Quote
Old 09-16-2018, 05:15 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
We tried several small forced air heaters over the years. A few years ago I started using one of the oil filled electric radiator type heaters. It is great, warms the trailer fairly quickly and produces a much more even heat though out the trailer, plus it is silent.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-16-2018, 06:18 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have had at least a dozen small ceramic heaters over the last 25 years. I have five right now. I've learned a few things that I think are important.
1. Those heaters that don't have a thermostat just do not work for a trailer interior if someone plans on using it while sleeping. The heaters with digital thermostats provide a more even interior temperature than those with the dissimilar metal /mechanical thermostats.
2. Three heat settings are better than 2 (low, medium, high heat)
3. Multiple fan speeds are better.
4. Before purchasing, listen to the fan. Some are loud enough to keep me awake.
I like to use two electric heaters, one at each end of the trailer on the low heat setting, instead of one on a high. It keeps the interior temperature more comfortable.
Of all of the heaters I have tried I like the Lasko tower heaters best, because the fan is whisper quiet. I also have an oil filled heater I use at times two heaters are needed.
ps: I live in my 34' trailer all winter in FL. I use electric about 95% of the time. Until there is danger of freezing a plumbing pipe the furnace is hardly ever used.
Alan
Old 09-16-2018, 07:13 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
We use a simple ceramic heater. We sit it on the stove top.
CRH is offline   Reply With Quote
Old 09-16-2018, 10:02 PM   #5
2007 22' International CCD
Dittos on the oil-filled radiator type heaters. I have dogs, all males, with “male dog habits”. Oil-filled heaters are also not as hot running and silent. Heater is kept on the floor at rear of trailer out of the aisle.
Old 09-17-2018, 08:34 AM   #6
Thank you A W Warn for your insights. You said 3 heat settings were better than 1 but in looking at space heaters on line, I can only find some with 'high' or 'low' and 'fan only' settings. Is that what you meant by 'three heat settings"?
Thank you.
Old 09-17-2018, 09:07 AM   #7
Mollysdad's Avatar
I tried a bunch of "hot wire & fan" type electric heaters and was always disappointed, usually because of fan noise. Even the highly rated Broan.
I kept remembering a great heater I had in a rental cabin. All I knew it was a Pelonis.
I scoured e-Bay and finally found one made in 1989 and stored away in some estate so it looked new. It's ceramic, and uses a heavy steel cabinet, and the dial for heat also controls the fan speed, so you can dial it down to low power and quiet.
Pelonis is still around, just the name, but they're now plastic and made in China.
I love my 30 year old heater. (even bought two so I have one in my home bedroom)
Old 09-17-2018, 04:26 PM   #8
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I have had very good service from our Vornado heater.
https://www.vornado.com/product-cate...ers/whole-room
Similar to their VH-10.... a newer model.
I think they are still made in the USA, and have a 5-year warranty.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 09-17-2018, 04:55 PM   #9
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Ditto on the Lasko tower heater with digital thermostat. Be sure you get the one with the remote control so you don't have to get outta bed to adjust the temp.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-18-2018, 02:08 PM   #10
Steamguy's Avatar
2019 27' International
Washougal , Washington
Wow, there's a blast from the past... I've owned the Pelonis, and it was absolutely the very best heater. Quiet and efficient. It does run all the time, so it keeps the heat in the coach nice and even. They are hands-down, the quietest. The motor in mine quit after about ten years, and it was a $90 part, so that ended it...
A good second: I'll cast my vote with PaulnGina above. The Vornado heaters. They're reasonably quiet and do a good job.
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 09-18-2018, 02:24 PM   #11
2018 30' Classic
Jacksonville , Florida
Look for a thermostat and anti tip over feature. Think small you don't want it to over load anything pop a breaker or burn up a cord.
Overstreet is offline   Reply With Quote
Old 09-18-2018, 04:17 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
Have been using this since 1979, at home & AS.
All metal old school. 👍
ID:	322904   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 09-18-2018, 04:31 PM   #13
TDF
Fabius , New York
Are there any 12v heaters you can recommend? We never have shore power.
TDF is offline   Reply With Quote
Old 09-18-2018, 05:25 PM   #14
The problem with 12v is the amp draw, without a stout battery bank & charge supply you can go flat quick.
Mr Buddy is popular with the Sailing Cruiser crowd.
Amanamus
"Tahawus"
Recommendations for portable solar panel kit? jagzoo Generators & Solar Power 37 03-06-2017 08:28 PM
Portable Ice Maker - Recommendations GeeSag General Appliance Topics 7 09-29-2016 03:14 PM
Mr. Heater Portable Big Buddy Propane Heater Ray Eklund Furnaces, Heaters, Fireplaces & Air Conditioning 13 08-31-2016 12:02 AM
Reeling in the Sheaves…. Portable catalytic heater installation hshovic Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-23-2007 09:14 PM
Portable heater suggestions ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-22-2005 02:54 PM
