Old 09-26-2016, 01:53 PM   #1
benicia , California
Poor cable signal to my TV
I am getting really bad cable connection to my TV. I had the camp host check out the signal at my site and it was great. He actually brought a mini TV with him, connected the cable to it and picture was perfect. However, when I connect the cable to my 2011 FC, my picture is snowy at best. I bought my AS used but the dealer told me everything works fine. I didn't check cable during the walk through though.
Is there a setting inside the AS I'm supposed to use? When I set my Samsung TV to receive signal through the rooftop antenna, the picture is crisp and clear. When I set my TV to receive reception via cable, it stinks.
What am I doing wrong?
cantdrv55 is offline   Reply With Quote
Old 09-26-2016, 02:09 PM   #2
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Look near the 12 volt outlet and cable connection inside the RV. Small black button, in for onboard antenna, out for cable.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 09-26-2016, 02:11 PM   #3
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . what he said (beat me to it :~)) Mine has little green light on it. . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-26-2016, 02:19 PM   #4
Mine has a green light and button is out. Still crappy signal. Is there a way to check connection with a multimeter?
Old 09-26-2016, 02:32 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Regardless of button position, if the green light is on, your antenna power amplifier is on and that will mess up your signal. If the green light is off you should be good to scan for channels there and get good signal.
SteveSueMac is online now   Reply With Quote
Old 09-26-2016, 02:49 PM   #6
Ok thanks. The green light is always on regardless of button position. Sounds like I've got some wiring issues or defective signal selector.
Old 09-27-2016, 05:50 PM   #7
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
Keep in mind that the tv set can select between STD standard cable channels, HRC harmonic related channels and IRC incremental related channels.
When you swap tween cable and off air, rescan the channel lineup and that may clear up the problem.
Your set will also allow you to pick STD, HRC or IRC configuration. If you happen to be on the wrong format you have very weak signal or nothing at all.
Marketing consideration.
Jekerrville is offline   Reply With Quote
Old 09-27-2016, 06:06 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I don't think there is any wiring issue that will keep the LED on regardless of button position. When the LED is on, the antenna is selected, thus poor cable signals.
IMO you need a new selector.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-27-2016, 06:52 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Al
True not a wiring problem. Could be a bad switch on the selector.
Can be tested, just remove the screws pull the plate out and disconnect the power wire and see if it works.
Old 09-27-2016, 09:59 PM   #10
silver.villa
silver.villa's Avatar
2011 20' Flying Cloud
Albuquerque , New Mexico
Hmmm. We have a 2011 FC. As I recall there is a coax jumper that needs to be installed to be able to watch cable on your TV. This jumper is about 7" long pre bent in a u shape. There are 2 female coax outlets right below the antenna booster that everyone is referring to. After the jumper is installed then re-scan channels in the cable mode. Not able to access the AS until Saturday but can take a picture if you need.
Jerry
silver.villa is offline   Reply With Quote
Old 09-30-2016, 03:52 PM   #11
Hi Jerry, I have that cable connected in a U shape. Going camping again next month so will try all the suggestions then.
Thanks all.
Old 09-30-2016, 04:14 PM   #12
W , New England
In my manual, that jumper cable is required to use cable and is disconnected when plugging in a satellite receiver in that spot. If you have that jumper plugged in, you should be fine for cable.
I think you said no matter what you do with the button the green light is always on for your antenna boost. I believe that is your problem. That switch needs to be replaced so the green light goes off and your cable signal will be clear.
Name:	ImageUploadedByAirstream Forums1475270061.301616.jpg
Old 09-30-2016, 10:38 PM   #13
Thank you Steve.
Old 10-01-2016, 05:38 AM   #14
Thank you all...
This has been our TV also for the last week. I just thought it was the park/post and was going to check with the park people this week.
I turned off the green light and now have crystal clear cable channels.
LOVE THIS FORUM
Brenda
BetterNowlinLater is offline   Reply With Quote
Scrambled Cable Signal chaseav 2011 - 2015 International 9 07-25-2016 05:53 AM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 09:16 AM
Poor TV cable reception B&J 2002 - 2005 International 7 10-17-2005 10:58 AM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
Poor cooling on AC, good on gas Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-13-2002 11:46 PM
