Old 08-29-2013, 07:03 PM   #1
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Ponca Springs, CO to Gunnison, CO
How difficult is the drive between Ponca Springs,CO and Gunnison, CO? Would you recommend the drive to a newbie? Thx
Gege
GeGe is offline   Reply With Quote
Old 08-29-2013, 07:35 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
From Ponca Springs, you'll need to go over Monarch Pass to go to Gunnison. Not the world's toughest pass, but could be challenging for a first timer from the flat lands. If you are not versed in mountain towing, here are a couple of threads with info on Monarch and with tips on mountain towing:
http://www.airforums.com/forums/f42/...ss-108546.html
http://www.airforums.com/forums/f439...ck-108307.html
Lynn
WBCCI 21043
Old 08-29-2013, 07:42 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hi GeGe -- I don't see a Ponca Springs in Colorado. Are you talking about Poncha Springs -- just west of Salida? [maybe it's Google that has the name goofed up]
Name:	Poncha Springs.png
So ... you're talking driving north on 285/24 through Leadville?
We'll hope for others more experienced to discuss that route. I only know that once you get to Glenwood Springs you'd better know your exit & destination. Town & local environs are mighty squeezed in with the tight valley & slopes surrounding.
We sure liked Rifle Gap State Park northeast out of Rifle.
5 meter Langford Nahanni
Old 08-29-2013, 08:09 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Glenwood Springs is the long way around to get to Gunnison from Poncha Springs.
Hwy 50 is the most direct route.
There is an alternate route if you go south on Hwy 285 to Saguache, then take Hwy 114 over North Pass. North Pass is just over 10K' high, where Monarch is over 11K' high.
Can't tell you what kind of shape either road is in. But both are scenic.
If you are not skilled in mountain driving. The best advice I can give is to take it slow, use the engine for braking when going down hill. The yellow signs ahead of each curve gives the recommended speed limit. I would say to stay at least 10mph below the speed posted. Use the brakes sparingly.
Enjoy the ride.
Old 08-29-2013, 08:53 PM   #5
Lynn
Whoa Bob!
Lynn is sending you west from Poncha Springs as I should have. Sorry for my mistake.
Onward to Gunnison.
Old 08-29-2013, 09:01 PM   #6
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Monarch is a good pass with no major drop offs and wide roadway. There are some curves descending to the west, just downshift and take it easy and you'll be fine. 6% grade.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 08-29-2013, 11:07 PM   #7
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I drove up the east side and back down Monday afternoon. It was still there in good shape. There are many passes in Colorado that are a lot scarier than Monarch. Just remember: The dangerous part is going down not up. Make sure that you are set up in a low enough gear before actually beginning the descent. That ideally would be the gear that will allow you to maintain a constant non increasing speed without braking. Observe how a loaded semi descents a steep incline and emulate that. If you have not done a long steep descent before, practice on some hills that are short enough that you will not reach a dangerous speed before leveling out again.
Ken
Old 08-30-2013, 06:19 AM   #8
dznf0g's Avatar
Oswego , Illinois
Drove it last month. It is one of the better roads I traveled on...but I was looking for the "less traveled".
-Rich-
Old 08-30-2013, 07:57 AM   #9
awryawry's Avatar
2000 27' Safari
Durango , Colorado
Go.
.... pursue ease and grace ....
awryawry is offline   Reply With Quote
Old 08-30-2013, 08:06 AM   #10
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Monarch is no worry. Paved as any highway. A little curvy and a long pull, but take it easy and all will be fine.
Down shift and let the engine take you down, and you won't need brakes much.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-30-2013, 08:08 AM   #11
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
The "less traveled" would be a bit longer, but very pretty. Turn south at Poncha Springs on 285 and go to Saguache. Then take Co 114 over North Pass to just outside of Gunnison. North Pass isn't bad at all (with the relevant disclaimers to flatlanders), and not many people travel it at all.
If you want to head from Gunnison northwestward, you take take the road more traveled to Montrose and then north, but you can take the road less traveled over Black Mesa (Co 92). A good road (and nowadays even paved all the way!), though you have to appreciate cliffs and drops many hundreds of feet down into the Black Canyon.
Lynn
WBCCI 21043
Old 08-30-2013, 07:03 PM   #12
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
Thank you
Everyone is so kind. I really appreciate your help. Flatlander from Texas
Internet available at Mystic Springs? PA Camper On The Road... 6 10-30-2011 07:05 PM
Need springs for electric brakes Roger L. Brakes & Brake Controllers 5 08-16-2011 11:34 AM
Master Lift Gas Springs ElliotA General Repair Forum 2 08-07-2011 09:45 PM
SoCal dilemma: Desert Hot Springs, Borrego Springs or Temecula? Stella On The Road... 5 03-13-2011 04:59 PM
