View Poll Results: FUEL CONSUMPTION
8 mpg or less / 29,40 liters or more for 100 km 11 14.86%
9 mpg / 26,14 l for 100 km 6 8.11%
10 mpg / 23,52 l for 100 km 11 14.86%
11 mpg / 21,38 l for 100 km 10 13.51%
12 mpg / 19,60 l for 100 km 18 24.32%
13 mpg / 18,09 l for 100 km 8 10.81%
14 mpg / 16,80 l for 100 km 4 5.41%
15 mpg / 15,29 l for 100 km 4 5.41%
16 mpg / 14,70 l for 100 km 1 1.35%
18 mpg or more / 13,07 liters or less for 100 km 1 1.35%
Voters: 74. You may not vote on this poll
Old 02-29-2004, 01:34 PM   #29
Confused & Wandering
Theo's Avatar
1993 34' Excella
Right here, , where ever I wake up
Send a message via AIM to Theo
Towing my ex trailer, the 23 foot safari, i was getting about 12 going fast, and nearly 15 going slow.. I drive a 2002 Ford F250 4x4 crewcab, diesel. I may get less towing the monster I just bought, I find out tomorrow or tuesday..
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 02-29-2004, 01:35 PM   #30
Theo's Avatar
1993 34' Excella
Originally posted by biggerbadbrad
A mechanical engineer once explained to me that the fuel economy from a gasoline (or diesel) engine can be directly calculated using a ratio between the friction (energy exerted by the motor under a given load) and the displacement of the engine multiplied by a coefficient derived from the efficiency of that particular motor. He went on to explain further that although it is not likely that an engine with a larger displacement will ever yield better fuel economy than that of a smaller displacement at any load, the engine with smaller displacement will quickly approach that of the larger engine as these forces increase. The durability and longevity of engine life, however, will be significantly affected as this ratio increases to the point where the smaller displaced engine's lifespan is reduced significantly. Cylinder quantity and arrangement was also factored into this equation.
bbb
Have you any way of translating that for idiots like me to understand?
Theo
Old 02-29-2004, 03:21 PM   #31
1986 32' Excella
vledder , drenthe
Images: 8
my 392 hemi makes about 7 to 8 MPG with a heavy right foot
this is at cruising speed at about 100 mph without A/S
with the A/S I get about 8 to 9 MPG at 55 to 60 mph
1957 imperial 1974 27 Ft overlander
Remco
remcolent is offline   Reply With Quote
Old 02-29-2004, 04:29 PM   #32
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Right now I am getting a consistant 19.2 highway mpg solo with my Duramax. I get 18 country/city driving. Towing the Airstream it varies 13-14 mpg depending on the fuel quality and weather.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-29-2004, 04:37 PM   #33
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I'm pulling a 94 34' limited with a 92 Dodge Cummins. It has everything on it that Gayle Banks makes for this engine as well as a Pac Exhaust brake. Its a 4x4 with a 5 speed manual but it has a 3.54 gear. This is a wonderful choice for economy but a poor one for pulling long grades. I get 12.5 mpg pulling and 22.5 solo. I seldom run over 65. Diesels do get better mileage and I love mine.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
Auxilary Fuel (gasoline) Tank? DGJackson 1970-79 Tradewind 3 08-18-2011 10:44 PM
Extra fuel tank line? pdallas Classic Motorhomes 4 05-12-2011 09:32 AM
