Old 05-09-2019, 10:31 AM   #1
2019 25' International
Washington , Washington, D.C.
Please check me on this
Dear all,
I am a condo dweller so my Airstream resides in a storage facility 40 minutes away. I'm making my last drop off at the Airstream on Friday in preparation for leaving Sunday morning on a summer road trip (I am unable to visit her on Saturday). I want the frig to be cold Sunday morning, so on Friday, I plan to turn on the propane, flip the inside switch from "Store" to "Use," and turn the frig "ON" along with the "AUTO" button. Here's my question: Does doing this run down the batteries?
BTW - I have 2 solar panels on the roof and noticed the battery level was at 12.6V yesterday when I was inspecting her. I use a post-winter storage check list and everything worked fine.
Please let me know if there are hazards/consequenes I haven't thought about. Usually, I just let the frig go cold on my first day of travel and then stock the frig that evening from a grocery store. Just thought I would try something different this time around and see how I like it.
Thanks so much for any advice!
PatLee is offline   Reply With Quote
Old 05-09-2019, 10:50 AM   #2
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
Your plan sounds just fine (unless you are parked next to something really combustible, like an open jug of gasoline!) I would make sure that the fridge burner lights up before I left. You should be able to open the ventilation screen from the outside to visually confirm that it is burning. My fridge takes a little time to fire up after I turn the propane on, so I usually help clear any air in the line by turning on a stovetop burner until that will light, and the fridge usually lights right after.
If you have a switch for the refer fan, flip that on as well. The "Auto" switch only matters if the trailer has a 110v connection (or maybe if you have a 3-way fridge that could run off battery power). In propane mode, the fridge and its fan should use almost no battery.
teagues is online now   Reply With Quote
Old 05-09-2019, 11:07 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I would turn it to GAS rather than Auto. Once in a while mine has failed to switch over when I have pulled away from a campsite with power. Agree, also make sure burner turns on.
Alternately, and with an excess of caution (local tunnels require all bottles be turned off) I simply put a 5lb bag of ice in the freezer and one or two in the refrigerator along with already chilled or frozen food. Everything is good for 4 to 8 hours easily, if temps are reasonable. I have taken to setting alarms for myself to stop and turn on the gas in the fridge!
Paula
Old 05-09-2019, 01:31 PM   #4
2018 30' Classic
Jacksonville , Florida
Should be fine.
Yes, the refrigerator works on gas and electric. The controls are 12 volt. The heater for the absorption system is either 110vac or gas. You will be working on 12vdc and propane. Make sure the tank is on. Make sure the battery is also on. (ie batt storage switch)
You said, " BTW - I have 2 solar panels on the roof and noticed the battery level was at 12.6V ……" What did the solar control panel say? It gives a much better reading that voltage. It also tells you if it is charging and how many amps of charge. I primarily use the batt % reading.
ps...everybody I know that worked in Washington DC lived in Alexandria. Yet you live in DC? Is that why the trailer is 40 minutes away?
Overstreet is online now   Reply With Quote
Old 05-09-2019, 02:47 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would watch the fridge for an hour to be sure it stays on when on gas. Ours sometimes requires starting several times on gas when it has been dormant for a while. Looks like it is running then the "check" light comes on. Burning the stove burner for just a while is a good idea as suggested. The fridge running on propane should be a minimal draw on the batteries. Your trailer is outside rather in a closed unit, correct.
Bill M. is online now   Reply With Quote
Old 05-09-2019, 02:57 PM   #6
Long Island , New York
Personally, I would not pre-chill the fridge, but rather would bring a cooler or two full of pre-chilled food, and a few bags of ice. When you arrive to leave for your trip, turn the fridge on and transfer the food/ice.
This approach eliminates relying on the fridge to operate on propane in your absence.
If you want to pre-chill the fridge, as was suggested, wait an hour or so to make sure it is working right.
Peter
PS — Frozen food will not like this approach. Large blocks of blue ice from home are a good option too.
Old 05-09-2019, 03:14 PM   #7
2018 30' Classic
I always start the fridge two days ahead of departure. I fill three ice cube trays and put them in the freezer. If they're frozen everything is "cool" for the stocking one day before. Of course most of the time I'm on 15amps.
This is a good test for boondocking.
Old 05-09-2019, 06:00 PM   #8
Thank you everyone for your quick responses. Very reassuring. Teagues - thanks for clarifying the use of the "Auto" button, makes sense. Take care all and have a great summer.
Old 05-09-2019, 08:44 PM   #9
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
I live in the valley of the sun. I put dry ice in the freezer and refrigerator then pack it with the food and leave on trip. The dry ice helps the refrigerator get cold in a hurry.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 05-10-2019, 06:17 AM   #10
Overstreet - great idea to fill the ice trays and then check them to see if frig worked after turning on. Also, yes, I live in DC in a condo with no trailer parking available. To Bill M: Yes, the trailer is stored outside. Thanks again all!
Old 05-10-2019, 06:34 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Is your storage location outdoors or indoors? If outdoors, how much shade (if any) is involved? The "typical fridge" combined with the "typical batteries" will run down by about 1/3 in a day of usage. Without any boost you are getting a bit low in two days. That *assumes* they are full charged to start.
Assuming you do have sun and two panels, if you get pretty much full sun in your location, you will get over 1/2 of a battery in a day. That will keep up with the fridge.
Old 05-10-2019, 10:02 AM   #12
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Yep! sounds like a plan - I too am condo liv'in - and do the ice cube tray in the freezer and a couple of cans of (your choice of drinks ) in the frig that way I know I am set for boondocking (PS like you I run 200 watts of solar on the roof + 2 6v batteries) needless to say I check the day before to make sure all is well
La Dolce Vita Brick & Mona
2004 International 25CCD "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 05-10-2019, 10:41 AM   #13
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Short Answer: Yes
Long Answer: If you are on battery, select Propane. If you are plugged in, then select AUTO. Yes, AUTO is supposed to do both, but I have come across where it doesn't sometimes. Keeping it on propane while on propane has a 99.999 success rate in my book.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 05-19-2019, 11:06 AM   #14
geo
2019 23' International
Vancouver , British Columbia
I use this approach also, and it works well for me. My trailer is also stored in a remote lot, so when starting a trip, I put my food plus a couple of blue ice packs in a well insulated cooler, which stays in my air conditioned SUV during the drive. I also purchase an additional 5-9# bag of cubes when I get close to my first destination.
On longer trips, when driving between stops, I leave the ice and packs in the freezer, keep all the food in the fridge, and turn off the gas when traveling. The fridge does a great job keeping the food cold during the drive.
One important safety tip: if you run the fridge in gas mode while driving, turn off the fridge and close the propane valves before entering a gas station. Turn it back on only when you are a safe distance away.
geo is offline   Reply With Quote
Please Check My Math shovelbum Towing, Tow Vehicles & Hitches 6 03-11-2008 08:03 PM
Landyatch owners please check this for me. poqn2slots Airstream Motorhome Forums 3 07-26-2004 06:51 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
