Old 08-15-2017, 10:05 AM   #1
2006 22' Parkway
Poughkeepsie , New York
Personal wi-fi on the road
I know some people have their own wi-fi wherever they go. I have no idea what to get and need some help. I imagine there are monthly charges so I would be interested in knowing that too. Can this replace your system at home?
Skerr is offline   Reply With Quote
Old 08-15-2017, 10:27 AM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
How much data do you use each month? How bad would it be if you found yourself without fast/any internet access for a period of time? How important is coverage (i.e. are you mostly staying in well populated areas where lower cost providers have good service, or do you go boondocking)?
You can get an aircard/mifi type device which is basically a data only cell phone. Different providers have different plans with different costs. Coverage depends on the provider. Verizon is generally the most expensive but has the best coverage.
Data usage is limited. Even the "unlimited" plans will throttle you to a crawl once you go over a certain limit.
Cell signal inside the Airstream can be a problem. Lots of folks add a 4g cell booster like the WeBoost 4G-X RV, which runs in the $500 range. More $$ if you need a directional antenna.
TheGreatleys is offline   Reply With Quote
Old 08-15-2017, 10:54 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Simple choices:
1) A cell modem that plugs into your car and looks like WiFi. The data comes from one cell phone company and you pay for it. (You can also do this by satellite)
2) A mobile WiFi that is independent of the cell phone network. The question then becomes "what do you hook up to?". In most cases people want internet connectivity and not a bunch of files on a disk drive.
3) If you are stationary, WiFi systems that link to other WiFi systems are an option. That works if you are close enough and / or have a big enough antenna. Some amount of fiddling is needed for these systems.
What you get depends on what you need. For driving down the road and feeding data to the kids, the answer is a cell modem. If you are at the campsite, it may still be a cell modem if the nearest WiFi is a zillion miles away.
I use a combination of a tethered cell modem and a WiFi Ranger when parked. If I can get WiFi, that's great. If not, I pull 15 or 20 Gigs of data through the modem. When driving, we use cell phones as hotspots.
Old 08-15-2017, 10:56 AM   #4
2015 30' Classic
Pleasanton , California
If you occasionally need WiFi on the road, and are usually within cell coverage with your smartphone, just enable the personal hotspot feature on your cell phone? This will allow you to connect multiple devices to your phone via WiFi. Of course any data that you transfer via this connection will be deducted from your cell phone plan.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 08-15-2017, 11:25 AM   #5
kdickinson's Avatar
Taos , New Mexico
Verizon JetPac - I don't leave home without it.
kdickinson is offline   Reply With Quote
Old 08-15-2017, 11:27 AM   #6
bwpaint's Avatar
2015 25' FB International
my , house
We get unlimited data in our Chevy truck for $20.00 mo. Provided through ATT somehow.
ATT may have a way to add to other vehicles with satellite, don't know, but works well for us. Only problem is having to leave key in accessory position with doors locked to use internet in the trailer.
bwpaint is offline   Reply With Quote
Old 08-15-2017, 11:28 AM   #7
Chicago , Illinois
Or you can buy a cell/modem and install wifi throughout your AS as we had done - still uses your phone data like Verizon or T-Mobile but it is far more powerful and really reliable.
SMWASONMYMD is offline   Reply With Quote
Old 08-15-2017, 12:16 PM   #8
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Me either. 4 G and works great.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-15-2017, 12:28 PM   #9
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
We have a MyFy from Verizon and unlimited data and work every where, we watch Netflix on the road with a Comcast ($35) at Wal-Mart.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 08-15-2017, 12:29 PM   #10
San Clemenete , California
Hi--We went with the Verizon Jetpack. $50 for for the receiver (modem) $20 FOR 4G service. (Plus Tax)
Worked great for checking email and paying bills provided you were in a cell phone service area. Does NOT work in Canada as represented by the service adviser at the Verizon store.
It provided good reliable service for paying bills, checking email and sending photos.
Not enough to stream movies or use Skype or other video apps.
Worked in the tow vehicle as well as long as we had cell phone connections.
$20. for a private network, we were "happy campers".
CarolynSteve is offline   Reply With Quote
Old 08-15-2017, 12:46 PM   #11
belen , New Mexico
We have a jet pack and I just got a verison broadband unit for my business. Both are mobile and are real handy at home when the power goes out .
alantbird is offline   Reply With Quote
Old 08-15-2017, 01:07 PM   #12
2015 23' FB Flying Cloud
Redmond , Washington
Same here. I have used various versions of the Jet Pack for 10 years all across the country. I use a fair amount of data conducting teleconferences while working on the road. The base cost of the Jet Pack connection is $10/month on my Verizon plan and I have a shared data plan (30 GB/month) for all our devices (3 iPhones, 3 iPads, and Jet Pack). This plan allows carry over for unused GB. This helps because most months I am well below 30 GB, and some months I am above that amount.
Verizon has the best coverage and I am rarely out of range. Other carriers (Sprint mostly) claim .5% difference in service reliability, but this is referring to reliability IF you have coverage.
Though some on the forums here have reported problems receiving a cell signal inside the AS, I have not experienced this. I do place the Jet Pack right next to the window. The advantage of the Jet Pack is that I still have my phone free to use without worrying about disconnecting the call or other problems. Verizon store sales staff (take it for what it is worth) tell me the Jet Pack has a stronger/better signal than the iPhone or iPad. I am not sure if that is true, but it works for me. Also, I am sometime in my "Starbucks Office" or other location without power. The Jet Pack has its own battery so my iPhone does not get depleted.
I love being able to work with clients around the world while in my Airstream!
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 08-15-2017, 01:24 PM   #13
Long Island , New York
FYI the Electronics and Connectivity forum [incl. the 3 sub-forums at the top of the page] has many threads on similar issues:
http://www.airforums.com/forums/f317/
Topics include Verizon, weBoost, and other modes of connecting while on the road, for instance:
http://www.airforums.com/forums/f451...ed-162643.html
http://www.airforums.com/forums/f317...ll-135215.html
. . . are but two of dozens of threads there, containing hundreds of earlier posts.
Peter
PS -- Noticed an interesting weBoost article over on one of those threads -- click on arrow in quote to go to there. Article is a few posts earlier:
Originally Posted by OTRA15 View Post
Thanks for a great article, Larry!
Peter
Old 08-15-2017, 01:49 PM   #14
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
___________
We have OnStar and buy our data (ATT) through them. In the truck we run everything on the GMC data. Once we are in the Airstream we run on Verizon and Verizon Hot Spot.
Some areas, like Many Glacier, Montana has -0.0- wifi, television, internet or cell phone coverage, and the pay phones are from the 1970s needing payment cards. We drove out to Babb twice a week to download, upload, pay bills, make calls, etc. then back into the QUIET zone. The Park Service does have phone service and internet, but they don't share.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Personal Message... canny_banjo_man Off Topic Forum 15 08-31-2005 12:56 PM
Your personal Airstream webpage TomW Our Community 12 07-18-2005 09:14 AM
Our personal Road to Lansing thenewkid64 WBCCI Rallies & Events 15 06-29-2004 03:23 PM
**Personal Home Pages** Silvertwinky Link Archive 6 08-19-2003 05:26 PM
