Old 10-03-2016, 06:02 AM   #1
2017 27' Flying Cloud
London , Ontario
Red face Our first weekend out - a few notes/questions
Hi all,
We are the proud new owners of a 2017 FC 27 FB purchased from Can-AM in London, ON. We spent the last few days camping at a local provincial park. Of course, we ran into a few snags and had a few questions. I'll make a few random notes below.
Our friction sway bars (pictured) make a LOT of noise. I realize they are there for our safety. Our dealer told us the noise will gradually fade. But, does the noise get better quickly or does it take a long time to go away? I read on AirForums that a thin coat of vaseline takes away the noise, but won't this also take away the performance (i.e. the friction itself)?
We found that the heat pump worked really well to warm us in the AM without having to use any LP. The furnace is nice warmth from below instead of above, but we preferred to use the heat pump.
I installed an HDMI matrix switcher so the two TVs could both watch the Blu-Ray or an Apple TV I brought along. But, the cool thing is that you can set it to that one TV watches BR while the other watches the Apple TV (or vice versa). My first mod!
We have always been tent campers. We really enjoyed the warm comfort of the trailer, being off the ground, having a big fridge, toilet, and shower. Awesome stuff!
We had to make a manual water run for about 30 L of water using some collapsible water containers to get through the weekend without going to the fill station. This is because our fresh water tank only started at 69%. We will need to check this next time before departing.
The rig tows well with our 2015 Toyota Highlander. We practiced the emergency maneuver of slight acceleration of the TV and concurrent application of the trailer brakes in case of sway/fishtailing.
We spent an hour in a local school's parking lot practicing back-up maneuvers. Feel much better now, but backing in looking out the driver's side seems a lot easier than looking out the passenger side.
Looking forward to chatting with you all!
Phil
ID:	272758   Click image for larger version
Philip Jones is offline   Reply With Quote
Old 10-03-2016, 06:20 AM   #2
Rich and Kat
AIRHEDS's Avatar
Annandale , Virginia
Hello Philip. That HDMI switcher thingy sounds cool. Can you please share more details about brand, model and cost?
Sorry I can't be of any assistance on your squeaky bars question.
Good luck with your FC 27!
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 10-03-2016, 06:22 AM   #3
Nowhere , Somewhere
My eazlift and sway bars make no noise. Was your hitch ball lubed.? Also the small ones for the sway bar.? There is a lube spot on the bottom of the hitch head. Never lube the sway bar, it works like your vehicle brakes, great will make it useless. And the noise does fade as the friction surface breaks in.
1984 Avion 30p 9.1 meter. 2006 Dodge 3500 cummins srw short bed crew cab.
avionstream is offline   Reply With Quote
Old 10-03-2016, 06:53 AM   #4
2017 25' Flying Cloud
Gold Country , California
Thanks for the write up! Can you explain a little more about the hdmi switcher? Do both tvs have an hdmi that goes to the blue ray player? We pick up our 25FB FC in a couple weeks and have wondered how/if we want to utilize our iPads and iPhones for video in the trailer.
I had an Eaz-Lift and it was loud, but I did not grease anything.
Im surprised that a highlander can tow a 27'. I would be interested to hear your thoughts on it after a few trips.
Good luck!
NorCal Matt is offline   Reply With Quote
Old 10-03-2016, 07:10 AM   #5
KSA63's Avatar
2011 28' Flying Cloud
Ramara , Ontario
My FC28 squealed like a pig for the first trip from London to Orillia, not so much on the second time out and virtually no squeal now except when doing tight, slow speed turns. I also use an eaz-lift system with dual friction sway control bars. Biggest problem I have is with the pins that hold the sway control bars on the balls. I have taken to using tie wraps to cinch them up as they tend to spread easily and could fall right off without the tie wraps.
KSA63 is online now   Reply With Quote
Old 10-03-2016, 08:04 AM   #6
London , Ontario
Rich
Good luck!
Here is the product I ordered from Monoprice - http://www.monoprice.com/product?p_id=14529
I opened up the cabinet enclosing the Bluray player (two long screws from the side got me in). From the factory, the HDMI output from the Bluray player goes into an HDMI splitter, so at the other end of the splitter you'll find two HDMI cables going into the splitter. These are the cables carrying the HDMI signal heading to the 2 TVs in the trailer. So, I plugged these two cables into the "HDMI output" ports of the matrix splitter.
Next, I plugged the HDMI output of the Bluray into "HDMI input 1" of the matrix, and plugged the HDMI output of the Apple TV into the "HDMI input 2" of the matrix. Plugging the matrix into electricity completes the install. Now, you can independently tell each TV which HDMI input they should use. Either TV can use either signal, either individually or concurrently. Works great! You can even change signals with the remote they include.
Today I will reassemble the cabinet including adding a couple of short wood screws to mount the matrix more durably to the cabinet itself.
Hope this helps - any more questions please ask.
Old 10-03-2016, 08:06 AM   #7
London , Ontario
My hitch balls were lubed. I guess I will just have to be patient and hope it gets less loud as we travel more. I reduced the tension on the sway bars as we entered the campground since we were only going 30 km/hr and didn't want to disturb our neighbours!
Old 10-03-2016, 08:08 AM   #8
London , Ontario
Thanks for the advice. I was wondering about those pins as they fit pretty loose. I will at least get some more and maybe should do what you do...
Old 10-03-2016, 08:17 AM   #9
Plasma800's Avatar
houston , Texas
Congrats on your first trip out!
With regards to the water, you'll learn to be really conservative.
We carry multiple 1 gallon jugs of water and a couple of cases of bottled water for drinking and the dogs water bowls. These can be easily bought locally if you run low.
Wash dishes in a bucket or semi filled sink, showers = bird baths or bathhouse.
Usually our grey tank is the limiting factor. But we've gotten really good at techniques there too. When no sewer we wash dishes it's a bucket in the sink, then toss that water out, things like that.
Congrats!
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 10-03-2016, 11:31 AM   #10
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I haven't lost any clips yet, but good Idea using ty-wraps.
MelGoddard is offline   Reply With Quote
Old 10-03-2016, 11:35 AM   #11
Anna Maria , Florida
Good luck!
I was wondering about that myself. The tongue weight must be around 750 lbs on a 27' Airstream.
franklyfrank is offline   Reply With Quote
Old 10-03-2016, 12:01 PM   #12
Originally Posted by Philip Jones View Post
Hi all,
Phil
-I have a 30' FC from CanAm, and Andy gave me the same hitch. The sway bars groan like a drunken sailer trying to get back on board. So...
-I purchased a Reese Dual Cam hitch from HB Cycle in Cameron, and on my first trip out to Stratford the rig wriggled like a snake with a broken back.
On my next trip to the 'RV Explorer's Club' rally at Brockville, it again wriggled like".......
-So I asked CanAm to put the original hitch back on, and the damned works very well. It still groans, and I do loosen it off when parking the rig, but it works.
(The complete Reese assembly is up for grabs. Make me a decent offer.)
-I found the heat pump to be marginal on a cold morning, but the furnace is great.
-I like the 30 footer for it's great storage capabilities, and even my wife finds it comfortable to live in. (she wasn't an RV fan)
-As for the hitch: My old Airforce Sgt. told me: "If it moves, lubricate it! If it doesn't move, paint it! If it talks back, salute it."
-So lubricate everything, EXCEPT the sway bars.
I mount my hitch with shims to prevent rattle, and grease them.
(Sent me your e-mail, I'll send you a couple of photos of it.)
mdgoddard3021@gmail.com
-Like 'NorCal Matt' I'm curious about how the Highlander would handle the AS.
I traded in a Toyota 4-Runner (same engine as yours) that towed a 6000 lb. Hi-Lo; for a Ford F-150 EcoBoost that handles the 'Cloud' quite well.
-I keep my fresh water tank at about 60-70% for use on the road. or C.G. power failure. (Needed once at Millar Lake)
I've only needed a full tank one time, and that was at the RV Rally last year at Golden Lake. (My hose wouldn't reach a far-away bib.)
-Enjoy your new RV and welcome to the ranks of "Trailer Trash living in a 'Tin-Can' Shed"
Old 10-03-2016, 12:19 PM   #13
Hi all,
Phil
Hey Phil;
Get yourself some 1" ratchet straps and 'screw in the ground' stakes to support your awning in tough winds.
The Zip-Dee Awning supports look kinda flimsy, and I use three screw-in stakes, one at each end, one in the middle, (using the pull down strap to the stake).
Twist the straps around a few times to make a 'ropey' string that will prevent flutter.
Also i have made two 'de-flapper' clamps for the fabric sides, with bungee wrapped around the upper strut.
It works!
Old 10-03-2016, 12:28 PM   #14
Kyoshi's Avatar
2015 28' International
Beachville , Ontario
New Owner
We picked up our 2015 28 ft International from Can Am on July 15th. We have done 20 days of camping to date. we found that we could go 4 days on the water tank, washing bathroom, no shower used. Haven't used the furnace yet, but AC works fantastic. At Ontario Prov Parks, the hydro connection is between sites and we have had to use a 30 amp extension cord twice. I made up extra wooden blocks as one camp had very uneven ground. Slammed the door on our first trip and it locked itself. Fortunately I had a spare key hidden away. All in all we have had pretty uneventful first trips. Planning winter trip to California and back.
Kyoshi is offline   Reply With Quote
A Few Notes on Fantastic Fan Install Pick Roof Vents, Skylights & Fans 11 11-09-2015 09:10 AM
Notes from the first 19 days... westcoastas Full-Timing, Winter Living & Workamping 32 02-21-2015 05:20 AM
Thinking about adding Silver Streaks to my watch list- a few questions first RhinoWW Vintage Kin 0 07-25-2014 09:16 PM
First longish drive, impressions and a few questions tevake Classic Motorhomes 21 12-09-2013 01:12 PM
FYI Notes Laying Out Fresh Water System Tony S Fresh Water Systems 0 09-04-2013 11:07 AM
