Old 09-11-2005, 05:04 AM   #1
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Our First Trip
Burning Man '05
CLICK HERE to see more pictures.
We just completed our first trip in our ’77 Overlander and it went off without a hitch. We attended the annual Burning Man festival on the Blackrock desert. For those who don’t know about the Blackrock, it is a most inhospitable place. Nothing grows there. No water exist for miles and those who camp there better be prepared for no support from nature because not even she resides there. You are on your own. Our trip was 14 days – one that we have made many times in the past but never in such comfort.
Although many systems had been repaired or replaced (brakes, plumbing, water heater, axles) none had been tested fully prioar to leaving so we were going out to the desert in a trailer that we were completely unfamiliar with how everything would work (or not work). In the end everything worked perfectly with only one minor exception not even worth mentioning.
We were surprised how much stuff the trailer would swallow up. Costumes & clothes, food, additional water (49 gallons in 7 gallon jugs) and of course all the booze an aircraft carrier of sailors could drink packed inside with room to spare. With new 3500 pound axles installed the trailer didn’t even sweat the load.
The journey way 137 miles from our house to “Func Schway”, our encampment at Burning Man. Because we would be traveling down a mountain road 9 miles of grade I was concerned if the brakes would hold out. While I knew that our new DEXTER brake actuator and controller worked while parked in the driveway, they performed well together without problems throughout the whole trip. Riding on freshly repacked bearings (one of them new after discovering heavy pitting on the last repack job) the rotors stayed cool as can during heavy braking. The pads were the old ones that the trailer came with because the rotors were rusty and needed to be turned. There was no time to do that so we decided to just go with what we had. There was still enough meat on them to stop the trailer and they would go a long ways to putting a little polish on the rotors for now.
There was some concern that the heavier rated axles would give the trailer a bouncier ride. We did load up with the extra water but that was not necessary it seems. The trailer rode smoothly and everything was still in place when we arrived and returned. This is surprising because parts of the road were bumpy enough to make it seem like the truck & trailer were at times airborne going down the road. Damn cattleguards!
The Hensley hitch will need a shorter tow bar. With the new axles we gained about 4 inches in trailer height and that made the hitch ride at a downward angle. Wish we would have thought about that before we ordered the hitch so that we would have gotten a more appropriately sized tow bar. The weight distrubution bars don’t seem to pick up as much weight with the hitch at an angle like that but the H2 held up fine. And despite the offset the trailer didn’t sway an inch during the trip.
Heat on the playa WAS an issue as I expected. In order to keep the dust down as much as possible we had to leave the doors closed when the wind picked up. Fortunately we were prepared and didn’t plan on spending too much time in the trailer during the day. The old fridge worked mostly well. On AC power it barely performed but on gas it kept the food cool enough. That fridge will be replaced with a modern unit soon enough.
We were surprised at the size of the water tank, which through conservation lasted throughout the event with water to spare during the 14 days we were out there. But the grey and black water tanks seemed to fill up very quickly. We had to be pumped twice during the event. Not sure of the accuracy of the tank probes but we didn’t want to take any chances. If they indicated full – that was good enough for me.
One thing that we will have to get fixed is whatever access point the mice are using to get in the trailer at our house! The first night we were out on the playa we heard them running around in the ducts and finally caught 1 in the garbage can. The little bugger jumped in after traversing the drainpipe under the sink but couldn’t get back out. He was “dispatched” quickly but his little brother was still running free. We actually trapped him behind the table, which was folded down at the time. After coaxing him into a paper bag he was also dispatched. We laid down to quiet rest. The next evening we were shocked to hear mice running around again. We made several attempts to trap or otherwise catch them but they were savvy to our methods and avoided being caught. The only thing we could do was to pull the blanket over our heads and hope that they didn’t decide to join us. The next day I had to go into town and I stopped to get some traps. When I returned I set the traps with – you guessed it, cheese – and put them on the floor. Within 2 minutes one snapped catching one more mouse and a few minutes after that the other trap went. That was that! The rest of the trip was mouse free.
After this adventure we are looking forward to going to a few rallies and wherever else our heart desires in the coming months before we winterize. Now that we have identified the items that need to be looked at we are confident that this trailer is in sound shape.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 09-11-2005, 05:35 AM   #2
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Great pictures of Burning Man. Please explain to us East Coasters what the celebration is about. It looks like alot of fun.
Did you use a generator for AC power? Did you run the air conditioner there.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 09-11-2005, 05:49 AM   #3
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
It would be better if you went to the web site to learn more about the event because it is more than words and pictures can say. Come call it a counter culture event but that really is the antithesis of what it is. it is culture in art, music and really life.
There are a few areas at this event that has a large generator (150 KW or greater) providing power for emergency services and interactivity at the event. We were in one of those areas so we had power - called the 3:00 plaza. Most others have to bring out a generator for their power needs. One thing is that when using the power provided at the event it is expressly forbidden to run air conditioning because it uses up a lot of power and can cause the generator to trip. So we didn't run the A.C. The power we did use was for the wall of strobe lights we have, etc...
Old 09-11-2005, 08:07 AM   #4
Buttercup--thanks for the report and the great pics--I love "func shwei"--is the func funk music or more techno?
I would love to go to Burning Man--it seems like an amazing experience--it's just so far away--no time to do it right now--a friend from Reno goes there every year--your post reminded me to email him for his report.
and that's so great that the Airstream worked well for you. Were you tenting it before? That would be harsh in the desert.
zoeb nj is offline   Reply With Quote
Old 09-11-2005, 09:13 AM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Congrats on your first trip! Glad everything worked so well for you.
Thanks for the report on Burning Man also. One of these years I will have to go visit this event.
Uwe
www.area63productions.com
Old 09-11-2005, 09:14 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Buttercup,
I agree the tank size on the our vintage of trailers sux. IIRC there is 20 galllons of black and only 10 gallons of grey water. Freshwater is a whopping 45 gallons. We usually camp in heavily wooded areas so grey water disposal is not an issue (thirsty racoons ) But if you are staying more than a long weekend black water can be an issue. I have looked into modification of the existing tanks but have not come up with a reasonable solution yet. So the blue toter is the way to go for now....
Aaron
WBCCI #XXXX AIR #2495
Old 09-11-2005, 09:56 AM   #7
Barbara Peerenboom's Avatar
Seacoast , New England
"We just completed our first trip in our ’77 Overlander and it went off without a hitch"
WHAT???????????????? Hitches, we dont need no stinkin' hitches"
You have atchieved what I continue to dream about............. oh well, maybe next year the GT will be ready.
Thanks for the great pics!
Barb
Barbara Peerenboom is offline   Reply With Quote
Old 09-11-2005, 12:09 PM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Congtratulations on the first trip in the airstream. Im glad it went well for you and that you had a good time. Im sure you will have many more great trips in the years to come.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 09-11-2005, 12:28 PM   #9
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Glad to hear your first trip was a good one! I have found that having a great trip has more to do with attitude than anything else - we've had many trips where things didn't work, but we've never had a bad trip!
Someday we'll have to have a forum get-together at burning man - I'm curious to see what it's all about. Of course, by the time people like me show up, it is - by definition - not hip anymore
Stephanie
Old 09-11-2005, 03:19 PM   #10
rseagle's Avatar
Images: 33
Wow, what an experience that must have been! Great pictures. I bet the nightly illuminations and sounds in the desert were almost surreal. Wish I was there.
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
Old 09-12-2005, 12:35 AM   #11
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I will try to answer everybody in one post here. Yes this is the slow way to becoming a rivet master but it is hard enough doing this at work.
First of all I am posting a few more videos of the trip and I will post more pictures later for everyone but I was trying to keep it somewhat on topic.
zoeb nj,
It was Func Schway and you are right on. we did have several hours of funk on the iPod that was enjoyed by all. I also had some other music for other nights depending on how I felt at the time. But no thump, thump techno.
Kimber has tented it before and says that it isn't all that bad. She has 13 years under her belt for this event so she is the expert. I have 6 years and it has always been the pop-up (which is really a tent if you ask me).
Uwe,
Personal thanks for all the offline help you gave me on this project. I am truly grateful for all you have done. You should plan on going sometime. It is an amazing event with so much to see.
wahoonc,
LOL, Thirsty raccoons! thats precious. Actually I do have a few plans for grey water handling for next year. It involves a diverter valve and some plumbing to drain the water to a large pan for evaporation/cooling. We have done something similar before so it can be done. The trick is minimal modifications to the TT. Can't do much about the black water except using the porta potties at the event more often and save the onboard facilities for when we are too drunk to walk out to the porta potties.
Barbara,
Our TT is n ot complete but is done enough to travel in. You will get there and when you do, if your experience is anything like ours, you will be in fantastic comfort. I was amazed at how well Buttercup worked for us.
Gen Disarray,
We are looking forward to some rallies now that we are road worthy so there will be more trips. Think Death Valley in March.....
Stefrobrts,
Attitude does play a part and I find that it is hard to have a bad one out on the playa. What problems we did have were easily worked out including a grey water tank that didn't get pumped until.... It helps when you start drinking as soon as you get up.
rseagle,
The night life out on the playa is the best. No other place in life have I fely so safe and yet so removed from the comfort of the real world. Illuminated art projects at night take on a wonderfully surrealistic quality. That's why we go back year after year!
Old 09-12-2005, 05:52 AM   #12
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Burning Man Video on the web
Just added some videos to the web site. CLICK HERE to take a look.
Old 09-12-2005, 09:29 AM   #13
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Thanks for the travelogue and pix, Buttercup. Looks like you guys celebrated in grand style.
Pat
pmclemore is offline   Reply With Quote
Old 09-13-2005, 11:14 AM   #14
cammur's Avatar
Roseville , California
Congratulations on Buttercup and thanks for the memories of Burning Man. Went two years ago in a Coleman tent trailer, but now I have an AS. Look forward to the comfort, but I'm not quite willing yet to take my shinny new baby to Black Rock.
cammur is offline   Reply With Quote
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
Longest Trip with a Vintage Airstream Pick On The Road... 7 11-03-2002 07:44 AM
South Carolina Trip Ideas rdm Our Community 4 10-17-2002 09:17 AM
Trip report (long and maybe boring) mkeith54 On The Road... 4 07-26-2002 09:39 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
