Old 03-13-2012, 09:41 AM   #43
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Originally Posted by alozier View Post
Ok so Rick took Stacey and I to the factory.
We saw raw frame, frame with floor only and then a complete unit. They all have at least the 1/4 inch of play....
False alarm on the floor, sorry ;(
Working on the other issues now...
Hey,..no news, on the floor, is good news!!
Now you can enjoy the trip!
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 03-13-2012, 09:43 AM   #44
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Great news on your floor!!
Hope the same for your list.
Just wondering what build procedures have changed since 03, our Classic is solid thru out. Plywood or OSB?
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-13-2012, 09:45 AM   #45
2011 30' International
London , Ontario
Looks like 5/8 plywood...
alozier is offline   Reply With Quote
Old 03-13-2012, 09:51 AM   #46
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Airstream calls it Marine grade plywood,..according to Rick.
I'm going to lunch....I'll check in later.....im gonna go eat subway....(I'm kidding)
Shane
TAC ID TX-1432
Old 03-13-2012, 10:09 AM   #47
Shane
Our Classic is 5/8 plywood but NOT marine grade. Our leaks brought that fact to light.
----- Original Message ----- From: Airstream Customer Support
To: dbeatty686@gmail.com
Sent: Tuesday, August 30, 2011 3:42 PM
Subject: re: Fwd: Floors (contact us from airstream.com)
Thank you for contacting us in regards to the plywood used in our trailer. We use only low VOC plywood and paneling in our trailers to help eliminate out gasing. Some pressure treated woods contain preservatives that would not be allowed used inside a close area.
The plywood we are using is 5/8" water resistant grade 1 plywood.
Date: August 29, 2011 3:42:52 PM EDT
To: Marketing <marketing@airstream.com
Plywood grades.
Marine plywood.....
"Marine plywood is manufactured from durable face and core veneers, with few defects so it performs longer in humid and wet conditions and resists de-laminating and fungal attack. Its construction is such that it can be used in environments where it is exposed to moisture for long periods. Each wood veneer will be from durable tropical hardwoods, have negligible core gap, limiting the chance of trapping water in the plywood and hence providing a solid and stable glue bond. It uses an exterior Weather and Boil Proof (WBP) glue similar to most exterior plywoods. Marine plywood is frequently used in the construction of docks and boats. It is much more expensive than standard plywood: the cost for a typical 4-foot by 8-foot 1/2-inch thick board is roughly $75 to $100 US or around $2.5 per square foot, which is about three times as expensive as standard plywood. Marine plywood can be graded as being compliant with BS 1088, which is a British Standard for marine plywood. There are few international standards for grading marine plywood and most of the standards are voluntary. Some marine plywood has a Lloyd's of London stamp that certifies it to be BS 1088 compliant. Some plywood is also labeled based on the wood used to manufacture it. Examples of this are Okoume or Meranti
Other types of plywoods include fire-retardant, moisture-resistant, sign-grade and pressure-treated. However, the plywood may be treated with various chemicals to improve the plywood's fireproofing. Each of these products is designed to fill a need in industry."
[edit]
PFC
RLC
Old 03-13-2012, 11:07 AM   #48
London , Ontario
Lol, that's what we had for lunch...
Shane
Old 03-13-2012, 12:23 PM   #49
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
If you are gonna stay longer the Verandah has a decent lunch..kind foo foo but not expensive. I did not eat there for dinner.
Just down the road from Airstream is the heidout. I had the pork tenderloin sandwhich,....wasn't bad. It's a bar atmosphere,..I met a couple nice locals there.
The grocery store will be closing the 17 or 21st of March..so if you need anything before you head out,...hit them..but the shelves were already pretty much bare.....but did have enough stuff to get by.
That store gas station right in front of the terra port makes a great egg or bacon crossiant in the morning.they also serve pizza among other things...
How are things progressing?
Shane
TAC ID TX-1432
Old 03-13-2012, 02:04 PM   #50
London , Ontario
We are going to leave tomorrow ;(
They said they need until mid next week at least to go through the warranty and to add the air etc...
So we will leave her here for now and grab her when done.
Sitting back at the terra port having a cocktail with my better half....
Old 03-13-2012, 06:01 PM   #51
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Met with our mechanic Bill, great guy!
Went through our list and they are now going to look over things...
He isn't sure the floor is a rot problem, might be normal 'spring'. They are going to look at it first of course.
You guys think a 1/4 inch movement to the floor is normal when walking? If so let me know, this is out first trailer so we are clueless...
Maybe it is me then...
Just seeing over a 1/4 separation from the cupboard when walked on, and the squishy feels scare me....
I wonder how far apart the cross beams are each way...
Thanks eh!
Hi, I understand that the floor may flex a bit, [mine does too] but I don't think a 1/4" is normal. Do you have a picture showing the floor separating from the cabinet? I, for sure, don't have any gaps between my cabinets and floor. Ask to see the same thing in a finished trailer. Either, I don't understand what you mean by the 1/4" gap or Airstream doesn't either. Make sure you both understand each other before you go home. To me, there is a big difference between flexing and squishy. I just want to see that your trailer is properly fixed and/or diagnosed.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-13-2012, 06:14 PM   #52
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Horray! I was worried all day about this, and it's not even my trailer!
Last night I was charging up and down my AS like a maddened bull and could not detect any floor movement.
Fly at Night is offline   Reply With Quote
Old 03-13-2012, 06:26 PM   #53
London , Ontario
Ahh thanks!
Happy yours doesn't bounce, really!
Old 03-13-2012, 06:43 PM   #54
Ahh thanks!
Well.....errr......the boobies are another matter.
Old 03-13-2012, 06:47 PM   #55
London , Ontario
lol, literally
Old 03-13-2012, 07:30 PM   #56
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
My thoughts exactly.
The plywood you see in places like Home Depot is usually ACX or CDX. The first 2 letters stand for the quality of the top and the bottom. A is better than B, etc. This is printed on one side, but on ours it is on the bottom, so I have to guess it is BCX or BDX. That is because it has holes filled in with small pieces of wood. A would not have holes. C would have more problems and D would be even worse.
It does not look like marine grade but I am imaging what that would look like. It is possible they used thicker plywood several years ago and that's why Bob's floor and ours don't have such deflection. For years people have been complaining about the quality of plywood and asking why doesn't Airstream use marine grade? Maybe the trade off is thinner plywood (save a few bucks) and better plywood.
Another question is whether when they cut the plywood, do they treat the edges with something to repel water?
This is speculation, but I don't understand it otherwise.
I'm glad to hear you got a clean bill of floor health.
Gene
Attending to our "To Do" list aircampr 2005 and newer - Bambi all models 15 03-11-2012 09:46 PM
'76 Airstream GT Fixed Window Leak kentuvman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-11-2012 08:25 PM
1968 AIRSTREAM Caravel, a classic 17' Land Yacht travel trailer. AKA a Bambi eBay Watch Airstreams on eBay 0 03-11-2012 08:10 PM
Mancave: Airstream in the News Road Geezer Vintage Kin 0 03-11-2012 08:01 PM
