Old 09-03-2012, 05:34 PM   #15
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by CrawfordGene View Post
Apparently Ken only travels in winter. If it is hot outside, our trailer is usually hotter than the outside. Medications don't like heat and some dry foods don't either, but I'm still not opening the vents.
A flow through ventilation system like cars and truck have would be bestóa filter would solve the dirt problem.
Gene
Well, I didn't want to bring this up, but since you did, it might have something to do with the different insulation properties of our two trailers.
Mouse fur does wonders. See, I get cool just thinking about it.
Ken
Old 09-03-2012, 06:34 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
One fur all and all fur one.
Ken
I know some mouse furistas have said it acts as insulation, but it is very thin and doesn't seem to have air spaces to act like insulation, so I think it is a myth. Of course if you put your body against fur it will feel warmer than aluminum, but that doesn't indicate it is good insulation. Of course, some people may like to rub up against the mouse fur, but they may have some cat genes. That would be fur out.
Gene
Old 09-03-2012, 07:18 PM   #17
Ag&Au's Avatar
Gene
It works for mice. I never heard one complain about being cold.
Every time Daisy eats a mouse she says, "That was meowfully warming."
Ken
What are we doing to this poor guy's thread?
Old 09-03-2012, 07:44 PM   #18
Master of Universe
Gene's Avatar
Once the question has been answered, things go downhill from there.
Gene
Old 09-03-2012, 07:53 PM   #19
Ag&Au's Avatar
Gene
Is your roof white?
How about your trailer's?
Ken
Old 09-03-2012, 09:40 PM   #20
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Gene
Is your roof white?
Ken
Ok you two. The last time you took a thread off topic it got split and deleted.
I crack my front and back when it's hot out. I like it the same temp as the outside. One because I go in it with the kids when we stop. And two the fridge already works hard enough when it's hot out, why make it work harder than it needs to.
I had my cracked about 2" open through the columbia river gorge with 25 mph+ cross winds and 30 mph+ head winds and they are still there and looking good. I keep them closed under 80 degrees outside temp.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-03-2012, 09:43 PM   #21
mefly2's Avatar
2015 25' FB Eddie Bauer
Windows closed, rear FF vent open ~1/2 inch, Maxxairs on both vents, white roof ...
Old 09-03-2012, 09:52 PM   #22
purman's Avatar
1968 28' Ambassador
I have even thought about running the fan on the rear to draw air through the trailer. But have t yet. Fantastic fans h e to be open 3" us to work.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-03-2012, 09:52 PM   #23
Ag&Au's Avatar
I suspect that has to do with your trailer being constructed to 1968 manufacting standards. That was a good decade. My wife was constructed in the 60's also.
Ken
Old 09-03-2012, 10:13 PM   #24
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have the Maxxair vent covers, but still tow with the vents closed. My trailer is always cooler inside than outside when stopping to take a break. It will warm up if sitting in the hot Sun for a long time, but by then we are camped with the air conditioner on or open windows and vents. The mouse fur and vinyl headliner definately helps with the inside temps. Same with my small windows. My small windows can be opened while towing and won't break like the single large windows. I don't tow with my windows open either.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 09-03-2012, 10:16 PM   #25
purman's Avatar
1968 28' Ambassador
Do you make it to the southwest?? My trailer gets to be a sonar when driving in 100+ degree heat. I need some mouse fur in my trailer, Time to set the mouse traps in the barn darn cat keeps eating them though.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-03-2012, 10:29 PM   #26
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I know I left the bathroom roof vent 'cracked' just an inch or so on my old SOB trailer, by the time I had driven down the interstate a few hundred miles, the wind buffeting had caused the lid to completely open. Tried a few different ways while traveling, and soon discovered, traveling with it closed was the only way to go. Didn't take that long to cool or heat the trailer once parked.
Thanks, Derek
Old 09-03-2012, 10:32 PM   #27
Salem , Oregon
Images: 18
Hi, I guess you can say that I live in the South West.
2005 Safari 25-B
Old 09-03-2012, 10:39 PM   #28
purman's Avatar
1968 28' Ambassador
Ok mid southwest, Not California southwest. Although it does get really hot down there. When I went through Idaho a month ago it was 106. I think if I would have had the vents closed it would have been 120 in the trailer.
My new fresh water tank is under the trailer. It was warm enough to take a shower with. The heat off the road had it over 100 degrees.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
