Originally Posted by trailrsailr
I know it’s been a few years since the original post, but I’ve been trying to duplicate Option #1, and my Champion won’t run. I’ve kept the larger regulator intact as specified in the original post, and I’ve tried both “low-flow” and “full-flow” male quick-connect adapters to connect to my Flying Cloud, but no luck. Am I missing something? Thanks in advance!
I've attached the pictures of my set up. I separated the 2 regulators, I forget what was between them, but you can see in the 2 close up pictures the yellow tape and the fittings I used. The first 2 pics are the regulator you Dont need for the air stream. The bottom 2 actually clips to the gen--I just set it on top of the propane cylinder because it was quicker to get a picture. thats the connection that will plug into your trailer quick connect fitting.
The Quick connects (like on your airstream) I bought off amazon, the other fittings I took the pieces to my commercial hose distributor. I'm sorry that sounds vague but my hose distributor and I have a 30 year working relation, I had the luxury of taking the pieces in and saying I need to go from /This-to-That/ PM me I think I might have some extra quick connects and I probably be more specific in describing the fittings.
the top Pic is just a NPT reducer/adapter to go from the smaller size regulator to the female quick connect
the bottom picture fittings I would describe as (from left to right)
nipple-union-npt/hose flare fitting-hose supplied by champion-male quick connect(not in pic)
The hose from the gen to the "clip-on-regulator" was not modified.
I can run the gen off the trailer or a 25lb bottle (if I so choose) Hope this helps.
