Old 08-07-2015, 08:54 AM   #1
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
No water running ?
I just moved 2 sites over and now for some reason there is no water running into the Airstream. I have water running through the hose. As soon as I hook it up there's no water in the Airstream, why is this? I haven't done anything different than just move detach and reattach.
LoveSally
ILOVESALLY is offline   Reply With Quote
Old 08-07-2015, 08:57 AM   #2
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
What year AS?
Tom
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 08-07-2015, 09:02 AM   #3
ILOVESALLY's Avatar
Sarasota , Florida
2007
LoveSally
Old 08-07-2015, 09:03 AM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Hose or check valve is plugged?
tjdonahoe is online now   Reply With Quote
Old 08-07-2015, 09:07 AM   #5
ILOVESALLY's Avatar
Sarasota , Florida
Ok what should I do to fix it?
LoveSally
Old 08-07-2015, 09:15 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Disconnect the city water hose. Turn on the pump and verify that you are getting water to the faucets from the fresh water tank. Check each faucet.
Check the city water hose by letting some water run out on the ground. Reattach the city water hose and try the faucets again. Try more that one faucet to be sure that the problem is not with one of the faucets.
Brian
SuEllyn & Brian McCabe
Old 08-07-2015, 09:19 AM   #7
ILOVESALLY's Avatar
Sarasota , Florida
Brian
I tried all of above still the same. No luck.
LoveSally
Old 08-07-2015, 09:34 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Will water run if you use the pump?
Old 08-07-2015, 09:36 AM   #9
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
To clarify...You're not able to get fresh water through the faucets when using the internal water pump (and you have water in your fresh water tank) or the fresh water hookup from the campground?
Nomad518 is offline   Reply With Quote
Old 08-07-2015, 09:40 AM   #10
ILOVESALLY's Avatar
Sarasota , Florida
Correct, Nomad518.
LoveSally
Old 08-07-2015, 09:42 AM   #11
ILOVESALLY's Avatar
Sarasota , Florida
Sorry Nomad518 I can draw water from the fresh water tank with the pump. I just can't get it from city.
LoveSally
Old 08-07-2015, 09:42 AM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
did you accidentally hook up to the black tank flush
Alan
Old 08-07-2015, 09:45 AM   #13
aftermath's Avatar
Spokane , Washington
Check the check valve. Right where the hose attaches there is a small valve that you can see and touch. It has a spring behind it and when you push in on the little center it should move. It is there to prevent back flow. Perhaps something got stuck in it or it has locked up?
If you have water out of the hose and if all the faucets are working then this could be the last possibility.
aftermath is offline   Reply With Quote
Old 08-07-2015, 09:45 AM   #14
Nomad518's Avatar
2001 25' Safari
If not as Alan asked, is there crud on the filter screen where you hook up your hose from the campground faucet to the inlet on your trailer? If so, get a toothbrush and clean it off. Then, try again.
Water heater quits running 2007 safari Water Heaters, Filters & Pumps 2 10-23-2011 04:40 PM
Water pump running with no water! Michigander Fresh Water Systems 11 07-25-2011 03:04 PM
Running water to winterize? shinybean Winterizing, Storage, Carports & Covers 17 02-06-2007 08:56 AM
AC water running off top of Airstream. acrane Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-01-2006 04:11 PM
Water Pump running, water is not... CampSayler Water Heaters, Filters & Pumps 4 09-23-2004 04:34 PM
