Old 03-10-2012, 06:14 PM   #1
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Newbie propane question
'Kay, so I've managed to figure out getting water into the tank. I figured out how to close the drain valve and then put more water in the tank. I figured out the getting the pump to start filling pipes and the heater to start heating. Then I thought I'd better check the propane levels.
Does this pic mean that the primary propane tank is half empty? Or does it mean it's all empty and I'm running on the secondary tank?
Yours, Bewildered in the Bambino
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 03-10-2012, 06:32 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The red signal means that the primary tank is empty, and that you are running off of the second tank now. Through the lever over to the other side. It should turn to green. Refill the empty tank now.
Brian
SuEllyn & Brian McCabe
Old 03-10-2012, 06:57 PM   #3
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
What Moosetags said, assuming you have the Propane valves open on the cylinders. If you leave the valves closed for a day or two, the pressure in the indicator thingy drops and the red collar shows. Ask me how I know!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 03-10-2012, 07:01 PM   #4
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Then I sincerely hope I remember how you and Kirk showed me how to change the tanks, Mr. Toad! I'll give it a go tomorrow.
Thanks, Moosetags!
Old 03-10-2012, 07:38 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Z---It's easy to take the tank off...
(1) remove the butterfly bolt that holds the tank cover in place and remove the tank cover by lifting it straight up and off the center bolt...
(2) turn the empty tank off...
(3) unscrew the gas fitting at the tank end of the feed line ... it should just be hand tightened...
(4) lift the "claw" cross bar from the tank you want to remove...
(5) lift the empty tank off and take it to a propane place to fill...
When you have it filled it will be much heavier...so be ready for that.
Reverse this process to re-install the full tank ...when it's in place and connected, open it...when the other tank is empty the red collar will show... then you switch the lever to point to the tank that is full (the collar will change from red to green when you point it to the full tank)...then you can remove and refill the other tank...this way you never run out of propane.
TB & Greg and Abbey Schnauzer
#3954
Old 03-10-2012, 07:43 PM   #6
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Thanks, TB! I'll keep that close to hand so I can do it step by step!
Old 03-10-2012, 07:46 PM   #7
Southwestern , Ohio
Zlee,
Nowadays with the new no-tools fittings there's really nothing to it. Once you've done it you'll see what we mean.
Do remember to turn off the empty tank before you disconnect it, though.
Nuvite-F is offline   Reply With Quote
Old 03-10-2012, 07:56 PM   #8
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Originally Posted by Nuvite-F
Zlee,
Mr. Toad walked me through it in London, but I haven't done it since. Im always more nervous around things that can go boom.
Old 03-10-2012, 08:29 PM   #9
Southwestern , Ohio
Originally Posted by zlee View Post
I'm always more nervous around things that can go boom.
Well, that is one job where "smoking could be hazardous to your health"!
Old 03-10-2012, 08:37 PM   #10
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
I used to work around oxygen tanks. *shudder*
Old 03-10-2012, 11:12 PM   #11
Ottawa , ON
Yes, be sure to keep your cigarette to the side of your mouth, if you are smoking while changing out tanks.
(Only KIDDING!)
Old 03-10-2012, 11:15 PM   #12
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
(Only KIDDING!)
Old 03-11-2012, 12:37 AM   #13
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
On ours, the red will eventually begin to show...and it will stay that way for some time. BUT ...when it DOES get to the very end of its content, it will give off a faint propane oder in side the house. So the red is actually telling you that you may refill at anytime soon. Currently it costs @ 17 dollars to fill a tank. Wish I could do that number with the tow vehicle.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-11-2012, 06:58 AM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I'm reminded of whoever the idiot was here who smoked a cigarette and put it out by sticking it through the vent louvers on my propane filling station. I was kind of stunned when I opened the station and found the butt.
Lynn
WBCCI 21043
Question about mirrors Getahobby Towing, Tow Vehicles & Hitches 47 08-19-2013 09:55 PM
'69 Safari Bathroom Question - Please Advise BoCox 1969 - 1973 Safari 3 12-15-2012 03:38 PM
Warranty question GettinAway Buyer Guidelines 26 04-02-2012 10:05 AM
Seven pin wire question AIR-Quarius Towing, Tow Vehicles & Hitches 8 03-14-2012 05:53 AM
Propane Tanks -- Original Vintage Airstream Trailer eBay Watch Airstreams on eBay 0 03-07-2012 11:30 AM
