Old 06-02-2004, 02:02 PM   #1
Diesel Pusher's Avatar
Newbie needs info on what is required for maiden trip
After purchasing my rig in October, I have finally gotten it so we can actually take it on a trip.
Had to replace tires, and bearings.
Had to convert hydraulic disc brakes to new electric drum brakes
Had to have new 30# propane tanks installed with new valve
Had to have new converter installed
Had to have new water pump installed
Had new shower faucets and hose installed.
Had sub floor installed by door and then new vinyl commercail tile floor installed.
I currently have new 30Amp plug installed
I have a black water tank hose.
I know I will need to buy a new white water hose...can anyone please recommend what we will need for a the first trip?
1977 A/S Excella 500, 31 foot
2001 2500 HD D/A 4X4, Ext. cab, Victory Red.
Diesel Pusher is offline   Reply With Quote
Old 06-02-2004, 02:21 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Food, tools, sense of humor and cash.
also....
Slinky
Disposable gloves (for slinky encounter)
First aid kit
Sunscreen
Have fun.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-02-2004, 03:09 PM   #3
Basic essentials:
Leveling blocks. Ant spray. Outdoor grill. Lafuma recliner. Wheel chocks. Disolving toilet paper (Charmin works). Bleach for dump station disinfecting. Nitril disposible gloves for dump station. Twenty amp adaptor. Sewer doughnut. Tire pressure guage. Grill. Flamingo.
Happy camping!
Mark
Old 06-02-2004, 03:25 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I figure as long as it's safely rolling along behind us, it's a good trip! Try to relax, and keep a smile on your face (no matter what happens). Speaking of which don't forget a tight plug for the shower drain Enjoy!
Mark, what do you use the bleach for? Suddenly I have this image of you leaving behind a squeeky clean dump station!
Stephanie
Old 06-02-2004, 04:29 PM   #5
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
What to take
A flag, I bring three for my flag pole holder that I made, so that I can fly Old Glory, the Marine Corps Flag, and my great state of NY flag. Fold up outdoor chairs are a must, Deep Woods Off, a coffee pot if you drink coffee, a can opener (we forgot ours last time), a small set of tools, screw drivers, LP gas wrench, lug wrench, and DUCT TAPE (can never go wrong with it). Baby wipes are always good too, for after the dump station or sewer works. If I think of others, I'll post them. Oh yeah, I've seen people using their charged cordless drills on their stabilizers, makes putting them up and down alot faster, equates to more time to relax after setting up.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-02-2004, 04:46 PM   #6
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
New Trailer Shopping List
Maurice
Old 06-02-2004, 04:48 PM   #7
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Adult beverages
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 06-02-2004, 05:23 PM   #8
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
Get thee a pressure regulator that attaches between the hose bib (faucet/tap) and the white hose.
My father-in-law is living in our Safari while his house is being finished, and day before yesterday, I noticed that my new white hose is bulging. I taped it before it burst, and I had to tape a new spot today. And this with the 25psi pressure regulator.
Now - I have a shorter hose that came with the Safari, bu it looks to be the same quality as the bulging one. The old 8' hose that I saved from our SOB is obviously a much better hose than the other two, just by looking at it, but it is too short. I want to get a 12' version asap. Don't pinch pennies, buy the sturdiest stuff you can. Especially if it involves plumbing.
mtpalms is offline   Reply With Quote
Old 06-02-2004, 05:51 PM   #9
87MH's Avatar
1978 31' Sovereign
Images: 292
Battery?
Didn't see a battery on the "replaced" list.
I know there is a current thread on this, but 36 months is a good run for a battery - less if abused.
The Univolt will put out excess voltage unless a working battery is in the circuit.
Don't forget a way to measure both the 12 volt and 110 volt circuits. Too much or too little of either is not a good thing.
Make the first stop close to home (or in the driveway), that way a worst case situation ends up having to crawl into your own bed a bit later than usual.
Have fun!
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-02-2004, 07:37 PM   #10
Doesn't everyone?
Actually I use it for incoming and outgoing.
Occasionally one of the ends of my fresh water fill hose will contact the ground. I rinse, pour a bit of bleach on and around the connector, and rinse again.
At the dump station, I pour maybe four or five ounces on the slinky connector after draining the tanks, and let it drain down the hose. Then I splash an ounce or two on the end that went into the ground. And if I drip any waste water on the ground at hookup, I hit it with a bit of bleach as well.
I then rinse everything with water to keep the bleach from eating the plastic.
Paranoid? Perhaps.
Mark
Old 06-02-2004, 07:42 PM   #11
Originally Posted by robandzoe
...and DUCT TAPE (can never go wrong with it). Rob
No, no, a thousand times no! What you want, especially for an Airstream, is paper backed self-adhesive aluminum tape. It is far, far superior to duct tape. Available at most home centers.
Mark
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
Flying J Travel Plaza Info Pahaska Our Community 2 07-21-2003 11:04 AM
Newbie Needs Info... TheJarvis Our Community 13 11-06-2002 09:31 AM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
