Old 07-01-2014, 05:59 AM   #1
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
New Product
Wonder if this could be developed for integration for RV's? I'd be very interested in trying this.
Refuel
tsunami is offline   Reply With Quote
Old 07-01-2014, 07:51 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sorry but as designed NO
It relies on weight of a freely mounted tank. Since the tanks on your trailer are held down that would not allow it to work.
The older Airstream tanks have a built in system that shows up on the monitor panel. If yours does not consider changing tanks and adapting that to work.
If you need the remote readout while the trailer is parked you could release the hold down on the tanks and place the scale under them and that would work. but you would have to remove the scales and tighten down the hold downs before moving the trailer.
2004 Excursion 4x4
Old 07-01-2014, 07:59 AM   #3
2010 25' FB Flying Cloud
Davenport , Iowa
This is an interesting "gadget". Look at the QUIRKY
company. it is an interesting concept for NEW inventions and marketing. I believe they were on "Shark Tank" at one time.
Airtandem is offline   Reply With Quote
Great New Product SGT DAVE Sprinter and B-van Forum 1 05-25-2014 02:40 PM
New Product: Heated Water Hose Zigidachs On The Road... 4 01-09-2014 05:08 AM
May have found new product to cut through corrosion! Air Cruiser Cleaning, Stripping & Polishing 4 07-31-2013 10:15 AM
Water Leaks? - New Repair Product COArgosy78 Plumbing - Systems & Fixtures 10 05-27-2008 01:22 AM
new clearcoat product crispyboy Clearcoat, Exterior Paint & Trim 5 12-03-2004 06:24 PM
