Old 09-21-2016, 12:58 PM   #1
Mcwey's Avatar
2008 30' Classic
Fort Collins , Colorado
New Hitch?
We purchased an 08, M30 a couple months back and find the hitch which came with it is a little wanting. We are thinking of getting a Pro Pride or Hensley but can't seem to find much information on hitch weight. The plate on the roadside
of the trailer says Gross Weight 10,000 lbs. In other information I find about 8000 lbs? As we don't have access to a tong weight scale I am wondering if
some of you out there have anything better than what we have which is pretty much nothing!
Thanks in advance!
Monty
Mcwey is offline   Reply With Quote
Old 09-22-2016, 01:40 AM   #2
1979 23' Safari
Wayland , New York
Not quite understanding what you're looking for.
Old 09-22-2016, 02:00 AM   #3
Alluminati's Avatar
St. Louis , Missouri
You can take your trailer to the nearest truck stop and weigh the trailer off hitch. As much time and effort as that takes, I was looking for another method to weight the tongue. The owner's manual in my 27 yr old trailer suggested using a bathroom scale. Here's the method they suggest.
http://hildstrom.com/projects/tonguescale/
I haven't tried this yet, but plan to do so soon.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Alluminati is offline   Reply With Quote
Old 09-22-2016, 02:02 AM   #4
2007 22' International CCD
New Hitch?
ProPride systems are rated for up to 10,000 pound towing I think. See their website, contact Sean for his inputs. IMHO the ProPride is a good buy, but my rug is not that heavy. I went with Sean's recommendation for the WD bars. (Sean is owner and is expert on his product. If he thinks it's not good enough, he will tell you straight up. )
KE4GNK/AE
Old 09-22-2016, 07:15 AM   #5
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Hitch weight 2008 Classic
Mcwey,
in the document archive it shows 670 lbs for your trailer. This is without options or fluids. They now carry propane weight in the hitch calc. but don't know in 2008. You should at least consider 670 for a minimum hitch weight. And IMHO, your hitch on your tow vehicle should be rated for 1000 lbs.
We currently see that what they publish for hitch weights is lacking.
What your plate says is correct for your trailer and you should abide by that. Where the 8,000 you found is dubious.
Base weight and gross weight are different. Base weight is less than gross weight and without options included by special orders, previous owners or yourself.
NCC (Net Carrying Capacity) is what the limit you can carry in the trailer minus the options.
How to figure this is to bring your trailer to a scale completely empty and weigh it. This will be your new base weight.
Then subtract YOUR base weight from the GVW and that is YOUR NCC.
If you put a hitch on it, then subtract from your NCC.
The hitch opinions her will vary as to type and mfg. It will be you choice to as to which one you would prefer and work well for you.
It will depend on your tow vehicle for sure. But the hitch you chose will be required to handle the GVW of your trailer, which is 10,000 lbs.
Good luck in your search.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 09-22-2016, 08:00 AM   #6
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
What is a 2008 M30?
TRIPPPIN is offline   Reply With Quote
Old 09-23-2016, 10:39 AM   #7
Mcwey's Avatar
2008 30' Classic
Thanks to all !!
Thanks everyone for the great replies! I will follow
the suggestions given.
The M30 is a 31 with the shower on the curb side of the Airstream.
(So I am told)
Thanks again.
Monty
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 04:38 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 08:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 05:40 PM
a new forum and new hitch and new market approach... 2airishuman Hitches, Couplers & Balls 93 04-29-2008 06:50 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 12:48 PM
