02-17-2012, 12:48 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
My journey to Airstream 'Mothership'
I'm leaving one week from tomorrow. From Texas to Jackson Center,Ohio. I have some needed repairs.
Why not make a small photo/blog of it. I will,take pictures the whole way. Give my Mpg and updates regularly. I will let you know how the repair process goes and will take many many pictures while I'm at the Mothership. First time for me to attempt this,....what do you guys think?
Any interest?
The countdown will start in 8 days until departure.
02-17-2012, 01:04 PM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
Any interest?
Take the tour. I hope Don is still doing them. He's worked for Airstream for over 50 years, and is a wealth of information about the history and the manufacturing process. The people of Jackson Center are very nice. A blog/journal is a great idea. Can't wait to see the pictures.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
02-17-2012, 01:38 PM
Vintage Kin
Corpus Christi
Are you going by way of Joplin, MO or Memphis, TN?
I'd be all over the weather forecasts for either route. And use NHTSA site for road closure information.
Jackson Center sunset time is at 18:21 one week from now. The "rule" is to never drive into the dark (and cheat at the other end by starting no earlier than 1/2-hour prior to sunrise. Which in Arlington is at 0645, for an 0615 departure.)
I believe you may well enjoy working against the constraints of travel speed and departure/arrival times. That Ford has got to be quite comfortable, so records of mpg will be consistent as you're using a set speed (check local temps and winds; temps & fuel mileage have a one-to-one relationship: every 1C drop in temp is a 1% loss in mpg. "Winter fuel" is not the cause folks think it is. This is said for your future comparisons). I use the tachometer rather than the odometer to set the cruise control as it is easier to nail than "speed".
I also like the site Roadfood.com - Your Guide to Authentic Regional Eats to find the best lunch spots. And the AMBest Home independent truck stop directory for fuel. Fast in & out, if I want it to be. I tie those both to my 2 & 4 hour breaks. Makes those 600-mile days easy by arranging trip "legs" in advance (with state rest areas otherwise).
Some basic trip planning like this -- the time & distance of each leg, right down to Interstate mile marker -- relieves the mind of the tedious stuff and allows imagination to work more freely (pics, etc).
2004.0 DODGE 2500 QC/LB Cummins 305/555; 6-manual, 7,400-lbs; fuel cost is 25-cpm towing 34' trailer; 15-cpm solo.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR) Currently: 1976 32' SS
Photos prior to sale
02-17-2012, 01:57 PM
A.K.A "THE STREAM"
Arlington
Going my Memphis,tenn..then north. Due to Texas chl laws in Illinois. I am planning on leaving Saturday morning about 6 am. Then drive till I'm tired.
My last long run was pikes peak to home. One day....it was easy. The biggest trip I do and have done twice was Arlington, Tx ..home...to Orlando,Fla. right at 1,000 miles. Gonna slow down and take my time this trip...especially if the weather gets bad.......I'm excited about the trip. I can't wait to start posting pictures.
Shane
02-17-2012, 06:47 PM
Vintage Kin
Corpus Christi
Here it is as an idea. This is a rough draft of how I do it (assuming a two day trip to JC).
Day One
Using IH-30, not 20, to depart 0615
MM-138 Safety Rest Area Facility Location Map Mt. Pleasant, TX
2' 12" @ 65-mph = 140-miles
[0830 - 0845]
IH-30 MM-56 Rest Area Gurdon, AR
130-miles at 2-hours
[1045-1100]
Ed & Kays Restaurant
15228 I-30, Benton, AR
81-miles @ 1' 20"
[1225-1315]
IH-40 MM-235 Rest Area Forrest City, AR
116-miles @ 2' 0"
[1500-1515]
Jackson RV Park
Exit 80A
Jackson, TN
131-miles @ 3-hours
[1800]
558-miles @ 65-mph travel speed = 9-hours +/- drive time. An 0615 departure with stops brings travel time (not drive time) to about 12-hours. Off the road before dark.
I assume you can drive to this point and find a nearby truck stop to fuel with a DEF Ford with a big tank at a reasonable rate of speed. Assuming a burn rate of 15-mpg, then this is 37-gls.
I also like to "navigate" by Starbucks. I want that 4-bux coffee at around 1500. Past Little Rock you won't find one. But you could fill the thermos in LR.
Jackson, TN may be a bit far. But there isn't much around Memphis (and it ain't a great town, either). So I have no idea of this RV park outside of what rvparkreviews said. (Check on AIR).
In all cases I have not used satellite or street views to see if there is room for a TV-TT rig. Nor have I checked state info to see if these rest areas are even open. Or the restaurant has weekend hours. Etc. Etc.
Takes a few hours, sometimes several evenings to lay out a good trip plan. A big part of the pleasure as I see it, the anticipation. Especially as to a fun place for lunches every day. (I avoid the C-stores religiously). I put addresses & phone numbers on the itinerary for my reference, and leave one at home for friends/family.
Certainly I can depart from all this, but it does make life easy when a scheduled arrival is expected at the other end.
Put it in gear and just go is work, IMO. Breaking the day up in this manner keeps me away from the rhythms of other people. I have places to go and people to see . . at my pace.
02-17-2012, 06:59 PM
A.K.A "THE STREAM"
Arlington
Rednax...your awesome!..honestly gonna leave about 5:00 am and drive till I get fatigued,....I dont ever have a plan....I will probably sleep in my stream at night at a rest stop,Walmart or a cracker barrell along the way.
But I can't thank you enough.
Shane
02-18-2012, 06:23 AM
Normal
REDNAX has been busy being a good neighbor here on the forums.
Maggie
The more you know, the less you need
02-18-2012, 09:44 AM
Vintage Kin
Corpus Christi
(A guilt trip sometimes. Temper, and re-temper.)
And, Shane -- at a given speed -- I think of the above as a way of checking where I am. Not where I have to be. How far I can actually go in a day or by lunch time. And avoid chain stores of all sorts.
Where are the first pics? Got the dog going with you?
02-18-2012, 10:14 AM
A.K.A "THE STREAM"
Arlington
No pup..no wife...just me.
The first pics will be pulling out of the driveway next Saturday...maybe packing on Friday afternoon.
Shane
02-18-2012, 10:22 AM
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham
, Ontario
I for one am looking forward to reading about " The adventures of SuperShane and the Pill Stream" while he makes his way home to the Mothership for a reunion of child with it's birthplace.
BTW Shane you never did mention what the repairs are that warrant such a long trip and why you feel that they can only be done at JC instead of your local A/S dealership. Inquiring minds want to know.
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
02-18-2012, 10:30 AM
A.K.A "THE STREAM"
Arlington
I have a leak under the dinette with a soft floor and mold. Curbside rear. My warranty ran out 3 days and I saw the mold. In reality my airstream was being serviced for the pigtail propane leak and haven't had a chance to clean the inside. The dealer was also doing other repairs and had my airstream for awhile. One day after getting her back I saw the mold and felt the floor. There is a thread I started with pictures on here. I called and spoke with Jim and he said not a problem and authorized a belly removal to look at it....I got to thinking if this requires a full laminate removal..I don't want a seam in my floor...these dealers are not worthy ,IMO to do the work. Plus if other leaks or problems are detected then I cut out the middle man.
Shane
02-18-2012, 10:44 AM
1961 30' Sovereign
1947 22' Liner
Durham
, Ontario
Well no wonder you have mold on the floor, when I have a leak I usually use the toilet. LOL
Seriously though that's incredible that the floor is rotting out so quickly. I had heard that they finally fixed the rear bumper leak issue but I am guessing that it was fixed after yours was built.
Do you think it's from the bumper area or from the rear pano's?
A full laminate removal would require a full gut would it not? I agree with you that kind of job is better left to the factory.
BTW when you do the tour make sure you grill Don about when they are going to restore wally's gold trailer. If enough people ask maybe just maybe they will finally do it.
1947 Liner 22 ft.
TAC ON-11
02-18-2012, 10:54 AM
A.K.A "THE STREAM"
Arlington
Maybe the water damage is from using the rear door and not being too accurate on my aim.......
It's not a huge soft spot,..but I feel the laminate separating from the floor...like giving when pressure is applied.
I don't know where the water is coming from.
I'll mention it about the gold trailer,.....but I am gonna go in low profile, with a great attitude.
Shane
02-18-2012, 12:48 PM
2008 25' Safari FB SE
Crawford
Shane,
The plywood, if not too damaged, can be filled with epoxy and will as strong or stronger than before. Finding the source of the leak is important too, of course.
I don't know what kind of floor the International has other than your statement it is laminate. New Interntionals have "wenge" laminates which would be a dark African wood on the surface. Non-vinyl laminates may swell once the board the surface is glued to get wet and have to be replaced. Ours has a thin, sheet vinyl floor that has bumps in it from cold temps and improper installation. In at least one cabinet, it is curling since the attachment to the floor (staples I think) has failed. I will take out most of the exposed vinyl and what I can remove under cabinets and seal the floor with something. I'm not sure what yet—epoxy paint is more complicated than I want it to be (I haven't detected any soft spots, but I haven't taken the vinyl out either) and am thinking of exterior polyurethane instead. I think you have a different problem though although you may want to make sure as much of the floor is sealed as practicable.
If laminate is interlocking (sort of like tongue and groove), removing it may damage some of the locking parts and make it hard to replace properly. If glued, there is also potential for damage. Floating floors are better because of the glue issue, but the locking mechanism is pretty frail on some of it. I think it is important to clarify this before works starts.
Rednax and you have very different ways to plan a trip. I am more like Rednax and agree the planning is part of the thrill of anticipation. No matter how much planning or non-planning there is, we all seem to get there.
Has Airstream agreed to pick up the cost of this since you were only 3 days out of warranty? Read your warranty carefully. There's something about 5 days after the 2 year term that seems to extend the period for those 5 days. Have they or a dealer worked on sealing the panos? If they did, you can claim they didn't do it correctly, or they didn't check for floor damage at the same time.
Gene
| Thread Tools |
| Display Modes |
