Old 11-06-2011, 07:38 AM   #1
Djmclean's Avatar
1988 35' Argosy 5th Wheel
Cumming , Georgia
Monteagle, TN
I'm looking at a trip to visit our son at Ft. Campbell. We live just outside of Atlanta. The direct route to get there is up I-75 to I-24. That would take us right over Monteagle. My husband is concerned about pulling our Argosy 5th wheel over that mountain. We use a Ford 550 Longhorn hauler (a 2002 model) and our Argosy is an anchor. It's 35' with a slideout.
Anyone have suggestions as to another route to get around the mountain without going hundreds of miles out of our way?
Djmclean is offline   Reply With Quote
Old 11-06-2011, 07:52 AM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
You can get off I-24 at South Pittsburg TN and go to Huntsville AL and go up I-65 to Nashville and then get back on I-24 to Fort Campbell. Monteagle is not that bad as compared to many other highways in the country. The West bound lanes through Monteagle is not at difficult as the East bound lanes. Going through the I-65 route may add as much as 2 hours to your trip. I do not know of any simple route around Monteagle. The two lanes that bypass the interstate are much worse than I-24 over Monteagle.
Ridgerunner3 is offline   Reply With Quote
Old 11-06-2011, 09:08 AM   #3
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from GA. . . With an F550 I would not worry about Monteagle. Extra slow lanes up and take your time down. I pulled 25' TT w/ F250 over and it wasn't a big deal, really., Regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 11-06-2011, 11:06 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Should not be a problem going over Monteagle.. I have pulled it in both directions many times with large fifth wheels. You will have to drop a gear or 2 on both the up and down segments.
I was using a 99 Dodge Cummins 3/4 ton
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 11-06-2011, 11:17 AM   #5
1966 24' Tradewind
Sequatchie , Tennessee
No problem
I live in this area and pull my 24' TradeWind up and down Monteagle, (both sides) with a 1977 ford half ton with no problem.
Harleyduo is offline   Reply With Quote
