Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 05-18-2017, 11:16 AM   #1
2018 27' International
Southeastern MI , Michigan
Michigan to Bar Harbor - route recommendations
Looking for suggestions on the best route from SE Michigan to Bar Harbor, Maine. Probably crossing into Canada at Port Huron unless Windsor makes more sense. Thoughts/experiences?
Countryboy59 is offline   Reply With Quote
Old 05-18-2017, 11:34 AM   #2
RxGuy's Avatar
2010 27' FB International
Deforest , Wisconsin
I would go the Port Huron Route. That is the route that we took when we went to Maine a few years ago. Went to Niagra Falls, then through NY.
I would think that the Sarnia customs might be a little less busy than Windsor.
Another option is to travel through Canada most of the way, up towards Ottawa/Montreal then cross into US. Make sure you have a passport.
RxGuy is offline   Reply With Quote
Old 05-18-2017, 02:02 PM   #3
dznf0g's Avatar
Oswego , Illinois
X2, used to live about half way in between. Port Huron is just way more pleasant.
-Rich-
Old 05-18-2017, 02:27 PM   #4
2017 22' Sport
2018 26' Flying Cloud
Brighton , Michigan
If you go the Sarnia crossing, which I recommend and decide to re-enter the US at Buffalo use the northern most entry point and hit it as early in the day as you can. In summer the delays can be extensive from mid-morning on. The trip thru Canada is stress free, good roads, nice travel plazas, well marked and minimal elevation changes.
Rivet Rocket is offline   Reply With Quote
Old 05-18-2017, 04:11 PM   #5
Yep, crossing at Port Huron. Really wondering about the last part of the trip, through Maine. What's that like?
Old 05-19-2017, 01:51 PM   #6
2005 28' International CCD
Camarillo , California
From SE Michigan; 90, 480, 80, 81, 84, 95
loft47 is offline   Reply With Quote
Old 05-19-2017, 02:39 PM   #7
Sag Harbor , New York
What part of Maine are you asking about, and where would you be coming from? If you stay in Canada until Montreal, the route across central/southern ME would be one thing. If, however, you are re-entering the US at Niagara Falls, and heading east towards Boston, you would probably be coming into ME from the south.
These would be quite different routes.
Peter
Old 05-19-2017, 05:06 PM   #8
Airjeep
Airjeep's Avatar
2012 27' FB Eddie Bauer
Zurich , Ontario
If you are going to go through upper New York state, Lewiston is nicer than Buffalo, IMHO.
Do you travel interstate type of highways?
Port Huron-Sarnia 402-401-403-Lincon Alexander-QEW-406?-Lewiston would be my suggestion. 401 east of Toronto is very dull. Toronto 401 is very busy, busiest HWY in N. America.
Backroads, lots of choices.
Cheers, John
Airjeep is offline   Reply With Quote
Old 05-19-2017, 05:47 PM   #9
2014 23' FB Flying Cloud
Ann Arbor , Michigan
Did thid trip last summer. Went south of great lakes on east leg of trip, folloeing the great lakes southern shore till e got to the "top" of Lake Champlain, then down the middle of that Lake (admittedly turned out to be not as pretty as many Upper Michigan drives along the Lakes). Then across the Kancamagus Scenic byway through the white mts. to Acadia. We did a side trip to Mouse Lake State Park to see moose on the hoof. Went back to the Main shore at Portland (didn't find good camping options there), then back across NH to Woodstock, VT. Then via Niagra Falls, through Canada to Port Huron. So much to see and do. Almost can't choose a bad route. Just need to return to those states more often. Enjoy the Trip! Howee!
HoWee is offline   Reply With Quote
Bar Harbor Maine EarlM On The Road... 7 06-29-2015 05:59 PM
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-02-2013 11:17 PM
Bar Harbor or Bust! ZoominC6 On The Road... 6 07-28-2011 06:56 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Bar Harbor, ME luckydc On The Road... 4 08-22-2005 06:22 PM
