Old 06-03-2004, 08:52 AM   #15
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Originally Posted by crazylev
...... Also have wheel choks (also pretty ugly), .......
Jonathan
So why are wheel chocks made in such lurid colors? I've seen international orange, crayola yellow and grandmas lipstick red - what gives? How about some nice gray ones or sage green or gosh... even aluminum would be lovely.
AirForums Custom Search
Janet H is online now   Reply With Quote
Old 06-03-2004, 09:12 AM   #16
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I have a nice set of BAL wheel chocks which are aluminum looking. I also have a neat BAL single-wheel lifter which lets you level the trailer by putting it under the low side wheel and cranking it up however far you need to go. Very slick! No neon lifting blocks for us! The only downside is sometimes it's hard to slide around the wheel on soft ground, so we keep one piece of wood to put the low tire on if we have to, then we can slide the leveler under there.
Stephanie
Old 06-03-2004, 09:50 AM   #17
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Janet.
My guess is that you don't forget 'em if you see 'em. I think improvising with four pieces of nicely wedged firewood would be just as effective.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 06-03-2004, 04:13 PM   #18
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Second the recommendations
Crazylev,
Like Stefrobrts, we have the BAL leveler as well as the BAL compression chock. The leveler works great and is sure easier than trying to get JUST the right amount of chocks under the wheels for side to side leveling. I did find that the tires on our '02 Bambi were too large to allow the leveler to slide easily underneath, especially on rockie sites. I fixed that by slightly expanding the leveler by standing on one arm and pulling up on the other. Probably didn't change the distance between the arms more than 3/4" but now the leveler slids in perfectly. The BAL compression chock is a unit that also slides underneath both sides of the tire, but it has a long jackscrew that you tighten against the wheel.
Also the McKesh mirrors work great. I can easily see the cars closer than the required 200ft (ie anything 200' behind the trailer must be visable in the mirrors). I also added a convex mirror on the McKesh mounted on the drivers side. Between the McKesh, the convex and the normal outside mirrors, I have NO blindspots on the either side of the rig.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Maiden voyage JLD On The Road... 1 10-19-2006 03:03 AM
Maiden voyage completed Silvertwinkie Our Community 7 04-05-2004 06:04 PM
Maiden Voyage Down South wheel interested Our Community 10 03-29-2004 01:02 PM
Maiden Voyage JLD On The Road... 5 02-20-2003 05:57 PM
Maiden Voyage pjtaia On The Road... 3 10-14-2002 08:55 PM
