Old 06-12-2007, 11:23 PM   #239
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, moosetags. Since we got on this tire thing and I want you and everyone else to be safe, I have three questions. (1.) Is it OK to put 80 lbs air pressure into the stock, Airstream wheels? Wheels are also rated for maximum air pressure. (2.) Would load range "E" tires at 80 lbs be too hard and beat your trailer to death especially on rough roads? (3.) With two destroyed tires at once, by chance did you check the tire pressures on the other two before replaceing them?
We are enjoying your pictures and stories of you trip and all the great information for the rest of us, soon to retire, and do some traveling of our own. We will all be on our toes now with tire inspections and maintainence. Hope you can finish your trip and many more without tire concerns.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-13-2007, 12:16 AM   #240
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
1. I would think that the OEM cast aluminum wheels can handle the load range E tires and their 80 psi.
2. I don't think so. My TV runs E's at 80 psi whether I'm towing or not, and the ride has always been acceptable.
3. When we changed the tire on the highway and replaced the blown tire with the spare, I checked the pressure in all four tires before proceeding. I did not check them again at the tire dealer.
SuEllyn & Brian McCabe
Old 06-13-2007, 02:46 AM   #241
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Brian, Iím really enjoying your travel log here,
but I must say Iím very concerned about your tire pressure at 80Psi.
Your unit I think has a Gross of 7500, which is about 1900lbs per wheel.
A tire with load range B at 1900 is 45lbs add 10 Psi for speed of 75mph or 55Psi.
A tire with load range C at 2150 is 50lbs add 10 Psi for speed of 75mph or 60Psi.
They donít show 1900lbs on the chart for C.
A tire with load range D at 2540 is 65lbs.
But you donít have near that load
The chart I found doesnít list the E range in an ST, but it must be higher than 2540, I would guess 2700lbs.
I think you need to consider lowering that tire pressure to about 60,
Please contact the dealer for a telephone # of the manufacturer to confirm this, JMHO
As far as your TV at 80 that sounds right for the rear tires, but on my 2500HD pickup it calls for 55 in the front tires and 85 in the rear at max.
PS: Doorgunner, sorry this horse isnít dead.
'77 Sovereign Intl 31' CB
Old 06-14-2007, 08:20 AM   #242
moosetags's Avatar
The Maxxis Tires that I put on Lucy the other day actually have a maximum load rating of 2830 lbs. @ 80 psi. The tire dealer in Gillette, Wyoming, recommended running 80 psi, even with an 8000# load. The service manager at this tire dealership seemed extremely knowledgeable, and mounts many more trailer tires than most big city tire companies. This dealer had over sixty of these Maxxis ST's in stock. When I got the replacement Goodyear Marathon in Dallas, the dealer didn't even know that Goodyear made such a tire until he looked it up, and then had to get one shipped in from the warehouse in Fort Worth. I tend to go with the recommendation of the tire guy in Gillette.
My 2005 Suburban 2500 door post show a recommended tire pressure of 50# front and 89# rear wich is what I run when not towing Lucy. The reason that I run 70# front when towing is that when a weight distributing hitch is properly adjusted, it transfers half of the trailer weight to the front wheels of the TV, dictating a higher pressure for front tire load. When I recently stopped at Roger Williams Airstream in Weatherford, Texas, and had David Tidmore readjust my Hensley. He told me that I should be running 80# front with the Hensley properly adjusted.
Old 06-14-2007, 08:51 AM   #243
moosetags's Avatar
Day 31 - June 13, 2007
We drove out east of Rapid City this morning and took a very scenic and casual drive to Badlands National Park. We drove the dirt roads of the Park for several hours. It's easy to image that you are driving on another planet. The prairie dogs are more that willing to pose for pictures. The goats are not quite as cooperative, but fun to watch anyway. The terrain is like nothing else and very interesting to see close up and personal.
After we left the Park, we drove up to Wall, South Dakota, and visited the world famous Wall Drug Store. That place has got to be the largest single retail store in the entire world. This is really significant when you consider that it is in a town of 800 people in the middle of nowhere. If you are ever travelling through South Dakota on I-90, be sure to stop at Wall Drugs, and allow several hours to see it. It's a really neat place. There are also a couple of cute little campgrounds right in Wall.
We headed back to Rapid City, and as usual, by the time we got back to Lucy, it was dark. We partook of a microwave hamburger supper from Lucy's kitchen.
ID:	39206   Click image for larger version
ID:	39208   Click image for larger version
ID:	39210   Click image for larger version
ID:	39212   Click image for larger version
ID:	39214   Click image for larger version
Old 06-14-2007, 09:19 AM   #244
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Moosetags,
With the tire issues behind you (in more ways than one...and I'm sure by now we've debated the whole thing to death) you guys are really have a great trip. You are seeing a lot of country that most would like to but won't for what ever reason. Sharing your pictures is a great way to keep us all aware of the uniqueness that awaits us in every little town and down every little side road that's out there.
Barry
safari57 is offline   Reply With Quote
Old 06-14-2007, 11:03 AM   #245
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Enjoying your travelog!
Some good friends of our family own the campground in Interior, SD. This campground is on the very edge of the Badlands N.P. These folks are really nice and can tell you a lot about the local area. They also own a ranch that is adjacent to the Park.
When I get my trailer done - this will be one of the first trips to go see these folks.
crispyboy is offline   Reply With Quote
Old 06-14-2007, 12:00 PM   #246
moosetags's Avatar
Thanx for the tip, but we've already done the Badlands. Today, we are heading up to Deadwood and Lead, and tomorrow we're going south to Custer State Park.
Old 06-14-2007, 05:11 PM   #247
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
We enjoyed watching the prairie dogs the last time we visited Custer State Park.
Richard
Old 06-15-2007, 08:10 AM   #248
moosetags's Avatar
Day 32 - June 14, 2007
We toured the area north of Rapid City. We hit Deadwood, Lead, Spearfish, and Sturgis. All of these towns were pretty neat, although Deadwood has become super "touristy". It was still really interesting to see. I had worked in this area about 35 years ago. It has changed a bunch. The neat old buildings are still here, and the towns are still nice, especially Spearfish. Sturgis has become all about motorcycles, but really neat to see. We saw the cutest TT there in the middle of a big vacant lot. We also saw a really nice larger AS there all hooked up in a church parking lot.
We took the scenic drive through Spearfish Canyon (US 14A out of Spearfish). There was some really impressive scenery in the Canyon. As usual, we got back to Lucy for a microwave supper after dark.
ID:	39265   Click image for larger version
ID:	39267   Click image for larger version
ID:	39269   Click image for larger version
ID:	39271   Click image for larger version
ID:	39273   Click image for larger version
Old 06-15-2007, 08:13 AM   #249
moosetags's Avatar
We're heading to Custer State Park today. We hope to see your little buddies.
Old 06-15-2007, 08:22 AM   #250
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Is that Paladin (Have Gun Will Travel) headed for the Moose Lodge? I knew he was still out there! Thanks again for all the pics. DG
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 06-15-2007, 08:31 AM   #251
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
LOL
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 06-15-2007, 08:33 AM   #252
moosetags's Avatar
In Deadwood, we saw several such people in period garb on the street. We don't know whether they are employees of the Tourist Development Commission or part of a time warp that we wandered into.
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-29-2005 11:56 PM
Great Link for MH and TT repair +info 74Tradewind Airstream Motorhome Forums 0 10-31-2002 07:29 AM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
Pulling a Bambi with a Ranger? wallycox Tow Vehicles 42 10-17-2002 01:29 PM
