Old 09-12-2010, 09:30 PM   #1
howco's Avatar
1970 27' Overlander
Sumner , Washington
LP Gas facts.......
Just completed our 3200 mile shakedown cruise in our 1970 A/S 27' International.
Learned two things about our LP tanks, I have two bottles both about 7.5Gal
I ran the refrigerator for two solid weeks one one tank alone, pretty respectable, that was on the coldest setting as we were in So Cal the bulk of the trip. While filling the tanks in Shasta, Ca. I asked the LP man how to tell how full your tanks were, he told me to pour some hot water over the tank from top to bottom, it will freeze where the gas level is. I didn't get to do this yet. Has anybody ever heard of this before???
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 09-12-2010, 10:07 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I don't think it'll freeze unless the ambient temperature is already pretty low, but this is basically the principle behind the stick-on propane tank level indicators. A temperature-sensitive strip runs vertically up the tank... you pour hot water on it, and after a moment the part of it that is below the level of the LP inside the tank cools and changes color, while the part that's above the level in the tank stays warm.
Old 09-12-2010, 10:07 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Yep, the water won't freeze, but the tank will be noticeably cooler below the liquid propane level.
Bill
Just my personal opinion
Old 09-13-2010, 04:30 AM   #4
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
lp gas tank
just like yesterday....in my mind,,,i prevision the thank that is about to be empty, and like yesterday when cooking and the burner goes out...then you know the tank is empty
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 09-14-2010, 11:59 AM   #5
howco's Avatar
1970 27' Overlander
Sumner , Washington
Thanks King
Old 09-14-2010, 01:47 PM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
There are a couple of variables here, but, yes, water can freeze on the exterior surface of tanks if the ambient pressure inside the tank is just right, allowing the propane to boil readily.
But this method is strictly for the novice. It is not permissible for licensed fillers to use anything like this method. The National Fire Protection Association (NFPA 58, Liquefied Petroleum Gas Code) recognizes two methods (filling by volume, filling by weight), though some states may prefer one over the other. (NM requires filling by weight if possible.)
For the novice, you can determine empty and full by math applied to markings on your cylinder:
WC XXX -- This is the water capacity in pounds for your cylinder. Multiply it by .42 to reveal the pounds of propane that your cylinder can contain when full.
TW XXX -- This is the weight of your cylinder when completely empty (essentially, the weight of the metal).
So if you have a cylinder that can contain, say, 29.97 pounds of propane, and the cylinder weighs in at, say, 25 pounds, then the following obtain:
1. If you weigh this cylinder, and it's at 25 pounds, then it's dead empty.
2. If you weigh this cylinder, and it's close to 55 pounds, then it's full.
You can figure for yourself what intermediate weights indicate.
Lynn
WBCCI 21043
Old 09-14-2010, 03:05 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
If you have the auto change-over valve in place and it is operating correctly, my method is to leave the second tank turned off and burn the selected tank until empty. I then switch manually and get the empty filled.
Yes, I do have to restart everything, but that is much easier than being out of propane completely.
To anwser you question, yes pouring water down the side will safely indicate the liquid level, and give you an idea how much propane remains. Keep in mind, it will appear the tank is not full via this method, even when you just had it filled.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-14-2010, 03:11 PM   #8
Ottawa , ON
Up here, the fill-up places I see have stickers on the equipment saying that by law they are prohibited from filling the tanks to more 80% of their capacity.
It still costs me $25 to get gas in an empty tank though. I offered to give him 80% of that, and he looked at me like I was crazy!
The nerve!
Lynn
Old 09-14-2010, 04:11 PM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
The nerve!
Yes, that's correct. The WC figure stamped into the collar of your cylinder takes the 80% fill margin into account.
Lynn
WBCCI 21043
Trailer Tire Facts tvanwave Tires 28 09-21-2010 11:58 AM
'65 Overlander historical facts kewpie 1965 Overlander 1 03-24-2009 08:06 AM
GM facts and fiction toastie Off Topic Forum 300 12-02-2008 11:23 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Interesting facts excelladep Our Community 8 06-08-2002 09:11 PM
